WTS : Peerless 2.5" Full Range
Results 1 to 10 of 22
  • Short URL:  http://modifika.si/257107
    14 Hrs 14 Mins 49 Secs
    SOLD OUTT
    Spesifikasi :
    Peerless 830985 2.5" Full Range
    4 ohm
    Black Aluminum cone
    Features include: A Neodymium motor structure and double-venting system that helps keep dynamic range intact, as the transducer can handle more power and dissipate excess heat efficiently. An anodized aluminum dome provides superior sound dispersion and off-axis response. A semi-progressive surround reduces distortion, especially at high output through long excursion. The drivers’ direct connected dome dust cap (connected to the magnet system voice coil) improves dispersion at high frequencies, providing superior sound on the high notes. The inserted copper cap on the pole piece ensures control the system impedance, thereby extending the upper frequency range.
    Nominal Impedance 4 ohm
    DC resistance (Re) 3.7 ohm
    Resonance frequency (fs) 101.2Hz
    Qms 3.46
    Qes 0.64
    Qts 0.54
    Bl 2.7 Tm
    Mms 1.9g
    Rms 0.36 kg/s
    Cms 1.27 mm/N
    Sd 22 cm2
    Vas 0.8 liters
    x-max peak 2mm
    Sensitivity 86.5dB 2.83V@1m
    Rated Noise Power (IEC18.1) 20W
    A 1/2 liter (30 cubic inch) sealed and stuffed box gives you an F3 of 150Hz.
    Dimensions: 69mm square, 61.6mm cut out hole, 36.2mm depth.
    SOLD OUT
    1 Mth 1 Wk 2 Days 8 Hrs 51 Mins 35 Secs
    Harga sdh trmsk ongkos sewa gudang pak??? Hehhehehhehehe....... Ayo" dibeli",biar sewa gudang gw dibayar!!!!!
    ayo upp lagi sore2 seblom pulang dr kantor
    Bantu lagihhhhhhh
    1 Day 17 Hrs 11 Mins 3 Secs
    Si bos bantu up... Ikut ah...
    ayo bro2 modcom sekalian, mari dilihat dan dibeli...
    ayo up lagi pagi2.... mari dibeli bro2 sekalian
    ayo up lagi buat barang murah tapi bermerek...... kondisi blom pernah pasang di manapun
    upp lagi biar cepet laku...
    54 Mins 52 Secs
    iseng nawar 200rb kalee aja boleh.... he.he.he.
  1. AUDIBLE PHYSICS NZ3A "THE ULTIMATE FULL RANGE"
    By FERNANDO in forum Speaker - SubWoofer
    Last Post: 10th October 2013, 13:06
  2. [ WTS ] Speker Peerless A16WG19 & Tweeter Peerless XT25TG30 + Pasif
    By arga.lubis in forum Speaker - SubWoofer
    Last Post: 30th June 2012, 11:43
  3. Replies: 0
    Last Post: 11th October 2011, 19:53
  4. Vifa TG9 3.5" Full Range Rp.600.000/Pair #NEW#
    By TOKOSPEAKER in forum Speaker - SubWoofer
    Last Post: 16th November 2010, 00:33
  5. WTB : speaker full range 3"
    By Axxellyz in forum Diskusi Speaker
    Last Post: 4th June 2009, 03:14
