[REV ENGINEERING] GREY PAJERO SPORT EXCEED 4x2 M/T Daily Use -- ECU=SHOP
Results 1 to 10 of 21
  • Short URL:  http://modifika.si/328508
    1 Mth 1 Wk 9 Hrs 25 Mins 5 Secs
    *update 18 Juni 2012
    Full stage 2 modification by MonMax Rev Engineering
    306Hp/570Nm
    Pushing 26 psi on stock internal.
    MITSUBISHI 4D56 2.5L Turbo Commonrail Intercooled
    230Hp/480Nm
    Pajero Exceed pushing 20PSI on stock turbo tuned with MONMAX by ECU=SHOP
    Modification
    Surge Tank + External Pump
    Oil Catch Tank
    King Dragon 3" Open Filter
    ECU=SHOP Monmax Diesel
    ECU=SHOP SCV
    ECU=SHOP Boost Speed
    GIZMO Boost Controller
    BREMBO BBK 4-Pot F50 Caliper with 355mm 2-piece Drilled Rotor
    RUNSTOP Rear Drum Brake Conversion Kit into 2-pot dual caliper
    Original VOLKRAYS Bronze TE37 6 Lugs
    Toyo Open Country 285/60R18
    TEIN Coilover
    ULTRACING Underbrace Kit
    Upgraded Stage 2 Turbo
    Custom 3" Downpipe
    Custom 2.5" Exhaust System
    BK Clutch
    Upgraded Commonrail Stroker Kit
    Rear Disc Conversion in progress
    More updates and pictures of the cars will be updated soon... This is going to be one sick Pajero Sport. Stay tune...
    PERTADEX lagi...
    8 Hrs 20 Mins 57 Secs
    ga bermasalah di transmisi bro??? ga perlu pake yg heavy duty kah??
    Quote Originally Posted by ak4ng View Post
    Masih aman. ntar naik turbo baru upgrade transmisi.
    UPDATED.
    1 Wk 4 Days 16 Hrs 45 Mins 18 Secs
    more pict donk , Pajero keren nich...
    Quote Originally Posted by hajarrr View Post
    masih on progress nih. bentar lagi kelar. ntar poto2 lagi. 300++ hp yg pasti.
    1 Day 4 Hrs 59 Mins 42 Secs
    bro,kalo mo upgrade ampe 300+ budgetnya brp yah? u/ pajero sport.tp status mbl gue saat ini uda dipsg diantaranya simota ventilator,power torque,simota filter stainless steel,cyclone + down pipe.exhaust system diganti HKS bolt on ,middle pipe ganti Kansai.nah kira2 dr spek yg saat ini apa msh bs dinaekin hpnya,bro? thank u.
    Quote Originally Posted by DieselPower View Post
    ngga mobil nya kaga motor nya sadissss semua
    Quote Originally Posted by pajerofreakz75 View Post
    langsung ke bengkel aja bos. ga enak dijabarin disini.
    Mobil kelar bikin exhaust dari Budi Knalpot langsung tuning di dyno dapet:
    306 Hp/ 570 Nm
    12 Hrs 24 Mins 2 Secs
    Thumbs up
    Asliiii...mantappp...soalnya pas di dyno gw liat langsung...dan emang baiknya datang ke bengkel...dijamin keracunan "Diesel Monster" punya gw (PS Dakar A/T---maroon) pakai harian cm pasang ECU SHOP Monster Max + CR Stroker Pump Kit + Modif CR Pressure Limiter + Ecu Shop Boost Speed + Monster Gauge OBDII + AT Cooler, hasilnya 270 Hp/580+ Nm[/QUOTE]...ini jg masih to be continue, soalnya ada beberapa part yg belum datang...silahken datang aja boss...
    306 Hp/ 570 Nm
Datsun 300x250 MBtech
  1. [REV ENGINEERING] PAJERO SPORT DAKAR 4x2 A/T Daily Use
    By DieselPower in forum Mitsubishi
    Last Post: 23rd April 2018, 12:11
  2. Replies: 22
    Last Post: 3rd March 2016, 22:57
  3. Replies: 160
    Last Post: 3rd August 2015, 20:27
  4. wtb, pajero sport exceed 4 x 2 white
    By arva in forum Mitsubishi
    Last Post: 6th July 2012, 22:45
  5. PAJERO SPORT 4X2 EXCEED TH 2009 Rp.357 JT
    By indru in forum Merk Lainnya
    Last Post: 29th April 2010, 09:23
