GUDE BULFROG CAMSHAFT DEALER IN INDONESIA - Page 5
Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
  • Short URL:  http://modifika.si/268700
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    ON SALE TURBO TIMER PIVOT TYPE TTX ORIGINAL HARGA 650 RIBU SELAMA BULAN NOVEMBER
    FOR ORDER CALL/WHATSAPP:081382077777(HANZ SPEEDZ)
  2. #42
    cipondoh-tangerang
    dear all SPEEDZ PERFORMANCE customer u can contact me at 081382077777(telkomsel) ,085882077777(matrix) or 99199777(esia).or 7afb1b53(bbm).for HANZ SPEEDZ..
  3. #43
    cipondoh-tangerang
  4. #44
    cipondoh-tangerang
  5. #45
    cipondoh-tangerang
    ++++PROMO BIG BRAKE KIT AP RACING AND BREMBO++++++
    WE BRING GENUINE BIG BRAKE KIT BREMBO AND AP RACING,WE SUPPLY FOR INDONESIA AND MALAYSIA MARKET AND MANY INSTALLATION IN CUSTOMER CAR.
    ************* AP RACING MADE IN UNITED KINGDOM ***********
    *****NEW RADI-CAL(NEW DESIGN)**********
    -CP 8520 NEW RADI-CAL CALIPER 6 POT ,AP DISCBRAKE 355MM FLOATING SLOTTED ,AP BRAKE PAD APF 404,AP BRAKE HOSE HARGA 39 JT (BLACK) DAN HARGA 40,5 JT (RED)
    **AP DISCBRAKE 362 MM FLOATING SLOTTED 42 JT.
    **AP DISCBRAKE 380MM FLOATING SLOTTED 45 JT.
    -CP 8530 NEW RADI-CAL CALIPER 4 POT,AP DISCBRAKE 330MM FLOATING SLOTTED , AP BRAKE PAD APF 404. AP BRAKE HOSE HARGA 32JT (BLACK ) DAN HARGA 33,5 JT(RED)
    **AP DISCBRAKE 345MM FLOATING SLOTTED HARGA 35JT.
    **AP DISCBRAKE 355MM FLOATING SLOTTED HARGA 38 JT.
    -CP7600 BLACK CALIPER 4 POT , AP DISCBRAKE 295MM FLOATING SLOTTED .AP BRAKE PAD APF 404 .BRAKE HOSE HARGA 24 JT.
    -CP 5200 BLACK CALIPER 4 POT , AP DISCBRAKE FLOATING SLOTTED 330MM, AP BRAKE PAD APF 404, BRAKE HOSE DENGAN HARGA 27 JT DAN 28,5 JT APABILA RED CALIPER.
    -CP 5040 RACE CALIPER 4 POT, AP DISCBRAKE FLOATING SLOTTED 330MM, AP BRAKE PAD APF 402, BRAKE HOSE HARGA 34 JT.
    -CP 9040 BLACK CALIPER 6 POT , AP DISCBRAKE 355MM FLOATING SLOTTED , AP BRAKE PAD APF 404, BRAKE HOSE HARGA 34 JT DAN 35,5 JT APABILA RED CALIPER.
    **DENGAN DISCBRAKE FLOATING SLOTTED 362MM HARGA 36 JT.
    ********** BREMBO MADE IN ITALY **************
    -BREMBO GT 4 POT,BREMBO BRAKE PAD,BRAKE HOSE WITH CENTER BELL PLUG & PLAY ALUMUNIUM AND ADAPTOR.
    **DENGAN DISCBRAKE FLOATING DRILLED 330MM HARGA 34 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 345MM HARGA 36 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 355MM HARGA 37 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 380MM HARGA 39 JT.
    -BREMBO 17Z 6 POT,BREMBO BRAKE PAD,WITH CENTER BELL PLUG & PLAY ALUMUNIUM AND ADAPTOR DENGAN DISCBRAKE FLOATING DRILLED 355MM HARGA 37 JT.
    -BREMBO 19Z 6 POT ,BREMBO BRAKE PAD WITH CENTER BELL PLUG & PLAY ALUMUNIUM , AND ADAPTOR DENGAN DISCBRAKE 380MM FLOATING DRILLED HARGA 43 JT.
    **DENGAN FLOATING DRILLED DISCBRAKE 380MM HARGA 45 JT.
    -BREMBO GT 6 POT.BREMBO BRAKE PAD GT,BRAKE HOSE WITH CENTER BELL PLUG N PLAY ALUMUNIUM DAN ADAPTOR.
    **DENGAN DISCBRAKE FLOATING DRILLED 355MM(BUAT VELG MINIMAL 18 INCH) HARGA 45 JT.
    **DENGAN DISCBRAKE FLOATING DRILLED 380 MM(BUAT VELG MINIMAL 19 INCH ) HARGA 47 JT.
    **DENGAN DISCBRAKE FLOATING DRILLED 405MM(BUAT VELG MINIMAL 20 INCH) HARGA 49 JT.
    -BREMBO REAR PORSCHE NEW CAYENNE CALIPER (FOR REAR USE ONLY),BREMBO BRAKE PAD WITH DISCBRAKE 345MM FLOATING DRILLED HARGA 34 JT.
    **DISCBRAKE 380MM FLOATING DRILLED HARGA 37 JT.
    -BREMBO 4POT MODEL 7L6 (FOR REAR USE ONLY ),BREMBO BRAKE PAD WITH DISCBRAKE 345MM FLOATING DRILLED HARGA 32 JT.
    **DISCBRAKE 380MM FLOATING DRILLED HARGA 35 JT.
    FOR ORDER CALL/WHATSAPP:081382077777/085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT 10150
NGK Busi GT Radial
  1. wts - camshaft toda A b series & bulfrog hccs 8 d series
    By m.b.s in forum Jual Beli Mesin Lainnya
    Last Post: 27th March 2012, 23:35
  2. Replies: 13
    Last Post: 24th January 2012, 23:20
  3. Replies: 13
    Last Post: 24th January 2010, 21:54
