Silikon Motorsport
Sun Air
Tritala Hasta Banner Available 242x90
Results 1 to 5 of 5
    Colonel
    2 Wks 14 Hrs 40 Mins 9 Secs
    Thumbs up Audison LRx 1.400 900 watts MonoBlock Amplifier kondisi muluus......
    Audison LRx 1.400 900 watts MonoBlock Amplifier kondisi muluus............
    Designed to drive very low loads
    RMS Power Ratings:
    350 watts x 1 @ 4 Ohms
    650 watts x 1 @ 2 Ohms
    900 watts x 1 @ 1 Ohm
    Limit Led: Overload Protection Circuit Indicator
    On/Off Led
    Safety Led
    Subsonic Bypass
    Output level adjustment
    Phase inverter (0°-180°)
    F1Q: Lo-Pass filter Q factor adjustment
    Built-in Crossovers: HPF(40 - 500Hz), LPF(40 - 500Hz)
    Subsonic Filter: Pre-set @ 20 Hz, Adjustable from 16 - 32Hz by replacing special resistors
    1 Pair RCA Outputs: Hi-Pass or Bypass
    Optional Bass Remote Modules Available Seperatley
    Dimensions: 370mm L x 176mm W x 56mm H
    GASOLINE AUDIO STATION
    Mega Glodok Kemayoran Lantai 6 Blok F1 no.6
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    email : gasoline.audiostation@gmail.com
    Gasoline Audio Station link :
    http://www.modifikasi.com/forumdispl...on-Represented
    Corporal
    1 Wk 5 Hrs 26 Mins
    Pm harga nettnya boss?
    Colonel
    pm sent bosss,thanks..
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    First Sergeant
    Parij Van Java
    1 Wk 5 Days 11 Hrs 49 Mins 7 Secs
    Ini masih ada boss? Brp boss?
    Colonel
    Masih boss danny,pm sent bosss,thanks.
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
Ziebart Indonesia Rajawali Autogallery Otostereo
  1. Replies: 11
    Last Post: 29th November 2009, 20:21
  2. Replies: 142
    Last Post: 20th November 2009, 02:26
  3. hi-end diamond d7 402 amplifier kondisi muluus..........
    By GASOLINE in forum Power Amplifier
    Last Post: 2nd June 2009, 05:54
  4. audison vr 203 kondisi muluus n no service..............
    Last Post: 2nd June 2009, 05:41
Velgvelg Rajawali Autogallery
