Honda New Jazz GE8 Performance Parts
Page 1 of 27 12345 ... LastLast
Results 1 to 10 of 263
  • Short URL:  http://modifika.si/29091
    Honda New Jazz 2008 Performance Parts
    ULTRA RACING STRUTBAR
    Strutbar buatan Malaysia. Didesain fix tanpa stelan.. Sangat mudah pemasangannya (plug & Play) tanpa ubahan apapun pada struktur bodi/chassis Honda New Jazz 2008 anda.
    - Warna: Putih
    - Bahan: Steel with White Coating
    - Ultra Racing Product For New Jazz 2008:
    1. Strutbar Front 2 Titik
    2. Strutbar Rear 2 Titik
    3. Lower Front Bar 4 Titik
    4. Lower Front Bar 2 Titik
    5. Lower Middle Bar 2 Titik
    6. Upper Rear Bar Adjustable 2 Titik
    7. Room Bar Adjustable 2 Titik
    8. Anti Roll Rear Bar 16mm dan 19mm
    9. Fender Bar 3 Titik
    Front Strutbar 2 Point
    Front Lower Bar 2 Point & 4 point
    ...and many more!
    COILOVER KIT
    Brand : KSPORT USA
    Type : Kontrol Pro Damper - Street
    Brief Spec : Adjustable Height-Low & 36 Level Soft-Hard
    Status : Ready Stock
    Installation: Direct Bolt on / Plug & Play (No Need of Modification)
    The Ksport Kontrol Pro Coilover Kit has been designed with professional road racing in mind offering extremely high value and performance.
    1. 36 levels of adjustable dampening
    2. Made from high quality 6061 aluminum with T6 for increased hardness
    3. Compression/Rebound adjustable
    4. Adjustable spring perch for height adjustment
    5. Adjustable body allowing maximum suspension travel
    6. Monotube high pressure design reduces oil leakage
    7. Electroplated body for protection from corrosion and rust
    8. One year limited warranty
    DOWNPIPE & FRONT EXHAUST PIPE
    Brand : Kansai
    Material : Stainless Steel
    Approximately 7HP Power Increase and 8Nm Torque
    KANSAI Exhaust Systems were designed to respond to the desire of so many KANSAI Headers customers wanting to also have a KANSAI Cat-Back exhaust system. CNC Mandrel Bends with TIG welded fittings deliver perfect fit along with the revolutionary design that KANSAI is known for. Customers will enjoy increased horsepower and torque and still maintain legality as KANSAI maintains a db (noise) rating that is street legal and sounds great. No cheap tin can sounding exhaust here!! Now customers can bolt on the power of KANSAI throughout their entire exhaust system.
    BOLT ON MUFFLER
    Brand : HKS Japan
    Type : Silent Hi-Power Muffler
    Brand : J's Racing
    Type : SUS 304 Stainless
    Status : OUT OF STOCK!
    Brand : Spoon
    Type : N1 Muffler
    REPLACEMENT FILTER
    Brand : K & N
    K&N Filter is designed to increase horsepower & acceleration. It's washable/reusable & million mile warranty.
    INTAKE KIT TO OPEN FILTER
    Brand : Simota
    HONDA RED EMBLEM ORI JAPAN
    ORIGINAL HONDA RED EMBLEM Made in Japan
    PERFORMANCE DISC ROTOR
    Brand : Runstop Thailand
    Type : Slotted & Drilled
    Size :
    Front OEM Size (262mm)
    Front Oversize 320mm OUT OF STOCK!
    Rear Oversize 300mm OUT OF STOCK!
