Pivot Illumi Starter
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/37666
    Bandung - West java
    2 Hrs 39 Mins 6 Secs
    Change your starter switch to a push button type like those used in racecars.
    Illumination Lamp emits highly luminous LED.
    Switch Just open a φ22mm hole for easy installation.
    Easy-to-Install Easy-to-install harness for turbo timers complete with couplers connected (possible to wire directly)
    Can be used Possible to use together with remote control starter and / or turbo timer.
    ·High-capacity 30A relay for starter.
    http://pivotjp.com/product/frame-isk-e.html
    made in japan
    harga : Rp 850.000:
    Status : On stock
    Indonesia
    3 Days 9 Hrs 29 Mins 24 Secs
    bro itu cocok untuk semua mobil ???.
    terus kabel2nya gimana apa cuma jual tombolnya doang ?.
    Bandung - West java
    Quote Originally Posted by avg2004 View Post
    Dapet komplit ama kabel dll,tinggal masang aja.
    Driver Seat
    1 Day 16 Hrs 3 Mins 27 Secs
    Bos..
    mau numpang tanya kalo engine starter itu lampunya putus, bisa ganti bohlam nya aja ato haruss ganti baru semuannya yah?
    N.E.V.E.R. regret anything that once made you S.M.I.L.E.
    Bandung - West java
    Quote Originally Posted by intake View Post
    Bos..
    Selama ini belum pernah ada yg putus lampunya.
    Mungkin bisa kali yah dibuka.
    ...Behind The Steering Wheel Of An Amazing Car...
    3 Days 2 Hrs 22 Mins 36 Secs
    bos mau nanya...gw gak ngerti mekanismenya kalo sebenernya tuh mobil pake kunci trus kita pasangin engine starter gt... jadi kuncinya harus tetep nyolok n di posisi idle? trus bisa dual gak (maksudnya pake kunci bisa, pake engine starter bisa)?
    thx bos
    --It's Not What You DO, But Who You're Doing It With...
    SO..
    Its Not What You Ride, But Who Are You.. Who's Riding It--
    Bandung - West java
    Quote Originally Posted by -THA- View Post
    thx bos
    bisa..2 2nya berfungsi.
    bandung
    2 Hrs 41 Mins 35 Secs
    masang ginian riweuh teu bos?? ieu urg gayuz haha
    Bandung - West java
    Quote Originally Posted by huhuy View Post
    wakakaka,teu riweuh boss kecuali masang sorangan jigana lieur...hehehehe..
    4 Hrs 13 Mins 26 Secs
    bos punya yang model lama yang ga pakai lampu ?
    baru ok... 2nd ok...
    gue cari yang ga pakai lampu ...
    Thanx
  1. FS: 2nd Pivot Engine Start (Red illumi) Original + JAW Mini Shift Light for MT
    By rizqrizaldy in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 14th March 2012, 20:05
  2. -STREET-ENGINE START PIVOT ILLUMI &TURBO TINER HKS TYPE 0.
    By Alwi jaya in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 24th July 2009, 00:23
  3. [ASK] Pivot Engine Starter
    By Oceana in forum Diskusi Aksesoris
    Last Post: 7th January 2009, 21:24
  4. WTA engine starter pivot
    By Lucifer9 in forum Diskusi Aksesoris
    Last Post: 15th July 2007, 20:00
