Hiquphon tweeter, please review..
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/2838
    Jakarta - Tomang - Glodok
    10 Hrs 18 Mins 39 Secs
    mau tanya pendapat para master dong, nih tweeter karakternya bgm?
    apa perbedaan antara OW1, OW2, OW3 ?
    juga kalo bisa harga barunya ..
    kalo dibandingin ama vifa yg XT-25 bgm? dalam segi natural dan ambience?
    tq..
    GBU
    1 Hr 28 Mins 10 Secs
    wah, hiquphon dibanding ma vifa kok rasanya nda banding ya.. mungkin ma scanspeak de baru tepat..
    harganya beda jauh bos..
    xt25 1jt an, hiquphon ow1g 3jt an..
    menurut gue, hiquphon alus banget sampe kerasa highnya agak kurang gitu.. sekilas hiquphon "mirip" midrange wekekekek...
    kalo bisa cari power yg highnya bagus baru pas de..
    Helix HXA500 ++
    Capasitor Banks (DIY)
    Cables by Flux
    kalo ama tweeternya seas orchestra bgm? OW1-G 2jt dapet baru tuh, murah gak?
    HU : Nak CD-700 + MF-51
    FR Speks: RS Advanced
    Sub : RS C 8
    Power FR : Brax X.2000
    Power Sub : RF BD500.1
    RCA : Acoustic Zen WOW + Cardas
    Click this:
    http://julsjazz.multiply.com/
    gua mau nih kalo segitu, beli dimana bro?
    ow1g 2jt murah banget tuh, baru ato 2nd ?
    Helix HXA500 ++
    Cables by Flux
    Manado
    11 Hrs 10 Mins 15 Secs
    di audiomobil ada tu bulan desember
    Batavija
    9 Hrs 14 Mins 30 Secs
    coba liat dan pelajari di:
    http://ldsg.snippets.org/sect-1.php3#TWEETERS
    and
    Driver recommendations - Hiquphon
    Hiquphon is a boutique manufacturer of OEM 3/4" dome tweeters and custom air core inductors. Like Skaaning, this is a labor of love for one dedicated and talented designer. Unlike Skaaning, Hiquphon's tweeters are priced within the reach of the average DIY'er. Despite being an OEM selling to such prestigious high-end vendors such as Fried and ProAc, Hiquphon does offer a limited number of "standard" tweeters. Each model comes in matched (+/- 0.5 dB) pairs with individual (and extremely accurate) curves and design data for each driver. Common characteristics include an outrageously high 0.9 mm Xmax (2.2 mm pk-pk physical excursion), 8 ohm impedance, and advertised distortion under 0.2%. Bucking current practice, but similar to the Scan-Speak Revelator, Hiquphon eschews the use of ferrofluid.
    1. The OWI (D2094-8708-03) is a lower sensitivity (87 dB/W/m) tweeter with, quite literally, ruler flat response on-axis from 2 kHz out past 20 kHz. Response at 20 kHz is only 5 dB down at 30 degrees off-axis. The design goal of the OWI is extreme smoothness and listenability. response waterfall
    2. The OWII (D2094-9008-03) has slightly higher sensitivity (90 dB/W/m) than the OWI with slightly less flat response. This is deliberate. A small "shelf" in the response from 2-5 kHz is designed to complement midrange or bid/bass drivers with a slightly rising high end response. Even with this FR contouring, for any other tweeter, this would considered excellent performance! Off-axis Performance is actually better than the OWI, being only 3 dB down at 20 kHz. The design goal of the OWII is analytically precise transient response. response waterfall
    3. The OWIII (D2094-8908-G3) "gold dome" tweeter is essentially the OWII with a gold dome. Modified versions of this unit can be ordered to match the Bud Fried designs, including the use of ferrofluid.
    Note:
    The Hiquphon OW I/II/III, along with the AccutonC223/6, Human 002, Scan-Speak R2904/7000, Morel MDM33, and the Alison Acoustics 4010203 (available only as a replacement part for Allison loudspeakers) are considered by many to be the ultimate electrodynamic tweeters.
