Blackfire Wet Diamond : All Finish Paint Protection
Results 1 to 10 of 55
  • Short URL:  http://modifika.si/32138
    1 Day 1 Hr 28 Mins 24 Secs
    Don't just turn heads. Create WHIPLASH!
    Wet Diamond, All finish Paint Protection is a paint-friendly, oil-in-water, emulsion safe for all finishes with or without a clear coat. This emulsion contains a small amount of a very refined mineral spirit in a water base. Multiple coats can be layered to deepen the gloss without drying or weakening the paint.
    BLACKFIRE Wet Diamond, All Finish Paint Protection can be applied by hand or dual-action, machine polisher. It applies easily and buffs off uniformly even in climates of high heat and high humidity. You simply walk around your car wiping on and buffing off as you go.
    The incredible shine is resistant to detergent washings and ultraviolet radiation. This keeps your car’s finish protected month after month and wash after wash.
    Hand Application Tips:
    # Always use on a cool surface out of direct sunlight.
    # Apply a Quarter size amount of product on a dry applicator pad and wipe on the surface using small circular motions. Allow Wet Diamond All # Finish Paint Protection to dry before buffing.
    # Buff haze with a clean Microfiber Buffing Cloth.
    Machine Application Tips:
    # Place a 6-1/2 inch, Hi-Gloss, Constant Pressure, Red Concours Finishing Pad on a 6 inch Hook and Loop Backing Plate and attach to your machine polisher.
    # Work on a small area, 24 to 36 inches square, out of direct sunlight.
    # Apply two 6 to 8 inch lines of All Finish Paint Protection directly to the surface.
    # With the machine off, spread the sealant over the surface using the dry foam pad. This coats the foam pad and the paint with sealant. (I prefer to apply this sealant with a dry pad, without using any pad lubricant.)
    # Place the Red, Concours Finishing Pad on the paint and turn the machine on. Set the speed dial on the polisher between 3-1/2 and 4.
    # Work the pad over the surface in a back-and-forth motion and then an up-and-down motion. Apply until the sealant starts to dry. Cover one section of the vehicle at a time (i.e. the hood, a door, fender, etc.)
    # Allow a haze to form. Hand buff to a brilliant shine with a Microfiber Buffing Cloth.
    == Interested : Please visit www.detailermart.com for further information ==
    ɐʇɹɐʞɐɾ
    12 Hrs 9 Mins 19 Secs
    wow koleksi ny lengkap negh kayaknya :smt003
    Jkt
    3 Mths 2 Wks 6 Days 19 Hrs 4 Mins 26 Secs
    slurp produknya menggiurkan semua yak :smt003
    Quote Originally Posted by std aja de
    siap memborong?
    Jkt
    Quote Originally Posted by phaphuq
    siap memborong?
    begitu ada kucuran dana pasti gw cicipin nih produk :smt003
    21 Hrs 28 Mins 24 Secs
    siap memborong?
    Nyicip mah pake punya gw aja Ndi. Klo buat aplikasi satu mobil mah ada Gw demen banget ama wanginya Blackfire WD AFPP. Kayak permen karet
    ==Is it detailing? Nope==
    Quote Originally Posted by artronnie
    Gw berangkat dari Gudang Peluru Tebet. Klo gak bawa perlengkapan banyak sih mobil gw cukup. Ntar kontek2 aja bos
    Gudang peluru tebet? dimana tuh ron? :smt005 apa ntar ketemuan di tol aja ron :smt003 soalnya gw gak tau jalan ke rumah david :smt005
    makanya rute jangan pluit - binus aja :smt005
    kumpul di kantor gua aja mo ga? just suggestion...
    Nih...hasil Blackfire WD AFPP
    Satu -
    Dua -
    Tiga -
    lebih NGERI lagi kalo di mobil HITAM....
    3 Days 2 Hrs 3 Mins 54 Secs
    Sampe kolong ban nya aja tetep kiclong, ck..ck..ck..
  1. [ASK] Paint Protection
    By VanBroken in forum Diskusi Perawatan Mobil (Exterior & Interior)
    Last Post: 20th August 2012, 08:03
  2. Paint Protection
    By Zenki136 in forum Diskusi Eksterior
    Last Post: 27th October 2010, 01:59
  3. Paint protection
    By sukamusik in forum Diskusi Eksterior
    Last Post: 9th April 2009, 11:06
  4. ask paint protection...
    By F1z-eeR in forum Diskusi Eksterior
    Last Post: 24th July 2008, 21:19
