Porter Cable 7336 : Dual Action Car Buffer / Polisher !!
Results 1 to 10 of 120
  • Short URL:  http://modifika.si/32943
    1 Day 1 Hr 28 Mins 24 Secs
    Porter Cable 7336 : Variable-Speed Random-Orbital Car Buffer / Polisher
    Porter-Cable 7336 Variable-Speed Random-Orbit Car Buffer / Polisher comes from the factory with a standard 6 inch counterweight so you can use it with backing plates and foam pads that are 6" inches or larger in diameter.
    The Porter Cable 7336 Variable-Speed Random-Orbit Car Buffer / Polisher is the perfect buffing, polishing and detailing machine for the car care perfectionist. This is the detailing machine that made hand polishing obsolete! The random-orbit, polishing action of the Porter-Cable 7336 will give you swirl-free results without burning your paint or removing excessive amounts of clearcoat. The Porter Cable 7336 Variable-Speed Random-Orbit Car Buffer / Polisher is the best machine polisher on the market today! :smt023
    The Porter-Cable Variable-Speed Random-Orbit Car Buffer / Polisher is the perfect car buffer to give you swirl-free results much faster than you can achieve by hand. With the Porter Cable 7336 Variable-Speed Random-Orbit Car Buffer / Polisher anyone can produce an outstanding finish on their car! Electronic variable speed control adjust from 2,500 to 6,000 orbits per minute. Handles screws into either side. Foam pads and accessories sold seperately.
    If you are looking for the ultimate shine and reflection then look no further than Porter-Cable 7336 Variable-Speed Random-Orbit Car Buffer / Polisher and our buffing and polishing accessories. The Porter-Cable 7336 Variable-Speed Random-Orbit Car Buffer / Polisher is easy enough for the beginner to use, yet effective and durable enough for the demanding professional detailer. This is the perfect polisher for removing light scraches and swirl marks and also for applying your favorite glaze, wax or sealant!
    Specifications :
    # Power: 120 VAC, 50-60 HZ
    # Amps: 4.0 Amps
    # Orbits/Min: opm
    # Tool Length: 11-1/2 "
    # Net Weight: 5-3/4 lbs
    # Shipping Weight: 6-1/2 lbs
    Features :
    # Random, swirl-free polishing action
    # Converts between a 6" random orbit polisher and sander
    # Electronic variable-speed dial 2,500-6,000 OPM
    # Random, swirl-free sanding action
    # Spiral/bevel gears
    # 100% ball bearings
    Includes :
    # Porter Cable 7336
    # Side handle
    # Operating manual
    # Wrench #48779
    A product from Delta|Porter-Cable
    == Interested : Please visit www.detailermart.com for further information ==
  2. clickbet88.com
    Cawang
    2 Mins 28 Secs
    bisa digunakan oleh pemula atau yang sudah ahli. Aman untuk cat. Belom pernah gue denger pake PC bisa burn cat. Untuk ngilangin swirl, dan defect2 ringan.
    7336-->7424's twin brother
    Foto 7424
    Sama kan barangnya.
    Paling beda di foto yang di upload erry, ada tulisan random orbital sander, sedang kan di 7424 tulisannya random orbital polisher
    tapi keduanya sama aja koq. sama2 mesin bagus
    2 Days 3 Hrs 1 Min
    brp tuh hrgnya,beli dmna?
    Cawang
    2 Mins 28 Secs
    www.detailermart.com sama bos david
    ɐʇɹɐʞɐɾ
    12 Hrs 9 Mins 19 Secs
    dah masuk ya barang ny...
    random orbital sander ma random orbital polisher
    apa beda ny negh mike..
    21 Hrs 28 Mins 24 Secs
    Belum di-masukin kayaknya di stock barang. Mungkin besok udah siap
    ==Is it detailing? Nope==
    ɐʇɹɐʞɐɾ
    iya barusan di liat masi sama kaya kmaren..
    2 Days 3 Hrs 1 Min
    gmn ni cara pakenya?tutorialnya dong sebelum dijual ke market biar kita2 paham dulu cara pake nya yg benar
    50 Mins 23 Secs
    Quote Originally Posted by copper rod
    Denger2 para suhu disini akan skip acara tutorial2, langsung ke live demo tgl 3 nanti.
    langsung demo aja baru nanti pada nonton video upload dari para Poisoners, hehhee
Venom 300x250 GT Radial
  1. Review DAS6PRO Dual Action Polisher
    By Perfectshine in forum Diskusi Perawatan Mobil (Exterior & Interior)
    Last Post: 16th May 2014, 13:50
  2. WTB > Dual Action Polisher merk Meguiars G110v2 ato Porter Cable 7424XP
    By Pro91 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 12th February 2011, 12:54
  3. DIBELI DA 2ND/NEW (DUAL ACTION POLISHER)
    By Socrates in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 24th July 2010, 01:42
