WTS : POWER MICROSTAC HE 300.4 BURRBROWN IC FOR SQ LOVERS
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/252640
    padang - sumatera barat
    1 Wk 4 Days 5 Hrs 35 Mins 50 Secs
    permisi bos bos semua....mau jual power ane ni...masih dipakai sih ampe skarang...lagi BU bos...
    MICROSTAC HE 300.4
    spesifikasi :
    * 1 pair of SANKEN Transistor each channel
    * Very stable,Low noise switching power supply
    * Direct coupling signal
    * Low ESR,Low impedance Rubycon Electrolytic capacitor
    * Audiophile grade amplifier schematic
    * Double Layer ,Through hole Glass epoxy PCB
    * Highpass/Lowpass/Fullrange active crossover from 35hz-250hz
    * Class A driver module transistor
    * Low noise,Precision gain contyrol
    * Audio grade Burrbrown op-amp
    * State of the art car amplifier design with right component at the right place
    Mode : Class A
    Number of channel : 4
    Rated power output in 4 ohm : 4 x 85 watt
    Rated power output in 2 ohm : 4 x 150 watt
    Rated power output in 4 ohm : 2 x 260 watt (Bridged mode)
    Rated power output in 2 ohm : Not reccomended
    Frequency Response : 20 hz €“ 20kHz
    Distortion : < 0.4% (1Khz)
    S/N Ratio, A weighted : > 95db
    Damping Factor : > 200
    Input Impedance : 47 Kohm
    Input Sensitivity : 0.1 €“ 8V
    Filter Front & Rear Channels : LP: 30-200hz ,HP: 30hz-200hz,Flat
    Fuses : 40 A x 1
    Current Draw, Idle : 2.5A
    Current Draw, Maximum : 70A
    Gambar :
    kondisi ok...terawat..soalnya di taro dibelakang bagasi aja..hehehe...
    harga 1.4 jt
    for fast respond : 081993999995
    Under blue sky
    2 Days 1 Hr 1 Min 17 Secs
    pm nett sampe jogja bro....
    Quote Originally Posted by hoik View Post
    siap bos..
    uppppp.....uuppp....uuppp....
    uuuuuuppppppppppppppppp.........!!!!!
    upupupupupupupupupu........
    uuuuuuuuuuuuupppp.......hayoo di beliii....
    3 Wks 3 Days 7 Hrs 59 Mins 11 Secs
    Pm nettnya, lokasi dimana? Saya di puri indah jakbar
    uuuuuuuuppppppp uuppp...ayyoo dibelii ayoo dibeli.....
Venom 300x250 MBtech
  1. [WTS] power 4 channel Microstac
    By kdbesi9 in forum Power Amplifier
    Last Post: 6th August 2012, 11:32
  2. Power Microstac (MURMER)!!!
    By AMG777 in forum Power Amplifier
    Last Post: 21st July 2012, 16:28
  3. WTS : Power SQL Microstac 350.4
    By Adeng in forum Power Amplifier
    Last Post: 14th November 2010, 21:27
  4. WTS power microstac HE 300.4
    By wilsontanuwijaya in forum Power Amplifier
    Last Post: 13th June 2010, 10:42
  5. WTA Power VOX 4.100 BurrBrown..
    By -GeRoBak- in forum Diskusi Power Amplifier
    Last Post: 1st February 2007, 15:14
