KSPORT Coilover Kit - Honda Civic EG Estilo/Genio (Street & Drag Spec)
Results 1 to 10 of 91
  • Short URL:  http://modifika.si/251164
    1 Wk 3 Days 2 Hrs 57 Mins 1 Sec
    KSPORT COILOVER KIT - Honda Civic EG 92-95
    Application :
    Honda Civic EG (Estilo/Genio) 1992-1995
    Coilover Type Available :
    1. Kontrol Pro Damper (Street)
    2. Custom Spec (0-400m Drag) Spring Rate : Front : 8,7 kg/mm & Rear : 9,8 kg/mm
    Specifications :
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Featured with 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment.
    * 36 levels of adjustable damping (Soft - Hard)
    * Made from high quality 6061 aluminum with T6 for increased hardness
    * Compression/Rebound adjustable
    * Adjustable spring perch for height adjustment
    * Adjustable body allowing maximum suspension travel
    * Monotube high pressure design reduces oil leakage
    * Electroplated body for protection from corrosion and rust
    Interested..???
    Call :
    Coki Siboro - de Auto Motorsport
    0815.1330.1978
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    we got stock for street and drag race application...
    CP : Coki Siboro
    ready stock for street performance and drag racing application...
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
MBtech Venom 300x250
  1. WTS : (Estilo-Genio) Koil dan Igniter mobil honda civic Genio/Estilo
    By kasugawa in forum Jual Beli Mesin Lainnya
    Last Post: 16th April 2012, 14:44
  2. WTS Coilover Tein super street damper for Honda Civic FD1
    By Mkurnia in forum Per & Shockbreaker
    Last Post: 22nd March 2012, 17:18
  3. |WTS| HWL Coilover Honda Estilo/Genio (Shock+Per) >>> 3.2jt
    By reytech in forum Per & Shockbreaker
    Last Post: 30th October 2010, 09:58
  4. Replies: 13
    Last Post: 2nd October 2010, 22:40
  5. --.WTS.-- KSPORT Coilover Kit Honda New Jazz GE8
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 31st May 2009, 01:09