    Availability : Front & Rear Disc Rotor
    OEM Size (Curve Slotted & Drilled)
    Front Oversize 320mm Min.17inch Wheels (Curve Slotted & Drilled)
    Rear Oversize 300mm Min.16inch Wheels (Curve Slotted & Drilled)
    BRAKE LINE KIT
    Brand : PRO RS
    Type : Performance Stainless Brake Line Kit
    Number of Hose : 4 Pcs (For 4 Wheels)
    BIG BRAKE KIT - FRONT
    Brand : KSPORT USA
    Type : ProComp Front Big Brake Kit
    Caliper : 6 Pot
    Caliper Color : Orange
    Size : Oversize 286mm (minimum 16inch Wheel)
    Specifications :
    * 6 Piston Aluminum Calipers (Orange)
    * D.O.T. Compliant Stainless Steel Brake Lines
    * Machined Aluminum Hats
    * Carbon Steel Brackets
    * 286mm (11") Large Ventilated Discs (min. 15" wheels required)
    * High quality KSPORT SC5 street brake pads
    PERFORMANCE BRAKE PADS
    Brand : N-Brake Thailand
    Type : NB-P & NA-P
    Availability : Front Pads Only
    NB-P Deluxe (Working Temperature 400 deg)
    NA-P Performance (Working Temperature 800 deg)
    Brand : Delphi Lockheed Japan
    Type : SHP (Super High Performance)
    Brand : Project Mu
    Type : Level Max900i - Circuit Sports (Carbon Metal)
    Working Temperature : 100-900 degree celcius
    CONNECTING RODS
    Brand : K1 Technology
    Type : H-Beam
    PISTON KIT
    Brand : Wiseco
    Type : Forged Piston Kit
    Bore : 73mm (Standard Size)
    Compression : 9,8 - Low Comp
    Note : Complete Piston with Pin & Rings
    THROTTLE CONTROLLER
    Brand : Pivot
    Type : 3-Drive Throttle Controller - SLIM
    Function: Improve Throttle Response
    Feature : Normal Mode, 3 Eco Mode Option & 7 Speed Mode Option
    BOLT ON TURBO KIT
    Brand : Zage
    Power Improvement : >50%
    Status : By Order 4-6 Days!
    installed picture:
    Brand : HSK
    - HKS Turbocharger T25 60T .63 A/R
    - HKS Cast Iron Turbo Exhaust Manifold
    - HKS Downpipe
    - HKS Intercooler 400x128x65mm Inlet 2 inch
    - HKS Aluminum Intercooler Piping
    - HKS Silicone Hoses + Ring Clamp
    - HKS Super Power Flow (SPF) Reloaded Air Filter 150/70mm
    - HKS Blow off Valve SSQV4
    - Turbo Oil Feed Lines & Return
    SAMCO SPORTS SILICONE RADIATOR HOSE KIT
    Color : Blue
    Number of Hose : 2 Pcs
    fell free to call for more details. thx
    bos kalo strut bar untuk CRV 08 ada ga?
    sorry bos, alamatnya dimana yah?
    Quote Originally Posted by jakontil
    untuk crv 2008 udah ada nih.. tp kalo strutbar depan/ruang mesin nya sih gak ada, karna dibalik firewall nya New CRV 2008 udah ada.
    Item strutbar ultra racing untuk CRV 2008:
    - Anti Roll Rear Bar 23mm
    - Lower Front Bar 4 titik
    - Lower Middle Bar 6 titik
    - Lower Rear Bar 2 titik
    alamat bengkel di pondok kelapa deket kalimalang jakarta timur bos.
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Ayo yg udah indent Honda New Jazz 2008 strutbarnya udah instock nih.. hehehe
    CP : Coki Siboro
    2 Hrs 19 Mins 43 Secs
    buatan mana bos???
    Quote Originally Posted by [M] View Post
    buatan mana bos???
    malaysia bos..
    CP : Coki Siboro
    menghadap laut
    21 Hrs 51 Mins 19 Secs
    yg strut bar selagi ada... yg strut bar ...
    Quote Originally Posted by b2sw View Post
    hahahaha
    makasih pak..
    CP : Coki Siboro
    ZiP_Performance@yahoo.com
    46 Mins 53 Secs
    bos coki pm harga buat front and rear donk.. thx
    Quote Originally Posted by ZiP_Performance View Post
    besok gw sms ya bos.. tapi ingetin aja, takut kelupaan..
    CP : Coki Siboro
  1. WTS: engine & performance parts buat jazz ge8
    By red avg in forum Jual Beli Mesin Lainnya
    Last Post: 2nd October 2012, 01:55
  2. FOR SALE : 2ND ALL NEW JAZZ PERFORMANCE PARTS
    By DimazQuixote in forum Jual Beli Mesin Lainnya
    Last Post: 4th October 2010, 05:46
  3. Replies: 82
    Last Post: 1st December 2009, 09:50
