Scuto Laminating Simota Bro Togel
  • Short URL:  http://modifika.si/322813
    1 Hr 25 Mins 58 Secs
    Remote Control Universal Steering Wheel
    Deskripsi Produk
    (Bisa untuk semua tape mobil, dengan syarat tape yang juga memiliki remote)
    Function:
    1.The infrared steering remote control is designed specially to keep you enjoy music, at the same time protect your safety when driving.
    2.You can copy function of other common remote control which you use in car to this steering remote control and then install it to your car steering wheel,
    so it can be used instead of your common remote control.
    3.The steering remote control applies to car CD, car DVD, car GPS, car MP3, and other car electronic products..
    4.Simple installation applies to various car.
    5. Applies to control various car CD/VCD/DVD or other car electronic products with remote control.
    6. Built-in high compatibility chip, can copy over 95% infrared format on existing market.
    7. EEPROM technology which can be erased over 100,000 times repeatedly,
    can copy function of various remote control easily.
    8. Built-in high capacity memory and up to 10 copy buttons, enough to meet common function of remote control in car.
    9. Simple and easy copy opreration, high correct ratio for copy.
    10. Copied function can be saved permanently if not erase it manually.
    11. Power supply by 3V button battery, power consumption is very low.
    Packing:
    63g/pc
    Dimension: 8.2 (L)x4 (W)x2.5 (H) CM
    Including battery inside
    Cara pemakaian:
    1. Tekan (set) selama 5 detik, sampai lampu led merah menyala lebih terang dari sebelumnya.
    2. Tekan tombol yang diinginkan pada Remote Steering, maka lampu led merah berkedip per 1detik.
    3. Pada remote asli yang ingin di copy, tekan tombol sehingga Remote Steering berkedip hingga 7-8kali selama 5 detik, tanda bahwa tombol berhasil di copy. (Kondisikan Remote Steering dengan remote asli saling berdekatan dengan sudut kemiringan 60°)
    4. Tekan (set) kembali selama 5detik, sehingga lampu led merah mati. (Selesai)
    5. Ulangi step no. 1 untuk setting tombol berikutnya.
    Garansi: 30 hari
    bb: 2113 D0FF
  2. Asia88 Bet
    jakarta selatan
    22 Hrs 22 Mins 24 Secs
    ini fungsi nya apa yaa?
    Bro,
    Numpang Tanya, harga nett berapa Dan Lokasi di mana?
    Tx
MBtech
  1. Remote Control Universal Steering Wheel
    By Satpam2007 in forum Jual Beli Barang Mobil Lain-Lainnya
    Last Post: 22nd October 2012, 12:52
  2. Remote Control Head Universal Steering Wheel
    By Satpam2007 in forum Bursa Audio Lainnya
    Last Post: 26th June 2012, 14:13
  3. Remote Control Universal Steering Wheel
    Last Post: 14th May 2012, 16:49
  4. Remote Control Universal Steering Wheel
    By Satpam2007 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 22nd February 2012, 15:11
  5. Remote Control Universal Steering Wheel
    Last Post: 11th January 2012, 09:26
