9853 VS 8650
Results 1 to 10 of 26
Thread: 9853 VS 8650
  • Short URL:  http://modifika.si/2718
    R!0
    9853 VS 8650
    helo kk2 yang baek, g mo tanya 9853 ato 8650 yang lebih bagus sih buat sq? trus ada yang mo jual secondnya gak? tpi kondisi harus bagus yang pasti jangan bekas rusak, diservice trus di jual. Kalo ada yang mo jual 9833 juga boleh tuh.
    1 Hr 28 Mins 10 Secs
    waduh, menurut gue daripada 9853 mending 9833 de..
    kalo bandingin ma 8650 ada keunggulan dan kekurangan sendiri2..
    Helix HXA500 ++
    Capasitor Banks (DIY)
    Cables by Flux
    lu demen yang rebet kaga?
    kalo gak demen rebet pake 86
    demen entertainment pake 86
    demen suara yang "clear" pake 86
    wakakaka.. ini dia "pioneer complex"
    Helix HXA500 ++
    Cables by Flux
    Manado
    11 Hrs 10 Mins 15 Secs
    waduh masa alpine dibilang ribet si
    demen ELEGANT pake 9853
    demen suara jernih abiz pake 9853
    demen tampilan NON DANCING DOLPHIN pake9853
    apa lagi y
    Manado
    oh iya
    demen teknologi glidetouch yg keren ? 9853 donk
    kalo ini "alpine complex".. wakakakaka...
    Helix HXA500 ++
    Cables by Flux
    satyr
    kalo ama 53 sih g masi pilih 8650 kalo ama 9855 baru pilih 9855
    Manado
    perbandingan dari sounddomain
    Nih perbandingan g ambil dari sounddomain.com
    Alpine CDA-9835 vs. Pioneer DEH-8600MP - THE REVIEW!
    After reading numerous posts concerning the "vs." topic of Alpine and Pioneer i've decided to post my review of these two HU's.
    Pleasy note that my opinion is my opinion and is VERY subjective (as everything that concerns the term "sound quality") so do not rely solely on my words - just take them into consideration.
    THE LOOKS. Although the design is very subjective but i prefer Alpine over Pioneer.
    ERGONOMICS. Alpine wins hands down. I just can't understand why guys at Pioneer decided to place a separate button for Traffic Announcement! It would be much wiser to place a mute button (for that you should buy a steering wheel remote which ,of course, is sold separately). Then there is no pause button. you have to make 3 presses on multifunction key to pause (or two - if you have steering remote). That is, again, is very annoying. On the contrary Alpine has both pause and mute buttons which are positioned for maximum comfort. Also, on Alpine, when you press to de-mute, the volume returnes smoothly unlike Pioneer which doesn't have such feature.
    PERFORMANCE.
    Speaking of performance Pioneer shines in mp3 area. I have an extensive array of mixes so one songs blends into another seamlessly. Alpine ruins that with its awful 2 second gap between songs. On Pioneer the gap is 1.5 seconds but you can turn of the Tag reading - and the gap is no more! 0 seconds just like CD-audio. Also the navigation of Pioneer is organized way better than alpine's. With Pio you can search subfolders and the whole search is a breeze. Alpine cannot show subfolders which is very annoying since it prevents you from creating a highly organized CD. But on the other hand when you select a song within specified folder with the next search Pio will revert to the root folder. Alpine will on the other hand show the currently played file within the active folder...
    As for sound quality - Alpine is a solid winner. I know that Pio uses Burr-Browns DAC and the signature of this DAC is EXTREMELY detailed midrange and highs. But the lows are somewhat muddy and boomy and there is no such astonishing separation between lows, mids and highs in Pio as in Alpine. Alpine has a much FIRMER bass and also because of the fact that Pio uses Graphic EQ (which has fixed Q and frequencies) you cannot control the sound the way you want. With Alpine the bass is not only firmer but it also much more pronounced at extreme lows (20-50 Hz). There were lots of songs were i\d hear the bass rolloff down to 30 Hz and on Pio i just didn't hear it! It feels like a "hole" in music when you know that now you will hear the bass but you don't hear it at all! Very annoying! Also, Pio's BBE and loudness are pathetic as they boost low and high frequencies too much which result in listening fatigue...
    Next is the Time Aligment feature. On Pio the realisation of Time Correction is done quite badly. First you HAVE TO CHOOSE your listening position. That, instantly kills the spaciousness of sound but even when you try to time correct the sound it just doesn't corrects at all! I didn't hear ANY "sound shifting"!
    On Alpine Time Correction works magic. Sound shifts as you turn the knob and the whole customization takes a few minutes (if you'll read the manual carefully). Also, unlike in Pio, on Alpine you can choose your own listening spot which makes sound customization much more flexible.
    Pio's Auto EQ is another pathetic "mambo-jumbo". Many people here in forums thought that Auto EQ adjusts EQ for optimal balance of frequencies but it is not true - the idea behind Auto EQ is the creation of flat response EQ curve and you will further adjust the sound based on the Auto EQ. But even this cannot help Pio from generatin muffled and muddy bass...That is said, Alpine has much more clear sound.
    Also i couldn's figure the difference between COMP1 COMP2 and BMX sound enhancers in Pio...What they did is clearly boosting high frequencies and COMP does really awful job by attenuating fragments of music that sound too loud so the whole "attack" of several compositions (like intro of "Jam" Michael Jackson) seems suppressed...Very strange...
    I think that guys at Pio made a big mistake when they buffed up this HU with so many sound enhancers....I think that the less the distortion of sound the better is for the ears...
    I hate Alpine's Medix Xpander as it kills "airy" feeling in some songs...I'd rather go with less bass but with more spaciousness...
    That said, the sound comtrol of Alpine is leagues away from Pio in terms of simplicity and of course the parametric EQ...
    At the end i would like to say that i will NOT buy Pio -i am now Alpine user (i've owned 9815 but it was stolen - it was a great unit but 9835's sound is better)...And the BioLite display looks more "pro'ish" that swimming dolphins of Pio...
    BOTTOM LINE.
    The main and the only advantage of Pio over Alpine is its ability of seamless transition between mp3 tracks + very good navigation.
    Considering all other features, Alpine is the king.
    Thank you for your reading and patience.
    I would be grateful to hear some valuable comments and criticism.
    And let the music thrill your senses...
    - Tenhauser -
    hahaha.. no comment de..
    menurut gue si tetep aja kembali ke selera.. ehehe..
    Helix HXA500 ++
    Cables by Flux
GT Radial NGK Busi
  1. alpine 9853 or pioneer 8650
    By veilsidenrico in forum Diskusi Head Unit & Processor
    Last Post: 9th May 2007, 16:02
  2. Pio DEH 8650
    By laguna in forum Diskusi Head Unit & Processor
    Last Post: 1st October 2006, 17:27
  3. Pio 8650 vs 6850
    By wil's in forum Diskusi Head Unit & Processor
    Last Post: 23rd May 2006, 11:29
  4. pio 8650 vs alp 9855
    By ghonks in forum Diskusi Head Unit & Processor
    Last Post: 18th January 2006, 11:24
  5. DEH 8650 OR CDA 9853 ???
    By FA in forum Diskusi Head Unit & Processor
    Last Post: 17th January 2006, 07:57
