Blitz R-Vit i-colour.
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/37592
    Bandung - West java
    2 Hrs 39 Mins 6 Secs
    R-VIT i-Color is a monitoring multi meter designed for 2003 or later Toyota CAN-bus or vehicles equipped with 1996 or later ISO14230 diagnostics connector. Installation is simple, it is install just by connecting to the vehicle diagnostics coupler. It features a 65,000 Color LCD screen and multi angle display. It can be set on three different angles depending on the location of the installation. R-VIT i-Color monitors a maximum of 29 items and able to display 6 monitored items simultaneously. Monitored items are: Speed, RPM, Water Temp, Ignition Timing, Fuel Injection Time, Air Flow Voltage, Outside Temp, Intake Manifold Pressure, Boost, O2 Voltage, O2 Rear Voltage, AF 1, AF 2, Intake Air Mass , Battery Voltage, Throttle Output, AT Temp, Gear Position, 4WD Ratio, Fuel Pressure, Momentarily Fuel Consumption, Malfunction Diagnosis Code, Lock Up ON ・ OFF, External Voltage Input (Press, A/F Box) / External Temp Input, Fuel Pressure Control, Fuel Injection Control / Electric Fan Control, etc. Depending on the vehicle, the monitored items vary or cannot be monitored.
    Made in Japan.
    Harga : Rp 3.900.000;
    Status : on stock.
    Dynomachine
    4 Days 19 Hrs 36 Mins 41 Secs
    kalo ke mobil honda juga bisa gak kang rony ?? buat jazz gw kituh , itungan mending beli ini apa yah dari pada indikator banyak2 ?
    Bandung - West java
    Quote Originally Posted by mile morrison View Post
    ini bisa buat jazz baca water temp,rpm,speed,ama kalo ada fault ecu nya krn dia connect ke OBD.kalo utk jazz.
    tergantung kamu perlunya.
    ini juga bagus menurut saya sih lrb murah lagi http://modifikasi.com/showthread.php?t=37678
    SS Performance Shop
    Jl. W.R Supratman no.40.bandung.
    Ph : 022-7278335,022-7278337
    Email : ronny@ssperformanceshop.com.
    dEpoK-kemang-pp
    4 Hrs 31 Mins 30 Secs
    Boss,
    Kalo dipasang ke Yaris, plug n play - kah?
    Udah coba, belun?
    om, r vit ds data link station japanese vehicle tuk subaru forester 2.0 matic ada om, harga ????
    9 Mins 21 Secs
    Om,utk baca ini semua : Speed, RPM, Water Temp, Ignition Timing, Fuel Injection Time, Air Flow Voltage, Outside Temp, Intake Manifold Pressure, Boost, O2 Voltage, O2 Rear Voltage, AF 1, AF 2, Intake Air Mass , Battery Voltage, Throttle Output, AT Temp, Gear Position, 4WD Ratio, Fuel Pressure, Momentarily Fuel Consumption, Malfunction Diagnosis Code, Lock Up ON ・ OFF, External Voltage Input (Press, A/F Box) / External Temp Input, Fuel Pressure Control, Fuel Injection Control / Electric Fan Control, etc.
    Itu perlu beli sensor2 lg atau lgsung keluar semua menu itu?
    Harga itu td include pasang kan ya?
GT Radial
  1. WTB: rays f1 R16 red colour..
    By ivanutama in forum 16 Inci
    Last Post: 6th August 2012, 21:29
  2. WTS D1 SPEC LUG NUT - TITANIUM COLOUR
    By smoor in forum Bursa Kaki Lainnya
    Last Post: 5th October 2011, 16:18
  3. (WTB) Want To Buy : RECARO SR3 (RED colour) or SPARCO torino (RED colour) !!!!!!!!
    By Bogel369 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 13th August 2011, 16:44
  4. BMW 630i EXOTIC COLOUR THE 1 ONLY!!!
    By paulus prospect in forum BMW
    Last Post: 5th August 2010, 13:24
  5. WTS: bmw Z4 2.3 2010 white colour
    By |-MhZ-| in forum Merk Lainnya
    Last Post: 5th July 2010, 12:11
