Velgvelg Rajawali Autogallery
Kotamas Knalpot
Hasta Rajawali Autogallery Clean N Tidy
Page 1 of 16 12345 ... LastLast
Results 1 to 15 of 234
    Major
    barcen 100% kirbal PM
    1 Wk 4 Days 4 Hrs 3 Mins 35 Secs
    Murah !!! Alat Scan u/memeriksa kerusakan mesin mobil ( pic ++ )
    Major
    Scanner mobil khusus u/ Mercy, BMW, & Peugeot
    A. Carsoft 7.4 u/ Mercedes Benz :
    Spoiler for Keterangan: Show
    1. Carsoft will give you fault codes, allow you to erase them, allow you to test individual components, and set some parameters. It does this for brake systems, airbag systems, AC, instrument clusters, transmission ECUs, Keyless Go, airmatic, ABC, PSE, ESP, Parktronic, the ignition system, headlight systems, convertible top, power seats, FI, and many other subsystems that typically only the dealer can diagnose & repair.
    2. YOU CAN READ/ERASE ALL FAULT CODES
    3. READ ECU INFORMATION
    4. YOU GET REPAIR INFORMATION AND FEATURES LIKE LIVE DATA AND CODING!!!! TOTAL AND SINGLE DIAGNOSIS - READ and ERASE FAULT CODES LIVE DATA (some ECUs only) - ECU INFO - REPAIR INFO - PRINT REPORT, LIVE DATA , DE-ACTIVATION & ACTIVATION OF THE BRAKES
    5. Harga = 1.5 jt
    SUPPORT :
    • Petrol Engines : ENGINE - TYPES until April 2004 Additional Features: - ME LIVE DATA, ME CODING, ME ADAPTATION Vehicle Types: - W124 / W202 / W140 / R129 / W210 / W208 / R170 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 / Vito / V-Class / Sprinter
    • Diesel Engines : ENGINE - TYPES until April 2004 Additional Features: - CDI LIVE DATA, CDI INJECTOR TEST Vehicle Types: - W124 / W202 / W140 / W210 / W208 / W203 / W163 / W168 / W220 / G461 / G463 / Vito / V-Class / Sprinter ABS - ASR - ETS - ESP - BRAKE Systems until April 2004 Additional Features: - ESP LIVE DATA, ABS ACTIVATION '95 onwards Vehicle Types: - W124 / W202 / W140 / R129 / W210 / W208 / R170 / W211 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 / Vito / V-Class / Sprinter SBC - SENSITIVE BRAKE CONTROL Systems till April 2004
    • Vehicle Types: W211 / R230 AIRBAG - AIRBAG Systems until April 2004
    ECU CODING :
    • Vehicle Types : - W124 / W202 / W140 / R129 / W210 / W208 / R170 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 / Vito / V-Class / Sprinter KI - INSTRUMENT CLUSTERS until April 2004
    • Vehicle Types: - W202 / W140 / R129 / W210 / W208 / R170 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 / Vito / V-Class / Sprinter BAS - BRAKE ASSISTANCE Systems until April 2004
    • Vehicle Types : - W202 / W210 / R129 / W140 / W208 / R170 / W211 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 / Vito / V-Class / Sprinter EGS - GEARBOX Systems until April 2004
    • Additional Features: - LIVE DATA . ADAPTATION Vehicle Types: - W124 / W202 / W140 / R129 / W210 / W208 / R170 / W211 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 KG - KEYLESS GO Systems until April 2004
    • Vehicle Types: - W220 / W215 / R230 ASSYST - SERVICE INTERVAL Systems until April 2004 Additional Features: - SERVICE RESET, SERVICE
    PROGRAMMING :
    • Vehicle Types: - W202 / W140 / R129 / W210 / W208 / R170 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 / Vito / V-Class / Sprinter AIRCONDITIONING - AIRCO Systems until April 2004 Additional Features: - LIVE DATA INFO (Guidance to Display A/C Live Data on vehicle display)
    • Vehicle Types: - W124 / W202 / W140 / R129 / W210 / W208 / R170 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 / Vito/ V-Class / Sprinter AIRMATIC - AIR SUSPENSION Systems until April 2004 Additional Features: - LIVE DATA , ACTIVATION
    • Vehicle Types: - W220 / W215 ABC - ACTIVE BODYCONTROL Systems until April 2004
    • Vehicle Types: - W220 / W215 / R230 PSE - PNEUMATIC Systems until April 2004
    • Vehicle Types: - W124 / W202 / W140 / R129 / W210 / W208 / R170 / W220 / W215 / R230 / G461 / G463 PTS - PARKTRONIC Systems until April 2004 Additional Features: - LIVE DATA
    • Vehicle Types: - W202 / W140 / R129 / W210 / W208 / R170 / W209 / W203 / W163 / W220 / W215 / R230 / G461 / G463 AAM - ALL ACTIVITY Systems until April 2004 Additional Features: - ECU CODING
    • Vehicle Types: - W163 EAM - EXTENDED ACTIVITY Systems until April 2004 Additional Features: - ECU CODING
    • Vehicle Types: - W163 D2B - COMMAND Systems until April 2004 Additional Features: - ECU CODING
