Page 1 of 29 12345 ... LastLast
Results 1 to 10 of 286
  • Short URL:  http://modifika.si/253352
    Giro Point
    Lightbulb Its just a Timor, not a KIA :D
    mau numpang mejeng si buluk ane yah om om dan tante tante semua
    Exteriornya :
    Spec :
    - HID Blitz H4 Magnetic head lamps
    - Sparco NS-II 16" wheels
    - Seneca Racing Lug nuts
    - Achilles ATR Sport 195/50/16 Tyres
    - Bilstein Shockabsorber
    - Intrax Lowering Kit (tidak di potong)
    - Remus Tailpipe
    Engine bay:
    Spec :
    - Still use the original carburetor
    - Yakuza Open Filter
    - Simota Breather
    - Speeder Spark Plugs cable
    - Accell Coil 120K Volts...bener ga yah, lupa
    - Use Shell Oil for engine and transmision
    - Stinger Single Fuse 150 Amp (for Audio System)
    - Stinger Battery Terminals with Auto Voltage
    Trunk side
    Spec :
    - SPL Dynamics Pro12D2 Subwoofer with 800 W RMS, at 1000 W peaks
    - Jacobs 50 Amps Volt Step-up Stabilizer
    - SPL Dynamics 1 Farad Capasitor Bank
    - ARC 5150 CXLR Power Amplifier
    - Nakamichi EC302 Active Crossover
    - Stinger Fuse Distributor Block and Ground Block
    - Pear Cable for Power wirings
    - TARA Labs NEXA cable for Subwoofer wiring
    Interior:
    Spec :
    - MOMO F1 Concept Steering Wheels
    - TOMEI Shiftknob
    - Sparco Handbrake grip
    - Custom Dashboard
    AUDIO
    - Nakamichi DAC111 (upgraded)
    - Nakamichi 100 MB CD Changer
    - Gramond Reveal 1 for Front Speakers
    - 2 Sets SPL Dynamics Pro 300.2 with Fully Upgraded
    - Potensio Passive using Step Attenuator TKD (Tokyo Ko-on Dempa) 50K
    - Duelund 2.0, WBT female RCA Internal wirings
    Wirings
    - Pear Cable 1 AWG for Power Amps
    - Pear Cable 4 AWG Power wirings
    - Pear Cable Commice for Speaker wires
    - Pear Cable Commice for Front RCA
    - XLO Twinax plus for Subwoofer RCA
    - Crystal Cable Picollo for Analog DAC wirings
    - XLO Signature-1 for Digital Coaxial wirings
    - Shun Mook included
    - 3M Windows tints
    - Peredam habis 40-an lembar, masing2 pintu plus latex cair, plingkut, dan semen tiga roda
    Interior UPDATE :
    - PIVOT Tachometer
    - MSD 6T with Soft Touch
    Exterior, Rear Disc Brake and Suspension UPDATE
    Original KIA Sephia Stop Lamps
    Rear Disk Brake
    thanks to mbah Husen (XB) saung, mbah Harry Semarang (iwakpitik) ama om mas yudi
    Hotbits Coilover
    thanks to Mr. Hendri from HOTBITS indonesia
    Do you think I'm sexy now? -wow
    Engine Swap still on progress
    setelah di bangkit kan dari kubur tuh engine, nih tampang awal nya :
    part pendukung nya nanti ye om om dan tante tante
    mohon dukungan nya yah dan jangan di ketawain yah timor buluk ane -malu
    Giro Point
    Mazda Genuine Parts inside
    HLA
    Cylinder Head, Gasket
    Piston (oem KIA), Piston Rings, Main Brgs, Conn Rod Brgs
    Clutch Cover, Clutch Disc, Clutch Release Brg
    Used AFM, nyari yg baru susah banget
    Performance Parts abal-abal
    HKS Super Street Camshaft and Gears, HKS for Mazda B6 engine
    Performance Valve Springs, Billet Pulley, Flywheel
    Gates Racing Timing Belt
    Taylor Thunder Volts 8.2 spark plug cables
    MSD HVC-2 Coil and MSD Coil cable
    Quick Shifter
    oops, ga lupa gasket2 laen nya full original mazda, yg ini lupa foto
    thanks to Lord Jesus, mbah Harry-Semarang (iwakpitik), chef Weda (Indonesian Performance), mbah Bayu (ciutbagong), Summit Racing, brow Andhika, Mr. Hendri (HOTBITS Indonesia) and off course semua om om dan tante tante Timor-er
    Giro Point
    ngintip dikit waktu prosesnya
    dipoles biar gak dekil
    MBSP kepasang
    papas + balans ulang flywheel
    Injector diukur ulang
    Giro Point
    Aeromotive FPR with Aeromotive Pressure Gauge
    Strutbar HotBits
    Exhaust System Upgrade by HOTBITS Racing
    HOTBITS Straight Flow Muffler
    click for details
    Spoiler for muffler: Show
    HOTBITS Bullet Resonator
    click for details
    Spoiler for Resonator: Show
    Giro Point
    UPGRADE POWER BRAKE
    Brake Master Cylinder OEM Mazda B6
    Master Vacuum Assy OEM Nissan B13 - Sentra Genesis
    Giro Point
    No Pain No Gain
    credits to: Mr. Wedha - Indonesian Performance
    Around Your Connections
    Giro Point
    44 Mins 28 Secs
    wuiiiiiii....
    mantab bos timor nya, saya pasang sein kiri aja deh
    Giro Point
    My Special thanks to Lord Jesus Christ, Bung Weda (Indonesian Performance), Mr. Hendri (HOTBITS Indonesia), Brow
    Andika (for supporting searching from ebay and SUMMIT Racing), embah Harry Semarang (iwakpitik), embah Dr. Bayu (ciutbagong) dan tidak lupa kepada
    teman-teman sesama pemakai mobil Timor, om dan tante Timor-er dan juga kepada semua teman2 yg sudah support dari
    awal sampai selesai...
    Mazda Engine B6-ZE RS + +
    Taylor ThunderVolts 8.2 Race Wire sets with Greddy Wire Separator kits
    HKS Mushroom Open AIr Filter with Simota Cold Air Intake
    SIMOTA Breather Filter kits
    Aeromotive Fuel Pressure Regulator
    MSD BLASTER HVC-II Coil with MSD Coil Cable
    Mazda Brake Master Cylinder with Nissan Brake Booster
    HOTBITS Front Strutbar
    maap cuma timor buluk upgrade dikit parts abal-abal
    Custom Galvanis 4-1 Exhaust Manifold and down-pipe
    Original REMUS Tail-pipe
    Aeromotive Inline Street Series HO and OEM Mercedez Benz Fuel Filter
    Giro Point
    mohon comment nya para master.....
    Giro Point
    Quote Originally Posted by PunkyKing View Post
    wuiiiiiii....
    ampun om...
    cuma timor kok....
Venom 300x250
  1. Timor Raja Timor
    By iklaninternet in forum Merk Lainnya
    Last Post: 5th July 2013, 23:07
  2. WTS:Timor DOHC 1999 dan Timor SOHC 1996 Istimewa
    By jadulz in forum Merk Lainnya
    Last Post: 2nd February 2012, 16:52
  3. Jual setir ori Timor + garnish belakang Timor
    By veilsidenrico in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 12th August 2010, 11:25
  4. WTB.. iNDIGLoW TIMOR SOHC , Spion MaNuaL LH TIMOR..
    By DeeCoolzz in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 29th May 2009, 17:31
  5. Replies: 38
    Last Post: 3rd May 2008, 23:51
