.:de Auto Motorsport:. KSPORT Big Brake Kit - Honda New Jazz GE8
Rgotogel Gelap.net 36Goal.com
Results 1 to 10 of 120
  • Short URL:  http://modifika.si/251163
    1 Wk 2 Days 19 Hrs 34 Mins 22 Secs
    KSPORT FRONT BIG BRAKE KIT - HONDA NEW JAZZ GE8
    Application :
    Honda New Jazz GE8 2008-up
    Honda Freed 2009-up
    Honda All New City 2009-up
    Type :
    ProComp Front Big Brake Kit
    Specifications :
    * 6 Piston Aluminum Calipers (Orange)
    * D.O.T. Compliant Stainless Steel Brake Lines
    * Machined Aluminum Hats
    * Carbon Steel Brackets
    * 286mm (11") Large Ventilated Discs (min. 15" wheels required)
    * High quality KSPORT SC5 street brake pads
    Short Brief :
    Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required.
    Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
    Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
    Interested...???
    Call :
    Coki Siboro - de Auto Motorsport
    0815.1330.1978
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
  2. Jayapoker
    ksport big brake kit.. plug and play for honda new jazz ge8 type rs with oem wheel.
    CP : Coki Siboro
    direct bolt on honda new jazz ge8 type rs with oem wheel.
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    honda new jazz ge8 big brake kit..!!
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
  1. de Auto Motorsport :: PRO RS - Performance Brake Line Hose ::
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 16th February 2015, 17:04
  2. de Auto Motorsport :: BREMBO Brake Pad
    Last Post: 16th February 2015, 16:59
  3. [selling] KSPORT Big Brake Kit
    Last Post: 6th December 2014, 06:39
  4. de Auto Motorsport :: Brake System Package :: BREMBO & PRO RS
    Last Post: 20th December 2013, 09:15
  5. --.WTS.-- KSPORT Coilover Kit Honda New Jazz GE8
    Last Post: 31st May 2009, 01:09
