[WTS]Airlift Autopilot DIGITAL (w/Controller)#27600
Results 1 to 10 of 113
  • Short URL:  http://modifika.si/28967
    [S][U][R][A][B][A][Y][A]
    2 Wks 3 Days 10 Hrs 55 Mins 41 Secs
    Mau jokul nih ... Airlift Autopilot Digital (controller). ngga termasuk balon air suspensionnya ya ... Digital controller ONLY !!.
    -Enak ... Cas Cis Cus bisa langsung lihat tekanan pressurenya
    -Otomatis ngisi angin sendiri kalo ada tekanan yang bocor.
    -Mobil di starter ... langsung naik sendiri otomatis ke pre-set level, ngga usah bingung2 untuk setting lagi.
    -Dll
    P/N #27600
    Price 14.5 Jt
    Kondisi 99%
    STOK 1 udah SOLD !!! PM me if you need one
    Bisa di aplikasikan ke air suspension merk lain.
    NB: Airlift products sementara bisa dibeli ke indonesia hanya melalui agent indonesia, harga di angka 16 jt. dan prosesnya bisa sampe 3 bulan.
    Kalo ada yang minat kabarin aja.
    David
    Descriptions
    Add the most advanced system on today's market to your exsisting air suspension system. Get accurate, instant control over your ride with our new Auto Pilot Digital controller. Features that have never been available in a digital control system come standard with this incredible, compact unit. Features such as:
    One touch ride height
    Allows you to return to your ride programmed ride height without tapping switched and watching gauges. Whether your below, or above your height, just tough one button to return to return to your aligned height, and prevent tire wear.
    Auto ride height on start.
    Will lift your vehicle to the programmed ride height with the start of the engine. This feature can be turned off, this is not available in some competitive products.
    Individual wheel control
    Allows you to adjust each wheel separately. Also known as Front back side to side control.
    All inflate and deflate buttons
    Also known as pancake control. Give you 4 wheel height control up and down with one switch.
    Accurate Manifold Mounted Transducers.
    The most accurate pressure sensors come pre-mounted to the valves. This eliminates the risk of leaks, and makes for an easier install.
    Digital Volt Meter
    Reads the vehicles voltage to help prolong equipment and battery life.
    Auto leak Detection
    Will monitor all 4 corners, if a leak occurs, the system will automatically add air accordingly and warn you of a problem.
    Tuning Feature
    Teaches the system the exact requirements to lift each wheel. Ensures that the auto ride height function is perfect every time.
    Only one wire to dash
    Only one wire needs to run to the dash of the vehicle. No more running airlines, power lines. And wiring every switch independently. One wire does it all.
    Kit Includes:
    - (1) Digital Control Panel
    - (1) Digital Control ECU
    - (5) Pezio Pressure Transducers
    - (2) Plug N Play Solenoid Harnesses
    - (1) Ethernet Cable
    - (4) 1/2" PTC to Transducer Fittings
    - (1) Inline Fuse Holder
    PusatREM.com - Surabaya
    Real Brembo GT / AMG (Ready Stock)
    =======> http://www.PusatREM.com <=======
    (PIN BB: 263A3A06)
    uppppppppppp of the night.
    (PIN BB: 263A3A06)
    up lagie buat controllernya
    (PIN BB: 263A3A06)
    up of the dayyy
    (PIN BB: 263A3A06)
    jl.Barito 15 Semarang, Jawa Tengah
    2 Mths 2 Wks 6 Days 40 Mins 19 Secs
    very nice stuff..
    A U T O C R A F T
    wheels , modification , car detailing , nano coating , body repair
    jl. Barito 15 (Timur jl.Karimata) Semarang 50127
    call : 081 575 12 8888 ; 081 805 87 5588 | bbm : autocraf
    pAlembang Yg meMbiNguNgkan
    57 Mins 30 Secs
    BNTU UPZ to the top
    thank you guys udah bantu uppp ... haikkzzz ...
    (PIN BB: 263A3A06)
    up of the dayyyy
    (PIN BB: 263A3A06)
    up lagi ahhhhhhh ...
    (PIN BB: 263A3A06)
    up up....mr.david..plz check your email..thx a lot bro.. =)
    A U T O C R A F T
  1. wts: controller + dual compressor airlift
    By herman in forum Bursa Kaki Lainnya
    Last Post: 24th June 2011, 15:12
  2. Replies: 15
    Last Post: 16th February 2010, 10:55
  3. Replies: 0
    Last Post: 10th June 2009, 10:28
  4. Replies: 237
    Last Post: 8th August 2008, 07:29
  5. [WTS] AIR SUSPENSION (Airlift) + DIGITAL (Ex Galant)
    By davetrends in forum Bursa Kaki Lainnya
    Last Post: 29th March 2008, 15:58
