Jual=Hi End POWER MONOBLOCK COUNTERPOINT Natural Progression Mono (Top of The Line)
Results 1 to 10 of 12
  • Short URL:  http://modifika.si/259591
    YOGYA CITY
    2 Days 3 Hrs 33 Mins 58 Secs
    TOP OF THE LINE dari PRODUCT COUNTER POINT HI END AUDIO USA
    Hybrid MONOBLOCK COUNTERPOINT Natural Progression Mono
    - Monophonic. Tube voltage amplification
    - IGBT output. 150/W 8 ohms, 300W 4 ohms, 500W/2 ohms.
    - Menggunakan 6 tabung = 6DJ8 x 4 dan 6CA4 x 2
    - Ada Balanced XLR Input dan dual RCA input
    - Bi Wire Out Put Plug Speaker
    - Waktu baru harga MSRP $4,498/each = $4,498 x 2 = Rp 90 juta an...!!
    - Sekarang sy jual mintanya Rp 22juta nego
    - Kondisi = Working Well, Mulus 95%
    - O ya, berat per biji nya sekitar 35kg, jadi kalau 2 biji sekitar 70kg....
    - Tongkrongan / Tampangnya Hi End, Up To Date & Ganteng Abiiss...
    - Hub / sms = 0811258551
    The Natural Progression Mono amps exemplify the best of Counterpoint engineering. Reliable and solidly-built, these amplifiers have copper-plated steel chassis, heavy custommade heatsinks and massive transformers. Front panel meters indicate output current and power. Do they sound good? You bet! With a triode front-end and an IGBT (Insulated Gate Bipolar Transistor) output stage, these amplifiers are capable of delivering 250 amperes of current and over 300 watts of power into four ohms.
    Can they be improved? Certainly. Like all Counterpoint (and all sub-$10,000 gear) the components in the signal path and in the power supplies use above-average sounding parts, all right, but not the best by a great margin. And the circuit itself benefits from a lot of cleanup. The original circuit uses two stages of tube amplification, followed by a solid-state buffer to drive the output stage. Then 26dB of feedback is used to improve the measured specifications. I've come to realize that, despite what other companies might claim, NO feedback always sounds better than some.
    The unit has two 6DJ8 tubes as a large paralleled-tube differential amplifier. No feedback. Solid-state IGBT (Insulated Gate Bipolar Transistor) driver. Tube rectifier. Copper-plated chassis, wood sides. Metering for power, current, normal/peak hold. Clipping indicator. On-Off switch. Balanced Inputs. Aluminum front panel finished in black or silver anodize.
    Buka saja links nya =
    http://www.audioreview.com/cat/ampli...2_1583crx.aspx
    http://www.altavistaaudio.com/npm.html#basic
    klaten
    mantafff...
    YOGYA CITY
    trims untuk bantu up nya....
    PangkaL Paha
    2 Wks 5 Days 7 Hrs 45 Mins 39 Secs
    buseett sangar abis wwkwkw
    1 Hr 8 Mins 45 Secs
    Wahhh mister zai lai yi chi ketauan mau shopping brg sangar yaaa?
    YOGYA CITY
    thanks untuk bantu up nya..
    3 Wks 10 Hrs 19 Mins 32 Secs
    Brg mantap nih pa. Bantu up ya,
    YOGYA CITY
    Quote Originally Posted by aristo1970 View Post
    thanks ya..
    Semoga jadi cepat laku..
    YOGYA CITY
    Mau denger suara audio home hi end harga bersahabat?
    Coba aja....
    YOGYA CITY
    UP for the best amp
    McIntosh MCC602TM - Alpine F#1 Status - Hertz Mille MLK3 - MOREL Ultimo Sub - Steg MSK3000 - Optima Yellow Batt - Trutech dist cap - Flux accs
GT Radial Venom 300x250
  1. Replies: 12
    Last Post: 8th November 2013, 10:04
  2. WTS : Monoblock AUDIOSYSTEM M-Line 600.1 (BNIB)
    By cliport in forum Power Amplifier
    Last Post: 8th December 2012, 22:42
  3. Jual : Power Mono Braxton Symphony 800 D
    By d3cibel in forum Power Amplifier
    Last Post: 10th November 2011, 12:04
  4. Replies: 3
    Last Post: 30th May 2011, 21:25
  5. Jual : Power Soundstream Rubicon 502 + Balanced Line
    Last Post: 26th August 2009, 09:14
