Lake Countrys CCS Dual Action Smart Pads Foam Pad !!!
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/34198
    1 Day 1 Hr 28 Mins 24 Secs
    Lake Countrys CCS OEM Foam Pad
    CCS Technology revolutionizes foam buffing pads!
    Blue Finessing Foam 6.5
    Flat pad has soft composition for applying glaze, finishing polish, sealants, and liquid waxes. Flat pad provides full contact with paint surface to minimize the pressure applied by the user.
    Gray Finishing Foam 6.5"
    Composition is firm enough to withstand added pressure during final finishing to remove buffer swirls. It has no cut and will apply thin, even coats of waxes, sealants, and glazes.
    Green Polishing/Finishing Foam 6.5"
    Use this foam to apply one-step cleaner waxes. It is a balance of polishing and finishing that is perfect for all-in-one product application.
    White Polishing Foam 6.5"
    Less dense foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so its perfect for pre-wax cleaners.
    Orange Light Cutting Foam 6.5"
    Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. Its an all around pad that will work on most light to moderate imperfections.
    Lake Countrys CCS Dual Action 6.5 inch Smart Pads Foam Pads are flat full contact buffing pads that work with your Porter Cable 7336 to correct automotive paint more easily than ever before. The CCS Smart Pads user-friendly features provide better control, less product waste, and a more successful detail.
    Lake Country has improved upon the basic pad design with CCS technology, which actually slows the rate of product absorption and saves polish. With conventional foam pads, polish is absorbed into the foam rather quickly. This reduces the working time with the polish and may give you disappointing results. A build-up of chemicals inside the foam will also cause the pad to dry out more rapidly.
    CCS stands for Collapsed Cell Structure. The face of a CCS pad is covered in strategically placed pockets. These pockets are locations where the foam cells have been closed. Polish does not absorb into these closed cell pockets, leaving more product on the pad's surface and on the paint. This polish-saving design gives polishes a longer working time, which results in more successful detailing.
    CCS Smart Pads work on every type of paint, from conventional clear coats to the harder, scratch-resistant clear coats used by Mercedes Benz and the Ford Motor Company. Lake Country's range of foam compositions, combined with the right chemicals, provides you with a prescription to correct almost any paint imperfection on any paint finish.
    What are the benefits of CCS Technology?
    #Slows rate of polish absorption As discussed above, the pads are slow to absorb products and therefore the paint benefits from a longer working time. The same is true of liquid waxes and sealants.
    #Improves operator control CCS pockets gradually release polish as needed by the operator. Since these areas are not absorbing polish, they serve as little reservoirs until the excess polish is needed.
    #Prevents pad skipping CCS pockets reduce surface tension allowing the operator to run pad flat on a working surface. Basically, the CCS pockets break up the smooth surface of the foam to eliminate the sticking and skipping that occurs when two perfectly flat surfaces meet.
    #Creates less heat CCS pockets provide several points where the foam is not completely touching the paint. This reduces friction and therefore heat generated between the pad and the paint.
    #OEM approved OEM tests confirm CCS pads out-perform convoluted pad designs.
    CCS foam pads provide ample surface contact to effectively work the paint. The CCS pockets are small so they don't affect the amount of foam continuously touching the paint during operation.
    The longer working time afforded by the CCS pads allows you to work problem areas with greater success. The pockets reduce the amount of heat created so even though you're working the paint longer, there is no additional risk to the paint.
    The CCS pockets function like many splatter pockets by reducing splatter and regulating the release of extra product, but you don't lose any contact surface.
    Each CCS pad features VELCRO brand hook and loop fasteners covering the entire back of each pad to secure to a hook and loop backing plate.
    New CCS Technology from Lake Country Mfg, Inc.
    A product from Lake Country Mfg., Inc.
    NOW AVAILABLE:
    6 1/2" Lake Country CCS Constant Pressure Pads:
    The other patented, innovation incorporated in CCS Pads are a curved outer edge. The curvature on the outer edge of the pad allows easy transitions over seams and inclines.
    Standard CCS pads are flat-cut. We pay extra to have the top edge rounded over because it prevents pads from snagging while polishing seams and edges.
    We also pay attention to the back of the pad. Standard CCS pads run the Hook and Backing material to the edge of the pad. This material is very course and can cause scratching if it hits the paint while working in tight spaces or around mirrors and wings. We cut the Velcro brand fastening material back 3/8 inch from the edge. This allows you to work right against corners, mirrors, wings and complex angles without fear of scratching the paintwork.
