Engine Swap timor
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/33139
    2 Hrs 4 Mins 29 Secs
    Engine Swap timor
    SWap engine mazda MX6 ke Timor Bisa ga????
    kota mati
    9 Hrs 58 Mins 31 Secs
    Mx6 kode msinnya apa bos?
    setau gw kl lantis,fmilia,champ,laser bs lsg msuk bos..
    1 Day 4 Hrs 11 Mins 39 Secs
    MX6... Kodenya FS..
    Kagak BIsa MAsuk pake MOUNTING standar...!! harus Rubah Mounting!!>.
    Pake FS bisa di Stroke jadi 2200cc & PAke turbo dengan mudah dapet 400BHP....
    hehehe Hayo bos.. naik kelasnya.. nanti ikut kah seri I
    0812-182-862-05
    kota mati
    Mx6 efi apa karbu c?
    kl FS brarti sama ama cronos 2.0,tx5,tels briliant y bos?
    The F series engine is Mazda's big block and the B series is the small block.
    # 51 mm rod journals vs 45mm rod journals
    # 34,29mm valves vs 33,28mm valves
    # head ports approx 20-30% larger
    # 86mm bore vs 83mm bore
    # 86mm stroke vs 85mm stroke
    # physical block constraints: BP = 86mm bore and 88mm stroke, FE3 = 89mm bore and 94mm stroke
    # 22mm wrist pin vs 20 mm
    0812-182-862-05
    o iya... Lebih panjang 1" dari mesin BP..
    dan BP lebih panjang 1" daro Mesin B5 Timor..
    paling2,... Coak Chassis.. hehehehe
    coz mesin BP aja udah mepet tuuh klo gani tali Waterpump..Hehehe
    0812-182-862-05
Datsun 300x250 Venom 300x250
  1. Swap Engine Honda Nova to B-engine
    By soundpump in forum Diskusi Mesin
    Last Post: 29th June 2015, 15:50
  2. Q # ENGINE WORKS : PnP, Engine Swap, Etc
    By coki.de auto in forum de Auto Motorsport
    Last Post: 28th May 2015, 04:37
  3. Replies: 19
    Last Post: 13th July 2012, 00:45
  4. [WTA] Engine Swap Timor B5 ---> B6 mazda
    By tonnychristofel in forum Diskusi Mesin
    Last Post: 21st August 2010, 22:32
  5. Engine Swap timor
    By Shiro 25 QN in forum Diskusi Mesin
    Last Post: 25th April 2008, 05:29
