~ஜ۩۞۩ஜ- BRZ Sudah Bisa Dipesan!! Yang mau pertama kali pakai, monggo dibuka. -ஜ۩۞۩ஜ~
Results 1 to 10 of 81
  • Short URL:  http://modifika.si/325935
    4 Days 4 Hrs 45 Mins 30 Secs
    [SUBARU JAKARTA] Boxer Rear-wheel-drive Zenith
    Jangan lupa Rate yaa
    CTRL+D atau "Thread Tools > Subscribe to This Threads", biar gampang carinya
    Spoiler for BRZ: Show
    Spoiler for Spesifikasi BRZ: Show
    ENGINE
    1998cc, Horizontally-opposed Boxer, 4-cylinder, 4-stroke
    DOHC 16-valve
    12.5 Compression Ratio
    Direct and pot fuel injection
    PERFORMANCE
    Output 200PS/7000rpm
    Torque 205Nm/6400-6600rpm
    Dimensions & Weight
    LxWxH 4240x1775x1425mm
    Wheelbase 2570mm
    Road Clearance 130mm
    Weight 1256kg(M/T) 1278kg(A/T)
    CHASSIS
    Rack and Pinion, electric power steering systems
    MacPherson strut type front suspensions
    Double wishbone type rear suspensions
    16' Ventilated front disc brakes
    15' Ventilated rear disc brakes
    Wheel 215/45R17, 17x7'
    EXTERIOR
    Auto on/off headlamps
    HID headlamps with auto-levelizer
    Pop-up headlamp washers
    Front fog lamps
    Rear fog lamps
    Power folding door mirrors
    UV Protection glass
    Variable Intermittent windshield wipers
    Engine, transmission and floor under cover
    Fender garnish
    Rear difusser
    Twintail muffler cutter
    INTERIOR
    Power window
    Remote control key system
    Keyless access and push start button system
    Dual-zone AC system with anti-dust filter
    Front and side defrosters
    Electric rear window defogger with timer
    1.4 DIN audio system 1-CD with 6speakers
    USB and auxilary input jack (in centre panel)
    Digital speed meter
    Tilt adjustable/telescopic steering wheel
    Paddle shift (A/T)
    Quick ratio powersteering
    Multi-information display
    Rev-Indicator
    Cruise control
    Aluminium pedals
    DRIVABILITY
    Vehicle Stability Control
    Sport and Snow mode function (A/T)
    Torsen LSD (Limited Slip Differential)
    SAFETY
    Front SRS Airbags
    Front Side SRS Airbags
    Curtain SRS Airbags
    Knee SRS Airbags
    Side-door reinforcement beams
    Steering column support beams
    Whiplash reducing front seats
    Seatbelt indicator
    Front seatbelts with pretensioners and load limiters
    3-point seatbelts
    Safety pedal system
    4sensor/2channel ABS
    Brake Assist System
    ISO-FIX adapted child seat anchors
    Anti-theft security system with engine immobilliser
    Iklannya nih mas bro..
    SUBARU BRZ Commercial
    Seluk beluk pembuatan mobilnya..
    SUBARU BRZ Development 1
    SUBARU BRZ Development 2
    BRZ Versi GT300..
    SUBARU BRZ GT300
    Status : Indent.
    Harga : Type LIMITED
    _______ Rp.668.000.000 (MT)
    _______ Rp.628.000.000 (AT)
    ________ OTR JAKARTA
    *harga gak salah kok, memang mahal yang Manual (MT)
    JUAL SUBARU JAKARTA
    HUBUNGI SAYA
    Harga dijamin gak dimahal-mahalin, kalo ada bonus juga gak bakal ditahan-tahan
    Nanya-nanya doang gapapa, daripada penasaran kan, lumayan nambah teman
    Sukur alhamdulillah kalo beli
    B A G A S
    0856 9442 4339
    Pin : 20c6e5dd
    email : bagusbb@motorimage.net
    Masih ragu dengan SUBARU? Cekidot..
    • Garansi 5 Tahun / 100.000 KM*
    • Garansi Karat selama 10 Tahun (jarak tempuh tidak terbatas)*
    • FREE Jasa Service selama 5 Tahun / 100.000 KM*
    • Garansi jika terdapat Cacat pada Cat 1 Tahun / 20.000 KM*
    • Garansi penggantian Suku Cadang Asli selama 1 Tahun / 20.000 KM*
    *mana yang tercapai terlebih dahulu,
    *syarat & ketentuan berlaku.
    SUBARU MAHAL??
    Coba bandingkan pajak masuk SUBARU yang 100% built up Jepang, harganya masih bisa bersaing dengan kompetitor lain yang rakitan Thailand.
    Jadi apa masih mahal??
    Untuk panduan lokasi showroom silahkan klik gambar dibawah ini
    Surabaya - Semarang - Temanggung
    3 Wks 3 Days 21 Hrs 13 Mins 1 Sec
    woow keluarnya kapan nih?
    beda banyak juga ya sama STi..
    Plat " L "
    1 Mth 3 Wks 2 Days 9 Hrs 8 Mins 52 Secs
    ctrl D dlu dah..
    kayaknya hargny lebih mahal dr yang toyota ngeluarin ya..
    bos..,kl blh tau jatah dapet berapa mbl ni?
    andai udh ada hrg fix nya ni..
    Quote Originally Posted by m4nuk View Post
    rencana launching di IIMS mas bro
    Quote Originally Posted by patient View Post
    ctrl D dlu dah..
    tengkiu
    ya kan harganya belum fix, bicara pahitnya dulu aja mas bro
    daripada di murah2in taunya ntar mahal
    jatah apaan tuh? mas bro nya mau jual lagi?
    1 Wk 4 Days 9 Hrs 32 Mins 16 Secs
    Waduhhh...kalo harga BRZ di atas 700jt sih rada berat yah....ada scirocco, RCZ, MX5, di level 650-700jt...850jt dah dapet BMW 135 coupe sih...cuma input aja buat motor image....
    Quote Originally Posted by olie92 View Post
    siaaap abaaaang
    Selamat sore
    Diatas Tanah Dibawah Langit
    2 Wks 3 Days 20 Mins 31 Secs
    tunggu pas launching... bisa diliat, diraba, dipegang... and harga juga udah langsung tau.
    memang naksir nih mobil... kalo ga beli versi toyota nya ya beli subaru nya lah ya.
    bantu up dulu.
    4 Days 19 Hrs 39 Mins 45 Secs
    mantaaaabz, ane naksir beraaaat nih...uda lam nungguin japan 2 door coupe yang baru, abisnya uda lama ngak kluar hihihi
    Quote Originally Posted by nelsonphilipus View Post
    bantu up dulu.
    siaapp.. nanti pasti di update kalo udah pasti harganya
    tengkiu mas broo
    Quote Originally Posted by lcc honda View Post
    ayo dong dipesan
GT Radial
  1. Replies: 48
    Last Post: 9th May 2014, 15:39
  2. Replies: 23
    Last Post: 4th April 2013, 19:21
  3. Replies: 29
    Last Post: 30th December 2011, 08:28
  4. Replies: 30
    Last Post: 21st October 2011, 09:45
  5. Replies: 6
    Last Post: 30th September 2010, 00:29
