JACOBSON ACCUVOLT FR1500 - VOLTAGE MANTENG 14.4V!!!
Page 1 of 17 12345 ... LastLast
Results 1 to 10 of 161
  • Short URL:  http://modifika.si/35394
    Grand Central West Side
    6 Days 23 Hrs 47 Secs
    What is Accuvolt and why do I need it?
    Not to be confused with a passive capacitor or simple filter, ACCUVOLT is an active "step up" voltage regulator that can actually put out higher than input voltage. It takes in the lower, noisy, unregulated vehicle voltage, computer-processes it, and puts out perfectly flat, higher, spike-free voltage (user-adjustable 13.5 to 16.25 volts) that powers your audio system, performance-related components or computer navigation system with the purest, absolutely flat (+/- 0.01) voltage, even when your battery is down to 9.5 volts! This smooth, rock steady voltage unleashes your audio amplifier or radio transmitter's full potential. All noisy voltage from the vehicle's electrical system is actively stepped up and filtered at 60,000 corrections per second. The resulting sound improvement is awesome!
    ACCUVOLT'S FEATURES AND BENEFITS
    Unleashes the cleanest sound, purest bass and highest available volumes by keeping your amplifiers powered with rock steady optimum voltage to eliminate power line noise.
    Eliminates the spikes that damage audio and radio equipment.
    Significantly increases both range (up to 40%) and clarity of on-board radio transmitters/receivers and CBs.
    Easy to install.
    Protects against accidental voltage spikes and reverse polarity.
    A full 2.7 volt adjustment up to 16.25v.
    Provides at least a full 1db gain.
    An Annunciator functions as a diagnostic and warning centre for battery condition.
    Jantzentm - Audiencetm - Furutechtm - Gronebergtm - etc.
  2. clickbet88.com
    4 Days 9 Hrs 47 Mins 37 Secs
    u dah pake ya??
    berapa??
    beli dimana??
    nyoo_hks@yahoo.co.id
    hrga brapa boss?
    Makassar, Jakarta
    4 Days 17 Hrs 36 Mins 43 Secs
    nic, ngimpor ajah gimana?
    lewat gw deh.
    Cipete, SoutH Of JakaRtA.
    1 Day 21 Hrs 37 Mins 39 Secs
    Weleh Nic.. barang bagus gini koq dijual?? ada yg lebih mantep dr Jacobs? :smt003
    Lo jual brp duit bro?
    Upps.. gw kira lo mo jual.. heheheh.. mo masukin?
    39 Mins 26 Secs
    bli dimana pak.... , ngaruh banget ga ?
    Wah ini ngaruh bgt.. pasti maksimal audio nya kalo di 14.4v. Gw dah denger sendiri hehehehe... sayang harganya masih mahal buat gw
    Surabaya - Ambon
    1 Mth 3 Days 21 Hrs 14 Mins 37 Secs
    harga brapa duit yah.. share donk..
    kao pake ini uda ga usa pake cap bank lagi yah ?
    2 Hrs 3 Mins 12 Secs
    Re: JACOBSON ACCUVOLT FR1500 - VOLTAGE MANTENG 14.4V!!!
    Quote Originally Posted by nicric
    Easy to install.
    wah ... mantep ... cari dimana neh barang kayak begini?
    = AD MAJOREM DEI GLORIAM =
  1. batcap, capbank, accuvolt ?
    By deepdeep in forum Diskusi Audio Lainnya
    Last Post: 17th April 2014, 18:12
  2. WTA: pengaruh dari pemakaian voltage stabilizer (mis.Accuvolt,VSS)?
    By baksojoni in forum Diskusi Audio Lainnya
    Last Post: 3rd November 2008, 22:39
  3. WTA: impact lain dari pemakaian voltage stabilizer (mis.Accuvolt,VSS)?
    By baksojoni in forum Diskusi Power Amplifier
    Last Post: 29th October 2008, 03:16
  4. [WTA] Jazz rpm naek turun ga jelas (sambil manteng)
    By 999DT in forum Diskusi Mesin
    Last Post: 9th August 2008, 19:22
  5. Accuvolt
    By n0k14 in forum Diskusi Audio Lainnya
    Last Post: 26th December 2006, 18:15
