B&M SuperCooler for Automatic Transmission (ATF Cooler)
Results 1 to 10 of 37
  • Short URL:  http://modifika.si/372885
    1 Wk 3 Days 2 Hrs 57 Mins 2 Secs
    Lightbulb B&M SuperCooler for Automatic Transmission (ATF Cooler)
    B&M ATF COOLER
    B&M SuperCoolers are 100% aluminum construction and use stamped plates sandwiched together to create one of the most efficient oil cooling devices available. Not only does this unique design provide for maximized cooling through more efficient heat dissipation but it also provides a much sturdier cooler which is practically impervious to flying rocks or other debris. The Super-Coolers intended for automatic transmission fluid also offer an additional feature known as “Low Pressure Drop”. The coolers assembled with hose barb ends include a unique bypass feature allowing a controlled amount of ATF to bypass the stacked plate core when the fluid is cold. This is beneficial in cold climate areas to guard against lube system failure. Controlled by viscosity, fluid is returned directly to the lube circuit through bypass openings in the stacked plate core. As the temperature increases, more ATF is directed through the core. This highly efficient design combines improved protection against lube system failure with the required levels of optimal heat transfer.
    Automatic Transmission Super Cooler - 14,400 BTU
    Cooler Size : 28cm x 15cm x 3.8cm (Panjang x Tinggi x Tebal)
    Installation Kit Included : Yes
    Application :
    1500cc-2000cc Engine (Light to Medium Modified)
    Features:
    - Stacked Plate design
    - Low Pressure Drop’ feature
    - All aluminum construction
    - Oven brazed construction
    - Small & efficient design
    - Includes installation kit
    - 3/4” thin line coolers are ideal for tight fit locations
    - 3/8” extended nipple fittings providing improved hose & clamp contact
    Racing Transmission Cooler - 20,500 BTU
    Cooler Size : 28cm x 20.3cm x 3.8cm (Panjang x Tinggi x Tebal)
    Inlet Size : 1/2 Inch NPT Inlet/Outlet
    Installation Kit Included : No
    Application :
    1500cc-2000cc Engine (Medium Modified)
    2000cc-3000cc Engine (Light to Medium Modified)
    Features:
    - 1/2" NPT Inlet/Outlet
    Hi-Tek Automatic Transmission Cooling System with 7 Inch Fan
    Cooler Size : 25cm x 19.5cm x 3.8cm (Panjang x Tinggi x Tebal)
    Number of Row : 12 Row
    Fan Size : 7 Inch
    Fan Speed : 350 CFM
    Application :
    1500cc-2000cc Engine (Heavy Modified)
    2000cc-3000cc Engine (Medium Modified)
    Fitted with a high-quality 12V SPAL electric fan, Hi-Tek Trans Coolers can handle the coolest cooling jobs.
    A thermal switch activates the fan when the fluid temp reaches 80° Celsius. Suitable for racing, street performance, and RVs.
    Hi-Tek Automatic Transmission Cooling System with 9.5 Inch Fan
    Fan Size : 9.5 Inch
    Fan Speed : 500 CFM
    Application :
    2000cc-3000cc Engine (Medium to Heavy Modified)
    Further info, please contact :
    Coki Siboro
    de Auto Motorsport
    0815 1330 1978
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Jakarta - Swift Club Indonesia -
    2 Mths 1 Wk 2 Days 9 Hrs 6 Mins 49 Secs
    Boss coki, yg automatic super cooler 14.400 btu harganya berapa? Thanks..
    Quote Originally Posted by fonzie View Post
    enakan langsung kontak ke hp saya aja bos untuk informasi harga nya.. tp sori, udah habis tuh stock nya.
    ini lagi mau repeat order.
    CP : Coki Siboro
    Bogor-Jakar
    1 Wk 3 Days 12 Hrs 43 Mins 21 Secs
    bisa buat cooler oli mesin gak?
    td gw tlp k bengkel katanya cuma ready yg relocated filter ya?
    yg biasa" aja ada gak
    yg ready stock yg mana? pm yak..
    Quote Originally Posted by [Ctrl]+[Alt]+[Del] View Post
    beda bos cooler yg buat oli mesin sama transmisi...
    kalo stock oil cooler yg ada di bengkel sekarang tinggal yang relocate kit aja.
    CP : Coki Siboro
    Cilandak, Jakarta Selatan
    2 Days 12 Hrs 16 Mins 54 Secs
    Boss, yang 20.500 BTU dan yang hitek fan 7' harganya berapa ya? Bisa dipasang di innova D4D?
    Thx
    1 Mth 2 Wks 14 Hrs 19 Mins 13 Secs
    Om coki...kl yaris at medium modified, pake yg 14.400 atau 20.500 btu ??
    Lebih bagus mana sama hayden ??
    Sekalian pm-in harganya, thx
    Bandar Lampung
    11 Hrs 35 Mins 20 Secs
    itu kipas dan motornya yah? ada buat nissan teana?
    Quote Originally Posted by vigoderoza View Post
    Thx
    yg 20.500btu bisa, kalo yang hi tek with 7inch fan tergantung torsi bos udah berapa.. tp dua2nya lagi kosong sih stock nya sampe akhir januari. tq
    CP : Coki Siboro
    Quote Originally Posted by GOLIATH'S View Post
    pake yang 14.400 cukup bos, tp yang b&m lagi kosong sih stock nya sampe akhir januari.
    tq
    CP : Coki Siboro
Mega Glodok Kemayoran GT Radial
  1. RR - JASMA // Transmission SuperCooler - Big
    By RacingRepublic in forum Jual Beli Mesin Lainnya
    Last Post: 1st March 2013, 15:06
  2. [ W T S ] Automatic Oil Transmission Cooler
    By Jagong in forum Jual Beli Mesin Lainnya
    Last Post: 28th September 2010, 23:16
  3. WTB: transmission cooler, per CVT, plat kopling racing...
    By B3mo in forum Jual Beli Mesin Lainnya
    Last Post: 26th December 2008, 22:33
  4. SOLD... WTS Oil Cooer or Transmission Cooler WITH fan
    By retilo93 in forum Jual Beli Mesin Lainnya
    Last Post: 7th July 2008, 21:30
