WTS >subwoofer JL AUDIO w3v3 12"
Results 1 to 10 of 18
  • Short URL:  http://modifika.si/256760
    WTS >subwoofer JL AUDIO w3v3 12" asli!! 1,5 NEGO!!
    permisi agan2 ane mau numpang jualin JL audio 12" w3 v3
    untuk spec'nya..
    Free Air Resonance (Fs): 27.97 Hz 26.72 Hz
    Electrical Q (Qes): 0.534 0.472
    Mechanical Q (Qms): 7.678 7.572
    Total Speaker Q (Qts): 0.500 0.444
    Equivalent Compliance (Vas): 2.806 cu. ft. / 79.47 liters 2.844 cu. ft. / 80.54 liters
    One-Way, Linear Excursion (Xmax)*: 0.510 in. / 13.0 mm 0.510 in. / 13.0 mm
    Reference Efficiency (no): 0.313% 0.313%
    Efficiency (1W/1m)**: 87.15 dB SPL 87.15 dB SPL
    Effective Piston Area (Sd): 80.600 sq. in. / 0.0520 sq. m. 80.600 sq. in. / 0.0520 sq. m.
    DC Resistance (Re): 1.658 ohm 3.563 ohm
    Nominal Impedance (Znom): 2 ohm 4 ohm
    Thermal Power Handling (Pt): 500W 500W
    Driver Displacement: 0.071 cu. ft. / 2.01 liters 0.071 cu. ft. / 2.01 liters
    Net Weight: 14.50 lbs. / 6.58 kg 14.50 lbs. / 6.58 kg
    single coil... dan dijamin mulus bgt,,,
    bisa buat bass geber atau denger pelan..
    dijamin asli!!
    buka harga 1.500.000 NEGO TIPIS!!
    thx..minat PM
  2. Jayapoker
    up up up up up u p
    P up up up up upu
    Up up up up up up
    Up up up up up up up
    Up up up up up
    up p up up up up up
    up up up up up up up up upup
    upupupupupupupup
  1. WTS> Subwoofer JLaudio w3v3 10"
    By WI288 in forum Speaker - SubWoofer
    Last Post: 30th August 2012, 18:25
  2. WTS subwoofer JLaudio w3v3 10"
    Last Post: 13th December 2011, 00:00
  3. Replies: 29
    Last Post: 25th March 2010, 23:44
  4. SOOOLLLDDDD: SUB 12" JL Audio W3V3
    By buuuuu in forum Speaker - SubWoofer
    Last Post: 2nd March 2010, 18:17
  5. Replies: 14
    Last Post: 12th January 2010, 17:15
