NGK Power cables
Page 1 of 36 12345 ... LastLast
Results 1 to 10 of 360
  • Short URL:  http://modifika.si/37599
    Bandung - West java
    2 Hrs 39 Mins 6 Secs
    Thumbs up NGK Power cables
    The best cable you can get.
    NGK's Power Cable is a performance spark plug cable designed with ultra-low resistance (0.9kW/m). The ultra-low resistance reduces spark energy loss, thereby improving acceleration, delivering smoother idling, and burning fuel cleaner. NGK's patented hyper silicon jacket minimizes voltage leakage, is resistant to heat and chemical corrosion, and it is reliable under extreme conditions. It's the hyper silicon jacket and the ultra-low resistance that allows NGK to maintain the factory diameter wires and provide the performance you crave.
    * Ultra Low Resistance Reduces Spark Energy Loss
    * Improves Acceleration
    * Delivers Smooth Idling
    * Improves Fuel Efficiency
    30% improvement in sparking energy
    A stronger spark improves the engine's performance.
    NGK Power Cables with variable pitch winding provide a better spark than standard wires with no compromise to noise suppression.
    NGK ultra-low resistance cables with hyper silicone jacketing reduce resistance to improve energy flow and limit electro-magnetic interference. Sparking energy is improved 30% over standard wires.
    Made in Japan.
    Harga : Rp 750.000; - 1.000.000;
    Status on stock.
    Available for : Genio,estillo,ferio,cielo,great corolla,aerio,swift,kijang 2000cc,lancer,familia,timor dll..
    kl pake kabel busi ini kudu pake koil racing juga ga?
    Bandung - West java
    Thumbs up
    Quote Originally Posted by F1z-eeR View Post
    kalo ganti lebih bagus.
    Ga ganti juga ga masalah.
    udah pake ini pasti deh ga akan nyari2 kabel busi lagi..
    Mister, ada cable busi NGK part no. 08S? Tks.
    Bandung - West java
    Quote Originally Posted by unu3x View Post
    Ga punya,08S mobil suzuki apa yah?bisa pesen 2 ampe 3 bln.
    BOGOR-JAKARTA
    1 Day 2 Hrs 2 Mins 4 Secs
    ask
    ada gak NGK power cable bwat 3SGTE??brapa?thnx
    Quote Originally Posted by ss View Post
    Itu khusus untuk Suzuki Swift, yang sekarang ada di pasaran tidak ada dudukannya, padahal 1 kabel yang panjang ada dudukannya. Gitu mister.
    Bandung - West java
    suzuki swift 33s selama ini ga masalah kita pake ampe balap aja make kok..
    3 Days 5 Hrs 5 Mins 40 Secs
    nanya dunk kalo buat yaris ada ndak?? trus koilnya pake apa yah?? thx..
    sukaluyu
    39 Mins 25 Secs
    klo ama magnacore bagus mana yah?
  1. ((((((.......Cables.......))))))
    By MR.GASOLINE in forum Cables & Interconnects
    Last Post: 11th March 2011, 04:41
  2. hi end cables ----- Booked ------
    By ultrapath in forum Bursa Audio Lainnya
    Last Post: 13th October 2009, 14:22
  3. hi end cables 2
    Last Post: 13th October 2009, 14:21
  4. Kimber Kable PK-10 power cables
    By vortechvr6 in forum Bursa Audio Lainnya
    Last Post: 4th August 2009, 12:43
  5. cables?
    By swiftest_thing in forum Diskusi Audio Lainnya
    Last Post: 7th May 2009, 02:26
