WTS :MODUL PENGAPIAN - KOIL - TURBO TIMER - KABEL BUSI
Results 1 to 10 of 30
  • Short URL:  http://modifika.si/256965
    jkt
    Thumbs up UPDATE WITH PICS&PRICE - WTS : MODUL PENGAPIAN - KOIL - TURBO TIMER - KABEL BUSI..
    Hallo Juragan Juragan Modifikasi.com
    Saya ada beberapa barang yang tidak terpakai dan masih bisa dipergunakan dengan sebagaimana mustinya
    dan sebagaimana harusnya, tapi Tidak ada kelengkapan dus ataupun buku yah teman teman, jadi hanya menjual
    unitnya aja yah..
    1. Modul Pengapian
    CRANECAMS FIREBALL HI-6 IGNITION + wiring set
    1.300.000 nett
    Feature-for-feature, Crane’s HI-6 multi-spark CD ignition for racing or street applications is the industry’s best value. It delivers higher spark-gap current (when used with a companion Crane FireBall LX-92 coil) than the competition and can handle engines with compression ratios to 14.5:1. Important features include surface-mount construction, fully digital components that are sealed in urethane for protection against heat, dirt, water and vibration, plus a rotary dial-adjusted rev limiter. It supports points, module or magnetic triggers.
    2. Koil - SOLD
    MALLORY Universal Street and Strip
    • For street-driven vehicles with breaker point ignition
    or OE electronic ignition
    • Delivers optimum performance when used with these
    Mallory ignition products:
    - UNILITE® Distributor with a HYFIRE®
    Capacitive Discharge Ignition
    - Magnetic Breakerless Distributor with a
    HYFIRE® Capacitive Discharge Ignition
    - Dual Point Distributor
    • Effective to approximately 6500 RPM when used
    with a point type distributor (depending on
    engine combination)
    • Effective to approximately 8000 RPM when used
    with a Mallory HYFIRE® Electronic Ignition Control
    (depending on engine combination)
    Universal Street and Strip . . . . . . . . . . . . 30440 BLACK
    30441 RED
    Tech Sheet 30440
    Primary Resistance 0.42 Ohms
    Secondary Resistance 8.8K Ohms
    Maximum Voltage 51,000 volts
    Inductance 6.5 mH
    Turns Ratio 92:1
    Peak Current 260 mA
    Spark Duration 250 uS
    3. Turbo Timer
    3 step setting time
    1 minutes - Street Cruising
    3 minutes- Highways-Mountain Passes riding
    8 minutes- Circuits / Race/ Warm up Engine
    500.000
    manual timer 1-3menit
    300.000
    multi select timer
    green color digit
    500.000
    automatic timer
    300.000
    APEXi
    500.000
    4. Kabel Busi Hurricane (merah)
    (Kabel busi Hurricane tapi dimodifikasi pada ujung utk ke koil krn disesuaikan dengan socket utk Mallory)
    Semua barang barang diatas bekas dipakai di Toyota Corolla Twincam GTi 1.6
    maaf juragan-juragan belum sempat untuk update fotonya,
    nanti kalau saya sampai dirumah saya coba masukan gambarnya yah...
    jika juragan juragan ada yg berminat, mungkin bisa untuk menghubungi saya di nomor 0812-812-30300
    Prefer COD daerah Tangerang dan Jakarta Selatan..
    Terima Kasih Juragan Juragan
    BOLEH DILIHAT MOBIL ALL NEW JAZZ 2008 ANE YANG MAU DIJUAL :
    http://www.modifikasi.com/showthread...98#post8696398
    mampir ke lapak ane yang lain juga bos
    http://www.modifikasi.com/showthread.php?188610-JOK-RECARO-UPDATE-SALE-SALE
    denver
    4 Days 14 Hrs 43 Mins 54 Secs
    nunggu gambar..minat ama malory
    jkt
    tendang dulu keatas
    Minat sama CRANECAMS FIREBALL HI-6 IGNITION + wiring set.kira2 harganya brp nih bos?bisa buat type z gak?
    jkt
    PM SENT JURAGAN
    Cikarang - Jababeka
    4 Days 7 Hrs 39 Mins 54 Secs
    coil mallory nya berapa ? thanks ya
    jkt
    PM SENT JURAGAN
    jkt
    UP UP UP UP UP!!!
    jkt
    UP UP UP UP UP!!!
    medan
    1 Wk 1 Day 6 Hrs 9 Mins 29 Secs
    Bos kalo kabel busi buat lancer gti 1800 cc dohc?
    Brp harga nya bos?
MBtech Venom 300x250
  1. Replies: 18
    Last Post: 23rd April 2012, 20:44
  2. Pengapian (Koil Blue Fire & Busi NGK Platinum)
    By jsniref in forum Jual Beli Mesin Lainnya
    Last Post: 20th December 2009, 03:44
  3. [WTB] Koil + Modul pengapian
    By nanonine in forum Jual Beli Mesin Lainnya
    Last Post: 10th October 2009, 06:46
  4. WTS Pivot Turbo Timer, Extra Injector, Turbo Modul
    By haltech in forum Jual Beli Mesin Lainnya
    Last Post: 26th July 2009, 13:34
  5. FS Modul pengapian JACOB+koil+modul torsi
    By jero in forum Jual Beli Mesin Lainnya
    Last Post: 2nd April 2009, 22:58
