[Futoshi] Sunpro Tachometer 5"
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/36314
    Kondisi 99% - Ex Display
    Harga : Rp. 1.500.000 Hub 081908224488 (sms) 08561511551 (telp)
    * Slim-line design installs in tight cockpits
    * Rugged all-metal construction
    * Vibration-proof air core meter movement
    * Adjustable Shift/Max. RPM point
    * 360-degree backlighting
    * 0-10,000 RPM range
    * Switch-selectable for 2, 3, 4, 5, 6, 8 & 10 cylinder engines
    * Compatible with most automotive ignition systems including standard,
    electronic, DIS and most aftermarket systems
    * Includes installation kit and detailed illustrated instructions.
    * Also available in white face
    * Made in U.S.A.
    Harga : Rp. 1.750.000 Hub 081908224488 (sms) 08561511551 (telp)
    Soft spoken, even-tempered distinction and a geometric sense of style perfectly describe the Sunpro® 5´´ Sport ST Tach. The subtle metallic body and smooth finish of the bezel is like no other tach on the market. Unique styling gives the Sport ST its own sense of timelessness that compliment anycar’s interior.
    # Large 5´´ dial face
    # 0 to 10,000 RPM range
    # Vibration proof, air core meter design
    # Internal settings for 2, 4, 6 and 8 cylinder engines
    # Pointer return-to-zero feature
    # Large, easy to see amber shift light
    Benefits
    # Incandescent back lighting avoids uneven, hot spots for better night visibility
    # Modern DIS ignition applications are covered by 2 cylinder setting
    # Shift light can be repositioned around tachometer body for best viewing angle
    # Highly visible bright red pointer for quick view
    Harga : Rp. 1.950.000 Hub 081908224488 (sms) 08561511551 (telp)
    The Super Tach III represents a dynamic transition – classic design interpreted through modern aesthetics. Sheathed in a solid metal casing decked with a striking reflective chrome finish, the Super Tach III is adorned with aerodynamic Louvers that accentuate its streamline styling. Perched atop is a prominent blue shift light that complements the tach’s retro, two-tone dial face graphics. Most important, the Super Tach III is fast, accurate and reliable, thanks to vibration proof air-core meter construction.
    Features
    # Vibration proof air core meter design
    # Adjustable swivel mounting foot for mounting at any angle
    Benefits
    # Modern DIS ignition applications are covered by the 2 cylinder setting
    Regards,
    Futoshi Staff
    up, update !!
    Jakarta...
    2 Wks 3 Days 11 Hrs 21 Mins 50 Secs
    Bantu up buat barang bagus bos..
    bandung
    bantu up jg
    lucu modelnya uy
    Talking
    Bantu UP dech barang yahudd nich
    Tq all diantu up...
    cair lagi..alhamdulilah :D
    2 Wks 3 Days 37 Mins
    harga nego ga?
    FLOW AUTO
    4 Days 14 Hrs 28 Mins 53 Secs
    Sms ke no diatas aja bos lsg, Thx
    www.rocksvapor.com
    Vaporizer stockist , reseller are welcome
    Dki jakarta - Kelapa Gading
    37 Mins 47 Secs
    harga brnya brp boz?
    Sunpro Tachometer 5" nya kena berapa nett nya..?
  1. wts injector 400cc precision high impedance+indikator sunpro boost&afr
    By sandi_speed in forum Jual Beli Mesin Lainnya
    Last Post: 15th December 2011, 06:27
  2. [Futoshi] Supercharger Vortech
    By Lodi_Limantoro in forum Jual Beli Mesin Lainnya
    Last Post: 4th October 2010, 01:36
  3. TACHOMETER SUNPRO 5"
    By camira in forum Diskusi Interior
    Last Post: 23rd March 2009, 17:36
  4. TACHOMETER SUNPRO 5"!!---sold out
    By camira in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 21st August 2008, 00:16
