Simota Big Brake Kit !!
Results 1 to 10 of 30
  • Short URL:  http://modifika.si/368819
    1 Wk 3 Days 12 Hrs 46 Mins 44 Secs
    SIMOTA big brake kit 4 Pot
    -Caliper 365 casted aluminum alloy with 4 layers of nanometer resembled and anti high temperature special coating
    -Brake pad sport: , temperature range :50-650 degree C
    -Adaptor: hi temperature electro plated surface treatment and can resist acid. Also the product is durable enough to sustain vibration of braking
    -Rotor: Specially heat treatment , working temperature up to 900 degree C , with anticorrosion paint, and the design helps to remove dust from the brake surface
    -Stainless steel brake hose: Strong teflon tube wrapped by double later stainless mesh. The pressure testing result can reach over 3000 PSI
    Ready stock for
    Honda all new jazz ge8/freed/honda all new city 2011
    Simota Big brake kit 330 mm bolt on for honda civic FD1/FD2
    [SIZE=5]
    Buat yang mau pesan bisa lihat application list nya bisa buka dsini ==> http://www.simota.com/productsinfo.php?ID=82
    Racechip Indonesia / Elika Automotive Performance / Simota Racing Sport/ EP Tune
    Bursa Otomotif Sunter Blok E no 10, Jalan Yos Sudarso, kavling 87-88 Jakarta Utara 14230
    upppppppppppuppppppppppppp
    1 Wk 3 Days 14 Hrs 25 Mins 28 Secs
    Wah boleh dipmin nih bro buat ge8
    Quote Originally Posted by jaehanputra View Post
    Check pm ya bro
    Jakarta- Western Australia
    2 Wks 3 Hrs 17 Mins 37 Secs
    PM buat mazda 2 dong thanks
    1 Wk 16 Hrs 9 Mins 39 Secs
    mantap nih emang simota, udah keluarin rem nya jg, mantap
    Quote Originally Posted by CerberusGA View Post
    saya sudah PM yah..
    Quote Originally Posted by rsukuandi View Post
    thanks ko rudy... bantu bantu rekomenin ke tmen dong..hehehe
    Nahh,, ini dia mobil all new jazz customer kita (mr Andy H) all new jazz GE8 yang memasang Big brake kit Simota di mobilnya
    Mobil udah kencang, kalo gak didukung dengan pengereman yang maksimal, tentunya safety nya kurang dong
    Hasilnya: pengereman jauh lebih pakem, safety jauh lebih tinggi, dan juga gaya lebih keren pastinya dongg.. Big brake kit gitu lohhh
    Depok, west java
    1 Day 29 Mins 13 Secs
    boss PM in dong harganya..buat civic ferio 96 bisa gak yaa ?
    Quote Originally Posted by R4C1NG_REPUBLIC View Post
    bisa,, tapi mesti inden ya .. dan mau yang brp mm piringan rem nya
  1. Replies: 7
    Last Post: 25th July 2011, 11:40
  2. [WTA]POWER BRAKE AUXILIARY SIMOTA
    By cyvermont in forum Simota Racing Sports
    Last Post: 19th February 2011, 12:15
  3. Replies: 2
    Last Post: 26th September 2010, 00:49
  4. Replies: 0
    Last Post: 13th July 2010, 06:03
  5. Replies: 21
    Last Post: 9th September 2009, 01:25
