Flex L3403VRG
Page 1 of 13 12345 ... LastLast
Results 1 to 10 of 121
Thread: Flex L3403VRG
  • Short URL:  http://modifika.si/33133
    21 Hrs 28 Mins 24 Secs
    Flex L3403VRG
    Kena omel David dach...posting gak jelas (kena racun littlerunner nih, parah bener. ngeracuninnya mesin)
    Flex Tool L 3403 VRG (Rotary)
    The lightweight Flex polishing machine with accelerator trigger for polishing/sanding.
    Slim stick handle, high torque motor, light weight, and a practical bail handle. That is how to polish easily and effortlessly in every job. The accelerator trigger switch and speed selection allow for a controlled acceleration to the optimal mixing speed.
    SPECIFICATIONS:
    Max. polishing pad diameter - 6-1/2"
    Max. back-up pad diameter - 6-1/2" 5/8-1
    Tool fixture Speed without load - 1100-3700 RPM
    Power Input - 11.5 AMP
    Power Output - 1400 w
    Weight: 4.85 lbs
    STANDARD EQUIPMENT:
    1 bail handle
    1 side handle
    ADVANTAGES AT A GLANCE
    * FLEX seven-fold microprocessor electronics: with consistent speed control by tachometer generator, soft start, accelerator trigger switch, restart protection after power interruption, overload protection, temperature monitoring, and speed selection
    * High-powered motor: can handle extreme loads
    * Spindle lock: for easy disc changes
    * Quality shut-off carbon brushes: if the carbon brushes wear down, the motor will be automatically switched off and thus protected from damage
    * Bail handle
    * 4 m power cord: with FLEX red plug
    * 10-Foot power cord
    hmmm...udah gak sabar
    ==Is it detailing? Nope==
  2. 36Goal.com
    1 Day 1 Hr 28 Mins 24 Secs
    gua naksirnya kaya lu punya Ron... :smt010 :smt010 :smt010
    Minta David dong. Harusnya tersedia nih
    Quote Originally Posted by artronnie
    David siap tunggu order yang pasti..!!! :smt023
    Pokoknya ada order barang pasti bisa masuk walaupun nunggu sikit.. :smt003
    Udah gak sabar
    ɐʇɹɐʞɐɾ
    12 Hrs 9 Mins 19 Secs
    mantap mesin high end negh :smt007 :smt007
    4 Days 11 Hrs 52 Mins 36 Secs
    Bung ronnie :
    bedanya Flex Tool L 3403 VRG dengan porter cable??
    Quote Originally Posted by erw3108
    Bung ronnie :
    ini kan rotary, PC DA...
    kalo mau, ambil yang 3401 VRG :smt010 :smt010 :smt010
    liat yang di bawah Ronnie post
    Cawang
    2 Mins 28 Secs
    Bung ronnie :
    2 different animal. rotary and dual action. buat defect2 ringan bisa pake DA, tapi kalo untuk kelas berat seperti ngilangin sanding mark, musti maen di rotary
    Quote Originally Posted by phaphuq
    Dua2nya bakal jadi punya gw sih
  1. Dijual Club of Flex polisher ( Flex VRG 3401 dan PE 14 )
    By Foamwax in forum Produk Perawatan Mobil
    Last Post: 18th October 2012, 00:12
  2. WTS - TEIN Flex CO for GE8 2nd
    By Jazz_Go in forum Per & Shockbreaker
    Last Post: 8th June 2011, 14:54
