Liqui Moly Products - engine oil & additives
  • Short URL:  http://modifika.si/379631
    1 Wk 3 Days 12 Hrs 46 Mins 44 Secs
    Kami menawarkan produk perawatan mobil terbaik dunia , Liqui Moly, dari JERMAN, yang mendapat peringkat nomor 1 menurut survey AUTO BILD magazine, mengalahkan oli oli terkenal merek lain
    Oil products
    5W30 Long time Hi tech 5 liters
    Top-quality, state-of-the-art, low-friction motor oil for use all year round. The combination of unconventional basic oils using synthetic technology, together with the latest additive technology, guarantees a motor oil that provides exceptional protection against wear and reduces oil and fuel consumption, while ensuring that the engine is immediately supplied with oil.
    Intended use
    Optimum for modern gasoline and diesel engines with multi-valve technology, Valvetronic and turbocharging (with or without charge air cooling). Especially suitable where there are long intervals between oil changes and heavy duty engine requirements.
    5W40 Synthoil High tech 4 Liters
    Energy-conserving oil for today’s engines. Reduces oil and fuel consumption. Optimum lubrication even under extreme operating conditions. With thermally-stable wide-range viscosity. Immediate lubrication during cold starts and optimum oil pressure at all engine speeds. Lubrication is also reliably maintained at extreme temperatures. Optimum engine performance. Improved protection against wear and extended service life for the engine. Tested on catalytic converters and turbochargers.
    Intended use
    Year-round oil for petrol and Diesel engines. Especially suitable where there are long intervals between oil changes andextreme demands.
    10W40 Mos2 leichtlauf 4 liters
    The MoS2 anti-friction lubricant forms a high load-bearing film of lubricant on all friction and sliding surfaces. The MoS2-lubricant film reduces the resistance to friction and allows engines to run -- so they conserve more energy even under extreme conditions. MoS2 Energy Conserving guarantees: significantly less fuel and oil consumption. Significant wear reduction, fewer breakdowns and emergency lubrication properties. Stable to ageing and stable viscosity. Good cold-start behaviour and high operational reliability. Prevents sludge formation. Tested on catalytic converters and turbochargers.
    Intended use
    Year-round oil for petrol and Diesel engines with extra wear protection.*
    Oil additive mos2 4
    The anti-friction lubricant MoS2 forms a high load-bearing film of lubricant on all friction and sliding surfaces. This product reduces friction and guarantees energy-conserving performance for the unit. This yields the following advantages: significant savings in fuel and oil consumption, scientifically proved reduction in wear, fewer break-downs, emergency lubrication properties. Tested on catalytic converters and turbochargers.
    http://youtu.be/qMJ1Fl1B77E
    Ceratec
    CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil.
    http://youtu.be/xXvZByUPpEo
    Engine Flush
    Injection Cleaner
    Cleans contaminated petrol injection systems, removes carbon,deposits and deposits from fuel pipes, fuel distributors, injection,and inlet valves -- therefore: ˜ No starting problems and no lean,surging ˜ Smother idling, good throttle response ˜ Low-pollution,,environmentally compatible combustion. Promotes accurate injector
    dosing and fuel atomisation: ˜ Your engine regains its original performance,˜ Fuel consumption is reduced. Especially suitable for,engines with catalytic converters.
    http://youtu.be/5m4K9I976Jw
    Valve Cleaner
    Engines are subjected to extreme loads even under normal driving conditions such as town and commuter traffic, short journeys and traffic jams. This sort of use causes the build-up of deposits on valves, in the combustion chamber and in the carburettor. Valve Clean cleans valves, injection systems, intakes, carburettors and combustion chambers and keeps them clean. Clean engines save fuel. Promotes optimum engine performance and fuel utilisation. The combustion produces a lower level of pollutants and the engine is spared. Protects against corrosion and carburettor icing. Tried and tested in turbo-chargers and catalytic converters.
    http://youtu.be/ulxiY6o0J8E
    Diesel Purge
    Diesel Purge removes deposits from injectors and the pistons/combustion chamber. Eliminates engine-running problems. No more knocking under partial load -- smoother idling and softer engine running. Cleaner injectors produce optimum engine running. Cleans the whole fuel system. Protects against corrosion. Guarantees good combustion, increased economy and operational
    reliability.
    Jangan ragu untuk memakai LIQUI MOLY, ini produk andalan dunia. Dan rasakan teknologi oli jerman di mobil anda. Menerima pembelian grosir ( minimal 5 dus) utk Jakarta & luar daerah
    kontak langsung saja davin 081287678888/081932574323
    Racechip Indonesia / Elika Automotive Performance / Simota Racing Sport/ EP Tune
    Bursa Otomotif Sunter Blok E no 10, Jalan Yos Sudarso, kavling 87-88 Jakarta Utara 14230
    Upppppppppp
    bantu up suhu
    4 Mths 1 Wk 5 Days 3 Hrs 5 Mins 40 Secs
    Ep Tune Remapping Ecu by tuner Davin.
    Sekarang sudah bisa dilakukan mobil Eropah maupun mobil Jepang .
    Silahkan layangkan pertanyaan tentang Remapping Ecu.
    Hub Davin hp, 0811188620
    Simota Racing Sport / Elika Automotive Performance
    Jalan Taman Sari raya, komplek ruko 56 blok B no 97 CP=081932574323 / 081287678888 (Davin) ; 0811188620 (Tony)
GT Radial Venom 300x250
  1. SALE!! All LIQUI MOLY Products
    By std aja de in forum Oil & Fluids
    Last Post: 6th February 2014, 09:29
  2. Replies: 50
    Last Post: 21st January 2014, 12:21