    • Vehicle Types: - W202 / W140 / R129 / W210 / W208 / R170 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 ATA / DAS - ANTI THEFT ALARM Systems until April 2004
    • Vehicle Types: - W124 / W202 / W140 / R129 / W210 / W208 / R170 / W209 / W203 / W163 / W168 / W220 / W215 / R230 / G461 / G463 EIS - ELECTRONIC IGNITION Systems until April 2004
    • Vehicle Types: - W124 / W202 / W140 / R129 / W210 / W208 / W209 / W203 / W220 / W215 / R230 / G461 / G463 UCP - UPPER CONTROL PANEL Systems until April 2004
    • Vehicle Types: - W209 / W203 / W220 / W215 LCP - LOWER CONTROL PANEL Systems until April 2004
    • Vehicle Types: - W210 / W208 / R230 OCP - OVERHEAD CONTROL PANEL Systems till April 2004
    • Vehicle Types: - W210 / W208 / W209 / W203 / W220 / W215 / R230 HRA - XENON LIGHT Systems until April 2004 Additional
    B. Carsoft 6.5 u/ BMW :
    1. MCU controlled Interface for Carsoft 6.5 which is compatible with the original interface. Fully digital line switchings and MCU controlled service reset timing.
    2. Digital total test: It gives you a complete idea of the overall condition of the car
    3. Digital single test: It gives you detailed information about the appropriate control unit. Stored errors will be shown in a written report. This report has a short info-text which help you to eliminate the error.
    4. Special functions for some models: Including service interval reset, component activation, live data, LCM reading, sync. EWS and ECU, adaptation values, and coding
    5. Harga = 1.25 jt
    C. Lexia 3 u/ Peugeot :
    Compared with other universal vehicle scanner equipment that just read fault codes, lexia 3 pps2000 works almost all the functions such as the original dealer diagnostic tool. Lexia 3 pps2000 interface contains K-Line multiplexor, CAN-BUS interfaces and SAE J1850 bus (both PWM and VPW).
    • Read fault codes
      Displays all stored and pending fault codes with complete description (e.g. "Rail pressure - too low pressure"). Program supports report printing or copy to clipboard.
    • Clear fault codes
      This function clears all stored fault codes and other diagnostic information. Read identification Displays complete identification of control unit, e.g. part number, software/hardware version, manufacturer, etc..
    • Measured Values
      Program displays live Data like Engine Speed, Battery voltage, Oxygen Sensor, Coolant Temperature, etc. Values can be displayed in graph, 9 values at once, or full listing (all measured values). Logging to file is also supported, which allows offline analysis.
    • Programming functions/Adaptation
      This feature is of great importance in all vehicles because systems like Engine control units, Immobilizers, Airbags, Alarms, Body Control Units, and some others, require you to perform reset or programming procedures after car repair is done, or even configuration after replacing broken Control Unit.
    • Auto-scan (complete car scan/test)
      Detects all ECUs (electronic control units) installed in car and reads all diagnostic fault codes.
    • Read identification
      Display complete identification of control unit, e.g. part number, software/hardware version, manufacturer, etc...
    • Actuator test
      Actuator test activates particular actuator (e.g. turn on fuel pump, lock/unlock wheel, lock/unlock doors, cut off fuel, etc..)
    • Harga = 3 jt
    Foto penampakan :
    Major
    D. Compact C5 Pro u/ Mercedes Benz :
    • Description : ( Our MB Star Pro can be used with any laptops & computers,when diagnose with Benz car ,just connect the External Hard Drive with computer via a USB cable then run software directly .The DAS software already installed in this External Hard Drive. so convenience for using )
    • Now the version is : February 2011.5
    • Function:
      1.1989~up to now Car, Bus, Truck, Sprint, Smart ;
      2.All electric system Diagnostic;(Do not include flash code)
      3.Reading out and erasing trouble code;
      4.Reading the real-time data of sensor and actuator;
      testing the component of cars; coding and programming.
    • Hardware and software requirements :
      Software requires at least Intel Celeron/Pentium 1.8GHz, 1G RAM(the best), USB 2.0 recommended and Microsoft Windows 98 SR2/2000/XP with the latest service pack installed.
