CITY / JAZZ : Re-Setting ECU & Re-Calibrate CVT
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/2682
    JKT-PIK
    1 Mth 2 Wks 1 Day 4 Hrs 50 Mins 7 Secs
    There’s some Honda City or Jazz/Fit owners didn’t know that when they (someone/mechanics) are take-off the car’s terminal battery will be reset the car’s ECU and the CVT gearbox which will affects the engine’s performance and fuel consumption.
    This is why you need to reset the ECU and recalibrate the CVT's start-up clutch 'release' position, because engagement of the start-up clutch (when you shift from P or N into D) is via hydraulics and activated by the ECU via sensors, once you reset the ECU, you need to let it detect when the start-up clutch is at full engage (what they call 'lock-up') and when it's at full release.
    The best way to do this is to get your Honda service center to do it as there is a specific procedure for it. If you don't, the ECU may not have the start-up clutch in the fully released or fully engaged positions when it needs to be and you may end up with very bad fuel consumption.
    This has actually been reported by a number of owners who has been reset their ECU without doing the proper CTV recalibration procedure. They have reported poor engine’s performance & very bad fuel consumption but it was solved after the Honda service center did the proper recalibration procedure for them.
    Now days, people are already knew how to resetting the Honda car’s ECU but doesn’t know about recalibrating the CVT gearbox which this is might be the one of the reasons for some City & Jazz/Fit owners had a start-up clutch failure that has been reported.
    Below is the right proper procedure for resetting & recalibrating ECU/CVT, hope all City & Jazz owners will be noticed the gain performance & fuel economy.
    RESETTING ECU & CALIBRATING CVT GEARBOX PROCEDURE.
    a) Take off the positive (+) cable terminal from the car’s battery including all car accessories and all fuses of car audio to prevent electrical power coming from audio’s capacitors.
    b) Switch-on the car’s headlamps for 10 to 15 minutes to discharge the remaining electrical power inside the car’s ECU (even better if you leave the car overnight).
    c) Switch-Off the car’s headlamp & re-installed the positive (+) cable terminal to the car’s battery.
    d) Start the engine but DO NOT switch-on your air-conditioner, audio/radio, lights, and other electrical stuff. Let the engine runs until the engine’s cold-indicator is off (approx. 15 to 20 minutes) or until the engine reached its normal temperature (usually recognized when the radiator’s fan is turn-on).
    e) Switch-Off the engine and Restart it again.
    f) Switch-On the car’s front headlamps.
    g) Shift the gear from “P? to 'N' while stepping on the brake.
    h) Shift the gear between 'N' to 'D' to 'S' to 'L' then from 'S' to 'D' and back to 'N' again.
    i) Repeated this Gear’s shifting (h) process about 3 times with approximately 1-2 seconds between the gears shifting.
    Please be kindly reply back to this forum after resetting & recalibrating your car’s ECU & CVT gearbox to reports its performance & fuel economy. Thanks…
    TSVC
    2 Wks 1 Day 21 Hrs 24 Mins 39 Secs
    kagak ngerti bahasanya....please language indonesia talking
    3 Wks 1 Day 8 Hrs 46 Mins 6 Secs
    be ..tuulll pakai bhs indonesia aja ,mungkin ada yg bisa bantu terjemahkan ke bhs indo.
    JKT-PIK
    Busyet dahhh...hari geneeee gak ngerti Inggris...buka kamus dong...
    Yang pasti ini bisa nolong bikin mobil lebih kenceng ama irit bensin...
    Yahhh sekalian belajar Inggris gratis sambil buka kamus Inggris plus mobil kenceng...
    Ini udah gue coba di mobil gue...BENERAN!!! Tambah tarikan + irit....Thx...
    TSVC
    maklum tinggal di daerah jakarta coret...parung....
    ya udah ntar gw pake transtool aja...
    Bung, info ini elo dapat dr mana ?
    Apa dr Honda official website atau ??
    Tertarik mau coba jg tp perlu diyakinin dulu apa beneran nih...
    kesimpulannya : deactivated aki (cabut terminal negatif aki) sekitar kurang lebih 30 menit, ecu akan ter-reset (settingan balik lagi ke default). jadi setelah itu, kira-2 200 km pertama setelah reset ecu, si ecu akan mempelajari dan menyesuaikan perintah-nya ke sensor-2 berdasarkan driving style loe.....ini kayaknya yg dibilang si zig3n yg katanya bisa bikin nambah akselerasi + nambah irit ato nambah boros......
    1 Mth 5 Days 22 Hrs 29 Mins 47 Secs
    kalau ada pengantian yg dikontrol dengan ecu sebaiknya direset biar optimal sih seperti ganti intake, header, exhaust, bensin, busi,etc.
    kalau cabut baterainya cuman sebentar kelihatannya ecunya ngak kereset atau lebih baik cabut sekringnya ecu biasanya kereset sih.
    itu memang dari officialnya honda or handbooknya kalau diluar negeri dikasih tau cara reset ecu dan selanjutnya. kalau bukunya diindo perasaan ngak dikasih tau.
    tar ecunya ke lock lagih.. nangis deh..
    NEED FOR SAFE
    Re: CITY / JAZZ : Re-Setting ECU & Re-Calibrate CVT
    Quote Originally Posted by zig3n
    i) Repeated this Gear’s shifting (h) process about 3 times with approximately 1-2 seconds between the gears shifting. …
    wah kaya Game amet yah .. mo mesti pake kode , *jadi inget dulu game dragonball di SNES buat ngeluarin secret carracter.. "Kakaroto.." *
    hehehe..
Wuling GT Radial
  1. Beda setting mobil Iasca (Honda City) dengan yang lain?
    By Steve in forum Diskusi Instalasi
    Last Post: 25th April 2009, 01:15
  2. Setting AFR City Z
    By arieatc in forum Diskusi Mesin
    Last Post: 22nd November 2008, 15:01
  3. Setting Honda City Z
    Last Post: 8th November 2008, 14:18
  4. mo setting audio u new city
    By amd_08 in forum Diskusi Speaker
    Last Post: 6th April 2008, 23:46
  5. Setting audio buat City
    By edinur in forum Diskusi Instalasi
    Last Post: 14th February 2008, 18:34
