Hi-end Focal Dual Monitor
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/251504
    PIN: 28C74CA7 HP:08112509829
    2 Days 22 Hrs 30 Mins 11 Secs
    Thumbs up Hi-end Focal Dual Monitor ( TURUN HARGA )
    Numpang jualan lagi, power hi-end Focal Dual Monitor 2x300
    Seri Top of The Line punya Focal
    Kondisi: mulus lengkap seperti baru, pemakaian sebulan
    Murah aja bos, asal cepat. Call/sms only 08112509829
    SPEC:
    Output POWER @13.8 VDC; THD 1.0%
    2 x 4 Ohm 300W x 2ch
    2 x 2 Ohm 400W x2ch
    1 x 4 Ohm 800W x 1ch
    1 x 2 Ohm 1200W x 1ch
    Smallest output Impedance:
    Stereo: 2 x 1 Ohm
    Bridge: 1 x2 Ohm
    Frequency characteristic: 10Hz~45kHz
    SIGNAL-TO-NOISE RATIO ratio: Above 110dB
    Damping factor: 600 or more
    Input sensitivity : 0.2V~5V
    Converter: 24bit/96kHz crystal
    Digital graphics EQ: 30 bands (1/3oct)
    Digital parametric EQ: 1 band full adjustments
    Digital delay line (every input/output ch): 2 input /2 output maximum of 2048 samplings
    Digital control: Outside it minds USB PC (Windows)
    High pass crossover: Adjustment of the slope and frequency is possible
    Low-pass crossover: Adjustment of the slope and frequency is possible
    Remote control: Attachment (master volume +5 pre-setting)
    Supply voltage: 11~15V
    Size (width x depth x height): 540 x 280 x 50mm
    Weight: 7.5kg
    FPDualMonitor – Focal 1 Ch 1200 Watt Power Amplifier
    Monggo pelototin foto aslinya bos
    U P
    u p
    u p
    u p
    u p
    u p
    U P
    6 Days 23 Hrs 6 Mins
    nettnya brp bos? lokasi?
    Quote Originally Posted by willia View Post
    call me at 08112509829
NGK Busi Datsun 300x250
  1. Replies: 10
    Last Post: 27th January 2010, 04:54
