WTA buat XO pasive or beli aktiv
Results 1 to 10 of 34
  • Short URL:  http://modifika.si/261023
    2 Wks 3 Days 21 Hrs 7 Mins 29 Secs
    Bro yg pinter smua, mohon pencerahan...
    Saat ini terpasang : HU Bremen MP76
    Power Concept HP.65.4
    Power PPI 280
    Sub JL Audio W3V2 12 inch
    Speaker split 2way oz audio matrix elite cs180
    dengan spek speaker :
    * Sensitivity: 91.5 dB
    * RMS Power Range : 100 Watts
    * Peak Power Handling: 200 Watts
    * Frequency response: 35-5000 Hz
    * Diameter: 6.5 Inch
    spek tweter :
    * Cone Material: Coated Silk/Cotton
    * Voice Coil Diameter: 1" (25mm)
    * Magnet Weight: 0.43oz
    * Sensitivity: 90db
    * Frequency Response: 1,000Hz - 20,000Hz
    * RMS/Peak Power: 50/100
    * Fs: 1100 Hz
    * Qms: 10.251
    * Qes: 0.5376
    * Qts: 0.51
    * Re: 4.0 Ohm
    * VAS: 0040 M3/.141 ft3
    Pingin naikan kualitas vokal dan detil, rencana beli seas lotus RM120 dgn spek :
    - Nominal Impedance: 4 Ohm
    - Sensitive: 90.5 spl
    - FS: 71 HZ
    - frequency range: 100-4000 Hz
    - Power Handling: 110 watts RMS
    - Mounting Cut Out: 99 mm
    - Mounting Depth: 67 mm
    - Rec. enclosure Size: 1,1 liter
    Karena mo pasang midrange ada 2 alternatif pilihan :
    1. Buat custom pasive tuk tweter n midrnge budget 1 jt max
    2. Bli XO aktiv nakamichi ec 302 dgn harga seken 1 jtan
    EC-302
    Filter Slope: 18dB/octave
    Crossover Frequencies: 10-310Hz/100Hz - 3.1kHz/500Hz - 15.5kHz
    Total Harmonic Distortion: 0.003%
    Signal-to Noise Ratio: Better than 105dB
    Input Level/Impedance: 1V/10kohm
    Output Level/Impedance: 0-2V variable/1kohm
    Maximum Input Level: 3.5V
    Current Consumption: 250mA max.
    Approximate Weight: 1.0kg/2lbs. 3oz.
    Mohon masukan temen2 yg pinter, dengan budget 1jtan pilhan XO mana yang tebaik....
    Cirebon-Depok
    2 Wks 4 Days 16 Hrs 37 Mins 17 Secs
    Vote for EC-302 (asal settingnya bener ya)
    "KAYU DEWA" Mangga Dua Mall - Sunter - Jakarta
    4 Mths 16 Hrs 38 Mins 38 Secs
    vote pasif lah....suara OK...
    Kayu Dewa, Legend7N RCA Cable, Transparent Speaker Cable
    http://copycdaudiophile.blogspot.com/
    "No EQ with Good Treatment"
    Matrix 0816837719 (Whatsapp)
    Pin BB 51ECF989
    Pekanbaru - Riau
    1 Mth 2 Wks 22 Hrs 42 Mins 41 Secs
    lebi baik custom passive X-over, tp budget sgtu berat berat yah.... mao suaranya bagus en bener minimal kluarin duit 2jt lah...
    1 Wk 2 Days 6 Hrs 27 Mins 49 Secs
    Stubuh ama om ice...x-over dongggg tp budget mesti 2jtaan tuhhh
    ya itu masalahnya...
    klo buat pasive dari baca2 thread harus ketemu ama pembuat pasive yg bener dan tidak murah...let say bisa 2 jutaan lebih. Padahal budget cekak bgt.
    Klo bli nakamichi ec 302 dgn harga seken 1 jtan, hasilnya tidak sebaik klo pake pasive.
    Apa mesti nambah budget tuk pasive?
    or ada rekomendasi instaler jakarta barat yang biasa seting nakamichi ec 302 dgn hasil memuaskan
    Bexazi ..
    Quote Originally Posted by Hepi3friend View Post
    Tul btul btul ..
    Bikin pasif ada david neusound, dll.
    Nabung dikit bos spy puaasss ..
    Dari jln ke bursa audio rupanya ada yg jual pasive. klo bli pasive seken apa bisa dipakai?
    Jakarta Selatan
    4 Wks 14 Hrs 31 Mins
    belom tentu cocok bos..
    Blom tentu cocok...berarti bisa saja cocok ya bro.
    Katanlah klo spek speakernya mirip2 ...itu bisa cocok?
  1. Beli >> PASIVE X-OVER CUSTOM KHUSUS 3 WAY...
    By ChipiT in forum Bursa Audio Lainnya
    Last Post: 2nd May 2011, 08:43
  2. [ASK] Sub aktiv
    By Ariz in forum Diskusi Subwoofer
    Last Post: 15th June 2010, 09:27
  3. Sub aktiv 10" SIP
    By henrick in forum Speaker - SubWoofer
    Last Post: 29th April 2010, 07:48
  4. subwoofer aktiv
    By bang juri in forum Diskusi Subwoofer
    Last Post: 7th June 2007, 13:51
  5. (ask) Under seat Aktiv Sub
    By rahargo in forum Diskusi Subwoofer
    Last Post: 28th February 2007, 13:16