    Hiquphon distributors & dealers:
    North America
    Zalytron,
    Norway
    Musical Transparency
    International:
    Direct from the Hiquphon web site
    Batavija
    also:
    bagian:
    Driver guidelines - Tweeters:
    Prior to ca. 1960, the predominant tweeter designs were either cones or horns. Cones were generally found in lower priced consumer gear and horns were more often found in audiophile systems. Since that time, dome tweeters have pretty much supplanted both. Cone tweeters have always suffered from problems with beaming and resonances, while horns have always been expensive to manufacture and tricky to get right. Domes, on the other hand, can be as cheap and easy to work with as cones, while still challenging horns on sound quality (but not efficiency).
    Early domes tended to be made of hard plastics or soft treated fabric. Current technology uses a variety of materials as noted in Appendix B above.
    For DIY projects, most of my respondents recommend sticking to 1" (25 mm.) dome tweeters and avoiding the 3/4" units altogether. I've generally (more on this qualified statement in a moment) followed this advice because it's easy to see why. There are few things that a smaller dome tweeter can do that a 1" dome can't. Add to that the facts that a smaller dome will almost certainly have lower power handling and have to be crossed over at a higher frequency. Still, I have included a select few smaller domes for those who want the slight edge they offer in extended and off-axis response. It's still fairly safe to recommend against using one in anything less than a 3-way system (although even this has been done successfully in a handful of commercial systems).
    Having said this, I have to note that there exists a small minority of 3/4" dome tweeters that turn this advice on its ear! Most significantly, the line of 3/4" domes from Hiquphon are among the best dome tweeters in the world and certainly an outstanding value.
    A fairly recent addition to the technology of dome tweeters is the use of ferrofluid. Ferrofluid isn't a single material, but a class of some 50 magnetically and thermally conductive liquids of varying viscosities which are used to fill the gap around a tweeter's voice coil, thus providing heat dissipation (i.e. greater power handling), mechanical damping, and lowered mechanical resonance. Still, some manufacturers (Scan-Speak and Hiquphon) have moved away from using ferrofluid in their top-of-the-line tweeters, claiming improved transient response and transparency.
    Batavija
    Excellent frequency linearity 2 - 20 kHz +/- 1 dB typical
    Excellent phase linearity
    Smooth roll-off at high frequencies
    Low and well controlled resonance frequency
    Well controlled damped low frequency response, soft raising
    Very broad-banded (2.0 kHz to 27 kHz)
    Fast transient response
    Very low distortion
    A-periodic damped moving system
    Exponential phase-correction horn-loaded
    Saturated magnet gap for low magnetic distortion
    Perfect sealed housing
    Heavy duty connectors for 2.5 mm2 lead wire
    Excellent, mechanical robust, non-vibrating, soldering contact
    Shock absorbing construction
    Matched pairs within 0.5 dB in frequency range 2-20 kHz (OW types only)
    Beautiful sound capabilities
    well ini mah kata org2 masi kalah lah ama merk lain, apa lagi ring radiator
    cuman gue suka, soalnya soft bgt, cocok bgt ama selera gue
    cheers
    selera ya.. kalo menurut gue hiquphon kurang detail si..
    Helix HXA500 ++
    Cables by Flux
Venom 300x250 GT Radial
  1. FS: HI END TWEETER HIQUPHON BY OSKAR WROENDING I
    By EL84 in forum Speaker - SubWoofer
    Last Post: 17th January 2012, 08:16
  2. fs: Tweeter Hiquphon
    By mo_bb in forum Speaker - SubWoofer
    Last Post: 24th August 2011, 19:23
  3. Jual seken Tweeter HIQUPHON OW1 Dan Midbass DYN
    By chandra_suparman in forum Speaker - SubWoofer
    Last Post: 2nd August 2011, 01:24
  4. Tweeter hiquphon
    By envyboyz1 in forum Diskusi Speaker
    Last Post: 26th September 2009, 21:28
  5. Review Tweeter Hiquphon OW3 dong
    By Gunblade in forum Diskusi Speaker
    Last Post: 26th September 2009, 21:11
