[JUAL] PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam 100% BNIB = Murah.
Kami ingin memberitahukan bahwa Sistem Jual Beli Audio Mobil baru telah kami aktifkan
Untuk informasi lebih lengkap dapat dilihat di http://modifika.si/595332
  • Short URL:  http://modifika.si/325735
    BSD City - Tangerang Selatan
    Giro Point
    4 Days 17 Hrs 55 Mins 38 Secs
    Thumbs up [JUAL] PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam 100% BNIB = Murah.
    Assalammualaikum,
    Gan, Ane Mau Jual PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam.
    Kondisi PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam Yang Ane Jual Ini:
    - 100% BNIB (New/Baru) Packing Lengkap
    - Original Made In Taiwan
    Berikut Ini Adalah Keterangan Lengkap Mengenai PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam:
    Holds 2 cards for super large capacity
    Card types can be mixed
    Freedom of expansion and upgrade
    Super high read/write speeds of 10MB/s and up
    4 big advantages:
    1. Holds 2 cards for super large capacity
    Get maximum storage capacity with 2 microSDHC or 2 microSD cards.CR-5400 converts 2 microSD(HC) cards into one MS Pro Duo stick. You can get twice the capacity at a lower price.
    2. Card types can be mixed
    Cards of different capacity and different type can be used concurrently (i.e. microSD+microSDHC).
    3. Freedom of expansion and upgrade
    The adapter works with only one microSDHC card as well. The second slot can be equipped anytime later. You can exchange the cards and upgrade the max. capacity at will!
    4. Super high read/write speeds of 10MB/s and up
    CR-5400 is made of high quality components and preserves the original speed of the inserted microSD(HC) cards (when two different types of microSD(HC) cards are used, the slower card
    sets the speed rate)
    Download:
    On first time use, please format CR-5400(include microSD x 2 pc) in any Sony device. Such as PlayStation Portable or Cyber-shot Digital cameras. If you dont have one, please download HP Format Utility from here.
    (All rights reserved to c 2009 Hewlett-Packard Development Company, L.P.)
    Instruction guide for real and fake ones
    Speed test
    Product Specification:
    Product name: CR-5400
    Supported card types: microSD 256MB - 2GB/ microSDHC 4GB - 16GB
    Maximum capacity: Depends on the capacity of used
    Operation temperature: microSD/microSDHC
    Storage Temperature: 0J ~ 70J
    Humidity tolerance: -25J ~ +85J
    System requirements: 95% (maximum)
    Dimensions: 31.1mm x 20mm x 1.6mm
    Weight: ~2g
    HOW TO USE CR-5400:
    When using new microSD or microSDHC card(s) it needs to be formatted with a SONY product before you can store any data.
    If you use only one microSD or microSDHC card it must be inserted into slot#1 in order to work.
    When using a card reader always insert the memory cards into CR-5400 adapter first. Don`t take out the microSD or microSDHC card(s) and perform direct white operations from PC to single card(s).
    If you do YOUR DATA WILL BE CORRUPT.
    REUSING YOUR microSD or microSDHC CARDS FOR OTHER DEVICES THEN CR-5400
    If you experience formatting problems(i.e. only half of the original capacity), Please format this card(s) in slot#1 of CR-5400(slot#2 MUST be empty).
    After this you will be able to use your microSD or microSDHC card(s) in other devices again.
    Berikut Ini Adalah Foto Asli Dari "PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam" Yang Ane Jual Ini Gan:
    NB: Mohon Maaf Kalau Fotonya Kurang Bagus, Karena Fotonya Pake Kamera BlackBerry Jadul .
    Harga PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam:
    Ane Jual Cuma Rp100.000,- Ribu [NET No Nego]
    Stock:
    Cuma 1 Unit Doang Gan
    Metode & Cara Transaksi Serta Lokasi Transaksi:
    COD (Cash On Delivery) Wilayah Tangerang Selatan, BSD (Bumi Serpong Damai), Serpong, ITC BSD, Teraskota BSD, WTC Matahari BSD.
    Untuk Pembeli Yang Dari Luar Kota Ane Kirim Aja Pake JNE Okay Gan .
    Bagi Juragan Yang Berminat Untuk Membeli "PhotoFast CR-5400 MS ProDuo Adapter Buat PSP & Sony Digicam" Ini Silahkan Hubungi Gua Di Nomor HP Dibawah ini ya
    Terimakasih Atas Attensi Juragan Semuanya
    Rgds
    HUMVEE
    HP XL (GSM) : 087885398886
    YM! : humvee.reborn@yahoo.com
    Lokasi Gua : BSD (Bumi Serpong Damai) - Tangerang Selatan
    Giro Point
    Malem Semuanya
    Yuppp Silahkan Dibeli Gan Barang Langka Neh...
  3. #3
    Giro Point
    Siang Gan
    Yuppp
  4. #4
    Giro Point
    ane berminat nih..
    barangnya masih ada ga?
    lokasi ane di Ciledug, Tangerang
  1. Replies: 0
    Last Post: 3rd May 2012, 11:05
  2. Replies: 2
    Last Post: 3rd May 2012, 11:00
  3. Replies: 0
    Last Post: 2nd May 2012, 12:58
  4. WTS: Memory Stick ProDuo 4GB SONY untuk PSP
    By tamimk in forum Barang Lain-lainnya
    Last Post: 23rd March 2009, 16:37
