SALE!!! mono phoenix gold xenon 1200 & JL sub
Results 1 to 10 of 64
  • Short URL:  http://modifika.si/258712
    1 Day 19 Hrs 55 Mins 52 Secs
    sesuai judul, dijual uda kagak dipake lagi: silahkan diliat, dilirik, dan dibeli:rolleyes:
    Phoenix Gold Xenon X1200.1 (1 x 1200W @ 4, 2 and 1 ohm)
    Xenon ( zE'nšn ) N. Greek. 1: A colorless, odorless, highly unreactive gaseous element found in minute quantities in the atmosphere, extracted commercially from liquefied air. 2: A whole new breed of competition-level car audio gear from Phoenix Gold.
    Get ready for a revolution among stanch audiophiles. Hard-core competitors swore that nothing could top Phoenix Gold's Titanium series amplifiers, but they were wrong. The new Xenon series changes all the rules and breaks all the molds in both ground-pounding SPL and purist SQ. Audiophile technology abounds, with ultra-efficient Class D topology, ultra-low ESR capacitor bank, and MOSFET output transistors. Each Xenon model features all new XeFLOW thermal management with variable speed fan cooling, XeTUNE signal processing with 24dB per octave continuously variable crossovers, and XeLOAD circuitry for full power into any load from 4 ohms to an insane 1-ohm. The LPL (Low Pass Level) port allows for optional remote level control, and the RMD (Remote Monitor Display) port allows for optional voltage monitoring. Exotic sports car-inspired cosmetics include side and top-mounted vents with expanded metal highlights, and the unique rubber grommets that hide power and speaker connections are an industry first. Cast aluminum PG badge is backlit with Phoenix Gold's legendary Superbrite blue LED.
    Please note that Phoenix Gold amplifiers and speakers are only shipped to destinations within the USA.
    XeTUNE™ – Advanced input and signal processing circuitry
    * Top-Mounted Controls
    * 24 dB / Octave Crossover
    o Continuously Variable from 40 Hz to 400 Hz
    o 41-Detent Potentiometers for Precise Settings
    * Continuously Variable Subsonic Filter (5 Hz to 55 Hz)
    * Twin-T Variable 0 – 18 dB Bass Boost at 45 Hz
    * Auxiliary Outputs Route Full Range Signals
    XeFlow™ – Thermal feedback system with output optimization
    * Bottom-Mounted Extruded Aluminum Heatsink
    * Expanded Metal Mesh Intake & Exhaust Vents
    * Ultra-Quiet Variable Speed Fan
    * Temperature Monitoring with Automatic Output Optimization
    * Superbrite 5mm LED Power Indicator
    XeLOAD™ – Full power with automatic load sensing
    * Load Sensing Optimizes Power Supply and Output Stage
    * Maximum Power Output From 1 - 4 Ohms
    * Class D Circuit Topology For Less Electrical System Strain
    * 80% Average Power Efficiency Means Less Wasted Heat
    * Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
    * 4 Gauge Power Terminals with Removable Rubber Grommets
    * Fully CEA-2006 Compliant Power Ratings Ensure Accurate Specs
    * Optional LPL44 (Low Pass Level) Controller Allows for Driver's Seat Adjustment of Bass Volume
    * Optional RMD (Remote Monitor Display) Allows Monitoring of the Amplifier's Battery Voltage, Power-On, and Thermal / Overload Status
    * Requires external 100A fuse, available separately
    Subwoofer Mono Amp Specifications
    * Amplifier Type: Mono
    * RMS Power: 1200W x 1 @ 4 ohms
    * THD at 4-Ohm RMS Power: n/a
    * Bridged RMS Power: 1200W x 1 @ 2 ohms
    * Speaker Level Inputs: no
    * Preamp Outputs: yes
    * Built-In Crossovers: LP
    * Bass Boost: 0 - 18 dB
    * Frequency Response: 20-300 Hz
    * Signal to Noise Ratio: > 90 dB
    * Fuse Rating: 100 amps
    utk gambar2 bisa diliat disini:
    http://www.modifikasi.com/showthread...-modcom....%29
    dulu beli di gasoline (bos chris gua pinjem ya foto2nya), pake cm 3-4bln aja beli dr juli taon lalu, kondisi baik, normal, no x servis, mulus, no dus.
    jual Rp. 2,000,000 NETT
    sub JL W5 10" (lama) mulus, normal, no x-servis, karet surround msh asli (boleh dicheck). jual 500rb NETT kasih bonus grill as picture.
    lokasi SBY, janjian mau test barang jg bisa utk yg SBY
    sms/call/PM to 081331388811
    PangkaL Paha
    2 Wks 5 Days 7 Hrs 28 Mins 27 Secs
    sambittttttttttt
    UP UP UP!!!
    Angkat euyyy
    bump!!! BUMP!!!
    diangkat lagi
    UPPPPPPP!!!!
    Angkat lagi....
    Sundul lg...
  1. WTS: Phoenix Gold Xenon X600.1
    By tajadih in forum Power Amplifier
    Last Post: 3rd July 2013, 19:42
  2. WTS Mono Phoenix Gold dan 4ch vox
    By soulz in forum Power Amplifier
    Last Post: 1st May 2013, 08:55
  3. Monoblock Phoenix Gold Xenon 1200 Watt
    By edwin_sasmito in forum Power Amplifier
    Last Post: 26th June 2011, 17:19
  4. WTS : Monoblock Phoenix Gold Xenon 1200W
    Last Post: 7th September 2010, 00:56
