B Series performance
Page 1 of 18 12345 ... LastLast
Results 1 to 10 of 179
  • Short URL:  http://modifika.si/37210
    spesifikasi dari mesin-mesin B series....
    B16
    B16A
    Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
    • VTEC
    • Found in:
      • 1989-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
      • 1989-1991 JDM Honda CRX SiR (EF8)
      • 1989-1991 JDM Honda Civic SiR (EF9)
        • Displacement: 1595 cc
        • Compression: 10.2:1
        • Rod/stroke ratio: 1.74
        • Power: 158 hp (118 kW) @ 7600 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
        • Transmission: S1/J1/Y1/YS1
      • 1992-1995 JDM Honda Civic SiRII (EG6/EG9)
        • Compression: 10.4:1
        • Power: 170 hp (130 kW) @ 7800 rpm & 113 ft·lbf (153 N·m) @ 7300 rpm
        • Transmission: S4C (Some with LSD)
      • 1992-1996 JDM Honda CR-X del Sol SiR
        • Power: 158 hp (118 kW) - 167 hp & 111 ft·lbf (150 N·m) - 113 ft·lbf
    B16A1
    • VTEC
    • Found in:
      • 1990-1991 EDM Honda CRX 1.6i-VT (EE8)
      • 1990-1991 EDM Honda Civic 1.6i-VT (EE9)
        • Bore×Stroke: 81.0×77.4 mm / 3.19×3.05 in
        • Power: 150 hp (110 kW) @ 7600 rpm
        • Torque: 111 ft·lbf (150 N·m) @ 7000 rpm
        • Redline: 8200rpm
        • Transmission: Y2
    B16A2
    • VTEC
      • 1992-2000 Honda Civic EDM VTi (EG & EK)
        • Power: 160 hp @ 7,600 rpm & 118 ft·lbf (151 N·m) @ 2500 rpm
        • Transmission: Y21
      • 1999-2000 Honda Civic Si (EM1)
        • Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
        • Transmission: Y21 S4C
        • Bore: 92mm
        • Stroke: 77.4mm
      • 1996-1997 Honda Del Sol VTEC (EG)
        • Power: 160 hp (118kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
        • Transmission: Y21
    B16A3
    • VTEC
    • Found in:
      • 1994-1995 Del Sol VTEC
        • Displacement 1595 cc
        • Transmission: Y21
    B16A4
    • VTEC
    • Found in:
      • 1996-2000 Honda Civic SiRII (Asian version) (EK)
        • Power: 170 hp (127kW) @ 7800 rpm
        • Transmission: Y21
    B16A6
    • VTEC
    • Found in:
      • 1996-2000 Honda Civic - South Africa VTEC (EK)
        • Power: 158 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
        • Transmission: S4C
    B16B (Type R)
    • VTEC
    • Found in:
      • 1997-2000 Civic Type R[EK9]
        • Compression: 10.8:1
        • Bore: 81mm
        • Stroke: 77.4mm
        • Rod/Stroke ratio: 1.84:1
        • Rod Length: 142.42 mm (5.607")
        • Power: 185 hp (137 kW) @ 8200 rpm & 118 ft·lbf (160 N·m) @ 7500 rpm
        • Redline: 9000 rpm
        • Transmission: S4C With LSD
        • 0-60 High 5's
        • 185 BHP
          • Note: This engine uses the same block as the Integra Type R, which is taller than the B16a block, but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard b16. \
    >>>untuk spec mesin B17 ampe B20 liat page 2
    >>>spesifikasi dr transmisi2 B series liat page 2
    >>>kode-kode ECU honda liat page 3
    >>>JDM B series piston line up page 6
    disini gak cukup nich...
    bos ted.. bisa kasi saran buat B series engine ini...
    mulai dr stock engine diapain aja enaknya..
    ampe stage 2, stage 3 dst..
    mulai dr B16 yach..
    heheheh...
    temen2 yg laen share jg ya disini...
    sengaja gw bikin thread ini..soalnya di atas udah ada D series performance
    tapi thread B series lum ada..
    klo repost ato ga penting delete aja gpp hehehe...
    klo penting sekalian di sticky aja hehehe...
    thanks....
    kota yang penuh KKN
    2 Wks 6 Days 8 Hrs 22 Mins 52 Secs
    dikibin2 aja berttt??????hahaahah....
    Dket jalan yg panjang banget itu...
    3 Wks 30 Mins 23 Secs
    Hahhaha....
    MEnding lo beli cam gua bert jd naek stage dah tuu... hahhaa
    ATo ga
    BEli mesin gua naek stage lg d.. hehhe
    B1008 ZW, Ferio'00
    Si kuning EG
    @stan'z >> hahahah....dikibin mang kudu neh..
    @ichikers>> dapet cicilan "nol"persen nga...??
    akakakakkak j/k
    dpt donkz cicilan tp tergantung proposal
    hahahhaha
    B1008 ZW, Ferio'00
    Si kuning EG
    akakakakkakak....
    lu kapan pulang.. esti kuning dah nunggu tuh..
    hehehe..
    kota yang penuh KKN
    katanya lu mau test lagi bert???
    bruan sebelom orgnya balik tuh! hahahahaa
    bwakakakakakka...
    6 Hrs 11 Mins 41 Secs
    Sudah kebawa mimpi ya Bert...
    Aerio_Standard
    scrwd up city JKT
    5 Hrs 29 Mins 53 Secs
    paling sakti B series itu tinggal di Bore-up & Stroke-up jadi B-29!
    digosok terus pake sabun colek ampe melar tuh jeroan!
MBtech Venom 300x250
  1. Replies: 8
    Last Post: 18th May 2012, 11:32
  2. FS : Performance parts for D series
    By pegasus in forum Jual Beli Mesin Lainnya
    Last Post: 6th April 2011, 09:03
  3. B series performance part
    By Turbin_asoy in forum Jual Beli Mesin Lainnya
    Last Post: 8th March 2011, 10:23
  4. Wts: Midbass DLS - K6, Performance Series
    By Fiqi in forum Speaker - SubWoofer
    Last Post: 14th January 2011, 06:36