    • Character :
      1. Realizes all the function of official factory BENZ compact 3.
      2. C3 Multiplexer can connect to factory computer and IBM laptop.
      3. Complete maintenance data. It could offer full disassembly and assembly circuit diagram, working principle and element place anytime needed. It is the best assistant for maintenance man.
    • Package Include :
      1. MB C3 STAR MULTIPLEXER( BenZ VCI)
      2. 16 PIN OBD II cable (OBD Diagnostic Socket )
      3. 38 PIN cable (Old Benz Round Socket )
      4. 14 PIN cable (Sprint. Bus. Truck Round Socket)
      5. 4 PIN cable (Old Benz Rectangle Socket)
      6. RS232 Cable (Computer Communication)
      7. RS232 TO RS485 Cable (Compact3 cable)
      8. RS232/RS485 Connect Cable
      9. External Hard disk with ALL softwares (This can be used with any other computers)
      10. PCMCIA TO RS232 Card
      11. Drive CD
      12. Tool box (Optional)
    • Product software includes :
      DAS : the automatically Diagnosis Assistance System
      WIS.net : Workshop Information System
      EPC.net : Electronic Parts Catalog
      ST finder2009 : Part location finder
      STARUTILITIES : the movement management system and self-test
    • Harga : 8.5 jt
    Foto penampakan :
    Major
    Scanner mobil Launch X431 family Scan Tool, barang gress, readystock beberapa unit, tinggal pake
    A. Fungsi Utama untuk Launch X431 Diagun :
    • Penggunaan sangat mudah dan gampang dibawa-bawa
    • Dapat mendiagnosis dua kendaraan secara bersamaan via bluetooth dan kabel data ( included )
    • Teknologi bluetooth tanpa kabel dengan radius 15m-20m
    • Soket dan konektor sambungan 16 pin
    • Dapat digunakan untuk mendiagnosis mobil2 versi Asia , Eropa dan Amerika
    • Kecepatan membaca dan loading program sangat cepat
    • Free update data selama 1 tahun
    • Layar sentuh / touchcreen 4.3 inch, berwarna, lebih terang dengan resolusi tinggi
    • Menggunakan baterai recharge 1530mAh
    • Memori card SD 1GB
    • Bisa disambungkan dengan printer via USB
    • Harga = 13 jeti
    Features :
    Spesifications :
    Foto2 penampakan :
    foto2 penampakan ukuran besar ( 13 pics ) ... klik aja disini :
    http://www.flickr.com/photos/57438490@N08/sets/72157626369106604/
    B. Fungsi Utama untuk Launch X431 GX3 :
    • Dapat mendiagnosis berbagai jenis kendaraan s/d model terbaru
    • Dilengkapi dengan mini printer buat mencetak data mobil yg discan
    • Soket dan konektor sambungan pin ada banyak buat aneka jenis mobil
    • Garansi & free update data selama 1 tahun
    • Layar sentuh / touchcreen lebar, berwarna, lebih terang dengan resolusi tinggi
    • Berbasic PDA dengan OS Linux, jadi bebas virus
    • Harga = 14.5 jeti
    Foto2 penampakan :
    foto2 penampakan ukuran besar ( 12 pics ) ... klik aja disini :
    http://www.flickr.com/photos/65619681@N07/sets/72157627596358339/
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupupupupupupupupupup
    upupupupupupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
  12. #11
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
  13. #12
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
  14. #13
    Major
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
  15. #14
    Private First Class
    surabaya
    3 Days 5 Hrs 56 Mins 59 Secs
    bos, untuk nissan livina pasti bisa pake yah?
  16. #15
    Major
    Quote Originally Posted by HY_sby View Post
    kalo yg elm327 ke livina belon pernah test, tapi kalo ke xtrail udah test, bisa semua, kalo mau coba aja bro, kl ga tembus mah gampang, ntar balikin lagi aja, hehehe... hrgnya only 750k
Tritala CK & DRD Banner Available 242x90
  1. Mesin Mobil Murah Toyota Sudah Di Produksi
    Last Post: 1st December 2012, 22:01
  2. Replies: 0
    Last Post: 8th November 2011, 11:13
  3. Tips: Diagnosa kerusakan mesin dan jawabanya..
    By Fuego in forum Diskusi Mesin
    Last Post: 1st December 2010, 07:56
  4. KERUSAKAN MOBIL BLAZER-KU, BANTUIN GW DOONG
    By bluethoo in forum Diskusi Mesin
    Last Post: 20th September 2010, 16:11
Silikon Motorsport
Tirta Motor Sport
