Dijual titipan teman yg sudah bosen main karaoke
ampli karaoke Rp 1.750.000, bekas
MARTIN ROLAND MA-3000K II
600 watts professional digital mixing amplifier
Specifications:
Audio Output: 300W + 300W Output @ 8 Ohm
Microphone input sensitivity: < 15mV
Frequency Band: 25Hz to 20kHz
Dimension: 420mm(W) x 129mm(H) x 330mm(D)
Key Control with remote controller
Two Channels of audio select
Two Channels of Video select
Electricity consumption: 550W
Ultra Quiet Cooling Fan
Designed in Germany
Weight: Net weight 40 lbs
Microphones
3 x 1 / 4 inch Microphone Inputs
Input Signal Attenuators
Auto-gain level indicators
Individual Microphone Volume Control
Individual Balance Control
Individual Echo Depth Control
Individual Bass / Mid-range / Treble Volume Control
Volume Control
Microphone Master Volume Control
Music Master Volume Control
Echo Control
Depth control
Bass control
Treble control
Repeat control
Delay time control
Music Control
A/B Input Selector from 2 Audio Sources
Balance control
Bass / Mid / Treble control
11 Step Digital Key Control
2 Music Mode: Disco or Karaoke
Full Function Remote Control
Key Control: Normal, Low, High
Input Selector : 2 channels for audio, 2 channels for video
Master Music Volume Control
equalizer Rp 750.000, bekas
BMB EQ 80
10 Channel Natural Sound Graphic Equalizer
Channel graphic: 2 x 10 band graphic equalizer. Sensitivity: 200mV. Impedance: 47 k Ohm. Signal noise: >80dB. Frequency: 20Hz-20Khz (+-1,5dB). Power consumption: 220VAC/50Hz, 10 watts. Demensions (WxHxD): 435 x 95 x 235mm. Weight: 2,5kg
Yg gak nawar free Mic kabel BETA-58 (baru), mix yg cukup peka cocok untuk sistem home karaoke yg mau bagus tapi budget terbatas
Minat silahkan datang Liat & Test puas sepuas2nya , janjian di 08567088599 Jakarta
mengenai harga / spek silahkan google langsung ya...
http://www.kaskus.co.id/showthread.php?t=14159187
http://www.atechglobal.com/mixingamplifier.html
http://www.startekkomputer.com/index...mart&Itemid=53