    White, CCS Polishing Pad - The most often used pad. This pad has a mild cutting (cleaning) action and should be used to apply light compounds, polishes and one-step, cleaner/waxes.
    Do not use the same pad for applying different products. If applying a polish and a cleaner/wax, use one pad to apply the polish and a separate pad to apply the cleaner/wax.
    Green - CCS Heavy Polishing Pad - These green pads are also the best pads for applying one-step, cleaner/sealants lbut should not be used to apply a glaze or pure paint sealant. Best Used for Optimum Polish and Optimum Poliseal
    Orange - CCS Light Cutting Pad - This German foam has 90% of the cutting power of the Yellow Compounding Pad but finishes like the White Polishing Pad. Best used for Optimum Polish and Optimum Hyper Compund
    == Interested : Please visit www.detailermart.com for further information ==
    Cawang
    2 Mins 28 Secs
    mesin sama bakingplate disediain juga dong hehe
    Setuju, BP nya disediakan juga, yg ukuran 4 inch ampe 6 inch. Pembersih Padsnya sekalian juga, tapi yang buat nyuci punya.
    ditunggu komentar dari ownernya ya... :smt003
    depan komputer
    cara nyuci padnya kepriben?
    Quote Originally Posted by h3rry
    wah orang cirebon yak? Sira tinggal pakein sunlight.
    21 Hrs 28 Mins 24 Secs
    pake sabun cuci piring (sunlight seperti kata bro gio), rendam sebentar, gosok2 terus sampai sisa deterjennya abis, keringin
    ==Is it detailing? Nope==
    9 Hrs 13 Mins 27 Secs
    gw pake sabun cuci tangan brand store nya carrefour. stlh full detailing semua pad yg dipakai gw rendam selama +/- 15 menit terus gosok2/pijat2 keluarin sisa2 polish nya. yg paling ngeselin bukan nyuci nya tapi nunggu kering nya hahahaaa :smt009 takes forever
    sejauh ini yg uda gw pake yg warna orange (dgn SIP), green (dgn nano), white (dgn SIP dan Nano), gray (dgn Nano). dalam waktu dekat mau cobain yg biru dgn nano atau final polish untuk final polishing sblm wax.
    Performance nya bagus untuk semua polish product yg gw sebut di atas dan gw tdk menemukan problem dlm memakainya. bahkan yg warna orange dgn kontur keras (beda jauh sm putih atau green). btw, blm pernah coba Megs punya. sempet mau cobain tapi kalo gak salah dneger2 dari forum luar katanya velcro suka lepas (megs gak recommend cuci dgn air). gw pikir kalo gak pake air cuci pake apa yah?..akhir ny agw drop pilihan mau pake Megs. kalo ke depan ada yg pake dan cuci dgn air baik2 aja mungkin gw pertimbangkan.
    oh iya, pads yg gw coba dgn rotary. mungkin hasil dan opinion berbeda kalo pake mesin DA.
    Orange+SIP---White+SIP---Gray+Nano---Colli 476 & 845
    Cawang
    2 Mins 28 Secs
    Quote Originally Posted by liTTleruNNer
    selama ini gue pake megs dan lc. Megs ok2 aja, tuh berkali2 dicuci, direndam dll, ngak ada masalah. Velcro lepas karena problem dipake di DA dengan speed setting diatas 5. LC pun tidak direcommend dipake di atas 5 di DA, waktu gue beli LC diwanti2 begitu sama penjualnya hehe problemnya megs lebih mahal dari LC. ya LC menawarkan value for money yang lebih baik, serta menurut gue lebih rapi aja bikinannya
    http://www.detailermart.com
    3 Days 9 Hrs 25 Mins 56 Secs
    NOW AVAILABLE:
Datsun 300x250 Venom 300x250
  1. Jual Lake Country Buffing Pad 4". 5.5". & 6.5".
    By Virginia Island in forum Produk Perawatan Mobil
    Last Post: 22nd September 2012, 07:48
  2. [WTS] Lake Country CTP buffing pad orange 5,5inch + red 4inch
    By Fatboy in forum Produk Perawatan Mobil
    Last Post: 6th June 2012, 20:25
