Grit Guard® = Separate the Mitt from the Grit !!
Results 1 to 10 of 70
  • Short URL:  http://modifika.si/32231
    1 Day 1 Hr 28 Mins 24 Secs
    Thumbs up Grit Guard® = Separate the Mitt from the Grit !!
    Grit Guard® Separate the Mitt from the Grit !!
    How it works
    What is Grit Guard® ? :smt017
    # Place the Grit Guard® Insert in the bottom of any 12" diameter Bucket/Pail.
    # Simply rub your mitt or brush across the Grit Guard® Insert while washing your vehicle, boat, motorcycle, RV…
    # Radial Surface Design extracts particles and contaminants from mitts and brushes.
    # Gravity causes dirt to settle to the bottom of the container.
    Wash water stays clean - Scratch-Free Clean.
    # Four Quadrants on the base of the Grit Guard® Insert calm the wash water.
    # Designed to save every car enthusiast time and money.
    # NO MORE long hours spent removing scratches caused by improper car washing.
    # Wash it Right with Grit Guard®! Peace of Mind Guaranteed.
    # The Grit Guard® Insert works great for: Small Parts Cleaning, Wet Sanding, Oil Filter Draining...And Much More!
    Bottom Line... :smt033
    # Grit Guard® separates the Grit, from the Mitt :smt023
    # Gives you a Scratch-Free Wash, time after time. :smt003
    # Think of Grit Guard® as an "insurance policy" for your paint. :smt001
    A product from Grit Guard®
    == Interested : Please visit www.detailermart.com for further information ==
  2. Jayapoker
    Huray to Grit Guard!!!
    ini 'Must Have' tools buat yang suka nyuci mobil sendiri.... :smt003 :smt003
    dicuciin pembantu juga gak papa sih ry, yg penting peralatan lengkap
    50 Mins 23 Secs
    Quote Originally Posted by gioprivatemove
    Waduh gw disindir
    Cawang
    2 Mins 28 Secs
    If you care with your car, buy it!
    Quote Originally Posted by Arache
    Waduh gw disindir
    gak dong Bro. Gw juga kadang-2 ama pembantu. pas gw uda cape bgt atau gak sempet.
  9. 9th April 2008, 14:35
    Reason
    OOT
  10. 9th April 2008, 14:37
    Reason
    OOT
  11. 9th April 2008, 14:39
    Reason
    OOT
  12. #8
    1 Min 25 Secs
    Ini maksudnya informasi ato jualan yaaa???
    Berapa ya harga grit guard gini???
    Dan apakah grit guard ini ada umurnya???
    Habis nyuci mobil kan jadi kotor tuh, apa bisa dicuci, ato kotorannya gak nempel gitu???
    Thx yaaa...
  13. #9
    http://www.detailermart.com
    3 Days 9 Hrs 25 Mins 56 Secs
    phapuq kasi info...kl gw jualan bro...harganya 160rb..umur nya? asal jangan pecah aja bro..ini plastik
  14. #10
    3 Days 2 Hrs 3 Mins 54 Secs
    Quote Originally Posted by AtDp
    Thx yaaa...
    Tuh chan ada gambarnya di postingan paling atas, yang warna merah ditaro di bawah ember. Terbuat dari plastik jadi bisa dipastikan dengan pemakaian normal bisa dipakai seumur hidup :smt003 :smt003
    Berguna agar kotoran2 di dalam air tidak naek lagi ke permukaan air.
  1. FRAME RUSH / TERIOS - SEPARATE & FULL - ONLY Rp. 150.000,-
    By gudangaudiopahe in forum Bursa Audio Lainnya
    Last Post: 12th July 2012, 10:03
