/// BOOSTED TOYOTA ALTIS..!
Results 1 to 10 of 83
  • Short URL:  http://modifika.si/258082
    1 Wk 2 Days 19 Hrs 34 Mins 22 Secs
    Project Street and (Drag) Race Toyota Corolla Altis 2002
    Sesuai permintaan pemilik mobil, Altis ini didesain dan diperhitungkan untuk penggunaan harian yg juga sesekali bisa ikut ngegas di even drag race..
    Spesifikasi dan Modifikasi :
    DARTON Sleeve Iron Block 82mm (Custom)
    Turbo Garrett GT3071R Dual Ball Bearing
    CROWER I-Beam Connecting Rods
    WISECO Forged Piston Bore 82mm Compression 8,8:1 (Special Order)
    CROWER Valve Spring & Titanium Retainer Kit
    ARP Head Stud Kit (Special Order)
    ACL Race Series Main & Rod Bearings Kit (Special Order)
    SUPERTECH Stainless Valves in & ex (Special Order)
    SUPERTECH Viton & Polyacrilic Valve Seals
    TOGA Performance Hi-Flo Oil Pump
    TRD Thermostat 170F
    SAMCO SPORTS Siilicone Radiator Hose Kit
    COMETIC MLS Head Gasket Bore 82mm & 0.030" Thick (Special Order)
    BLITZ Blow off Valve SS-DD
    TiAL MV-S External Wastegate 38mm
    JR PROJECT Oil Cooler & Relocation Kit
    JR PROJECT One-Sided Intercooler
    WALBRO Fuel Pump 255 L/H
    PRECISION Extra Injector 440cc (2pcs)
    BLOX RACING Air Filter Inlet 6 inch
    Custom Stainless Intake Manifold
    Custom Stainless Turbo Exhaust Manifold
    Custom Stainlees Piping Intercooler
    JR Project Silicone Hoses
    Custom Exhaust System
    MEGAN RACING Universal Muffler Inlet 2,5inch
    ACT Heavy Duty Racing Clutch with 6-Puck Disc
    CUSCO Oil Catch Tank
    STRI DSD-SLM II Boost Gauge Meter
    STRI DSD-SLM II Oil Pressure Gauge Meter
    STRI Turbo Timer - Black
    A'PEXi AVC-R Boost Controller
    HKS Silicone Hose Vacuum Hose 4mm
    HKS Silicone Hose Vacuum Hose 6mm
    NGK Iriway 9 Spark Plug
    KSPORT Coilover Kit - Street
    ULTRA RACING Front Bar 2 Points
    ULTRA RACING Front Lower Bar 3 Points
    ULTRA RACING Rear Lower Bar 2 Points
    ULTRA RACING Rear Bar 2 Points
    DASTEK Unichip Type Q+
    DARTON Iron Sleeve Block 82mm
    WISECO Forged Piston 82mm (Oversize 300) Compression Ratio 8,8:1 (Special Order)
    GARRETT TURBO GT3071R Dual Ball Bearing
    CUSTOM Stainless Intake Manifold
    CUSTOM Stainless Turbo Exhaust Manifold (Tubular)
    Boost : 2,0 Bar
    BBM : Bensol
    Dyno Test : RS Tuning-Lestari
    Horsepower Gain : 476 HP @7500 RPM
    Max Torque Gain : 467 Nm @7000 RPM
    POWER DYNO CHART
    TORQUE DYNO CHART
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
  2. SbcAgent
    Palembang.
    6 Days 10 Hrs 51 Mins 52 Secs
    udah naek spec lagi ni bos? heheh
    SOHC VTEC
    dinaikin dikit bos... hehehe
    CP : Coki Siboro
    CP : Coki Siboro
    Bhumi Shrivijaya
    1 Wk 4 Days 19 Hrs 55 Mins 49 Secs
    Salut bos.... Btw :
    1. Intercoolernya pake apa?
    2. Gain powernya dapet berapa?
    3. Kalo diaplikasi ke matic bisa ga?
    4. Total jenderal abis berapa ?
    5. Lama pengerjaan berapa lama?
    6. Penasaran.com
    7. hehehehe....
    Quote Originally Posted by aleebaba View Post
    Salut bos.... Btw :
    6. Penasaran.com
    7. hehehehe....
    intercooler nya pake merk jr project yg model nya one sided bos, keluar dan masuk nya dari 1 sisi, untuk kemudahan pengerjaan piping intercooler dan jalur piping terbaik yg mungkin pada saat kita pikirin..
    di matic sih gak bisa boost besar2, akan slip juga transmisi nya.. tp kalo main di boost range 0,5-0,8bar saya rasa masih cukup asal ditambah dengan atf cooler kit sebagai penjaga temperatur oli transmisi nya supaya tidak overheat.
    kalo semua yg udah dipasang sekarang di mobil habis biaya nya lumayan sih, banyak special order dan custom works nya..
    power gain nya lumayan lah buat mobil harian.. hehehe
    CP : Coki Siboro
    Black Car Community, KLiK, Geek's Family, ISOC, B-Owners, [FTT]
    2 Wks 1 Day 16 Hrs 47 Mins 26 Secs
    Salut bos.... Btw :
    6. Penasaran.com
    7. hehehehe....
    ayooo pasang om aleee... biar kayak streamnya tuh..
    boss coki: racun abis deh..
    www.sekaiproject.net
    4 Wks 22 Hrs 36 Mins 47 Secs
    kalo udah spek kaya gini cooling system nya harus ikut upgrade juga ga bos?
    radiator nya gitu atau electric fan? terus internal stock nya altis sanggup terima boost smp berapa bar bos?
    btw mantap bener ni altis nya.. mungkin udah bisa di bilang the fastest altis in indonesia ya boss??
    Online Editor Dept
    rawamangun - jakarta raya - fast n fun
    1 Yr 1 Mth 1 Wk 6 Days 11 Hrs 34 Secs
    Cokiiii, ini yg waktu itu elu cerita klo full boostnya di rpm rendah? Ckckckc... Masi 3xx kah hpnya? Lanjutkan cok....
    Quote Originally Posted by rizki1301066083 View Post
    wkwkwkwk blm juga ngeracunin apa2..
    CP : Coki Siboro
  1. Replies: 2
    Last Post: 24th February 2013, 11:46
  2. Replies: 0
    Last Post: 25th August 2012, 13:22
  3. Replies: 4
    Last Post: 3rd November 2009, 09:53
