Scuto Laminating Simota Bro Togel
Results 1 to 10 of 85
  • Short URL:  http://modifika.si/281013
    PangkaL Paha
    2 Wks 4 Days 16 Hrs 43 Mins 33 Secs
    [WTS] ALPINE PMX T320 AMPLIFIER 2 CHANNEL [SOLD]
    Spoiler for real pic: Show
    Alpine PMX-T320 2 channel car amplifier
    Alpine PMX-T320 give you power performance at an amazing price. Alpine PMX-T320 is designed to fit easily in any system. Alpine PMX-T320 car amplifier has a built-in high pass and low pass filters let you set the frequency points to match your speakers and ensure optimum efficiency. Alpine PMX-T320 also enhance their performance with Bass EQ, now you can get even more powerful bass.
    Alpine PMX-T320 features:
    • Amplifier Type: Class-A/B
    • 320 watts 2 channel amplifier
    • Per Channel into 4ohms (≤1%THD+N): 2 x 50W
    • Per Channel into 2ohms (≤1%THD+N): 2 x 75W
    • Bridged into 4ohms (≤1%THD+N): 1 x 150W
    • Channel Design: 2/1 Channel
    • Thermal Control: Thermal Management Control
    • Power Supply: DC-DC PWM Power Supply
    • Power Supply Design: MOSFET Power
    • Board Circuitry: STAR Circuitry
    • Current Protection: Over-Current, Over-Voltage and Thermal Protection
    • Power Indicator: Top Mounted Blue LED Power Indicator
    • RCA Output: Gold Plated RCA Input Connectors
    • Speaker-Level Inputs: Speaker Level Inputs
    • Crossover: Selectable Low-Pass / High-Pass
    • Connector Plating: Gold Plated Input, Output, Power and Speaker Terminals
    • Pre-Amp Stage: Discrete
    • Final Outputs: Non-Fading Pre-Amp Output
    • Gain Control: Continuously Adjustable Gain Control
    • Crossover Frequency (Fix, OFF/LPF/HPF Selectable) 1/2 ch: 80 Hz (-18dB/oct)
    • EQ (Equalizer): Bass EQ Fixed Frequency 50 Hz _ Selectable Gain 0/+6/+12 dB (3/4ch)
    • Power Requirements: 14.4 V DC (11 V to 16 V)
    • Input Sensitivity: 0.2 - 4.0 V (RCA IN)
    • Input Impedance: RCA IN 10k Ω / SP IN 10k Ω
    • Frequency Response: 10 Hz - 50 kHz (+ 0,-1 dB)
    • Speaker Impedance: 4 or 2 Ω
    • Signal to Noise: S/N Ratio (IHF A Weighted, Reference: rated power into 4ohms) 90 dB
    • Weight: 2.0 Kg
    • Footprint: 210 mm x 60 mm x 242 mm
    For more info plz look up :
    http://www.alpine-asia.com/indonesia...187&Itemid=262
    Lokasi Jakarta Barat/Selatan
    Kondisi super mantab
    Comes with manual book
    Original box and plastic wrap
  2. HJTOWIN
    PangkaL Paha
    up up up..
    klaten
    keluar teyus koleksinya...
    1 Wk 2 Days 4 Hrs 21 Mins 35 Secs
    ckckckck............
    PangkaL Paha
    sundul ganz...
    bandunk
    19 Hrs 23 Mins 22 Secs
    wow koleksinya banyak amir bang
    PangkaL Paha
    jiahhh dikata perangko kali ya koleksi
    PangkaL Paha
    sundul.....!!
    PangkaL Paha
    sundul gan
    Sin City - Jakarta
    3 Wks 4 Days 19 Hrs 5 Mins 38 Secs
    numpang ganti ya bangggggg
  1. [JUAL] Amplifier 4 channel VOX VA 100.4S.
    By RV in forum Power Amplifier
    Last Post: 30th November 2011, 11:34
  2. [WTS] ALPINE CENTER CHANNEL SPEAKER + AMPLIFIER (2ND)
    By dimsaudio in forum Speaker - SubWoofer
    Last Post: 26th July 2011, 14:15
  3. WTS amplifier precision power 5 channel murah
    By yahyabahanan in forum Power Amplifier
    Last Post: 31st January 2011, 18:03
  4. Replies: 36
    Last Post: 17th September 2009, 19:27
