WTS:AUDIO BEKAS STREAM = panel 3way stream + RAINBOW CS365ProfiKick +Mcintosh MC440
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/250928
    Polluted WezT Djakarta
    1 Wk 2 Days 22 Hrs 24 Mins 13 Secs
    WTS:AUDIO BEKAS STREAM = panel 3way stream + RAINBOW CS365ProfiKick + milbert tc-4r
    as topic guys, mo dijual cepat aja karna dah gak kepake lagi.
    panel dan speaker gak dijual terpisah. speakernya 3way udah termasuk passive xovernya hi dan lo.
    kl butuh subnya jg ada SS 23W jg mau dilepas.
    KETERANGAN DARI WEBSITENYA:
    The Profi Line, with its premium-quality components, is one of the most highly touted car speaker systems in history, as the numerous first place honors awarded in tests and reviews in the worldwide car audio press demonstrate. As with all the company’s product lines, Rainbow is dedicated to continuous development and improvement of the Profi Line, resulting in an ultimate auditory combination, with plasticity and front staging. The highest possible resolution definition with superb dynamic range and pulse response ensures sound reproduction of complex audio passages even at extreme volume levels.
    6.5 inch Woofer
    4" Midrange
    26mm Silk VOF Tweeter
    max. 180 Watt
    The Tweeter:
    Tweeter dome made of stamped, ultraviolet-withstanding, natural fiber silk mixture
    Fabric surround for controlled cone motion
    Tweeter dome sound-coated by hand
    Felt pad underneath tweeter dome to prevent turbulence
    Vented voice coil former with flexible stainless steel lead wires
    Connected acoustic volume for low-resonance frequency and superior linear frequency response
    Ferrofluid-free magnet system for fast and precise pulse response
    8-holed backplate to connect tweeter to the acoustic volume
    High-efficiency neodymium magnet with reversible magnet energy at temperatures up to 175 degrees Celsius
    The Crossover:
    Profi Line crossovers are remarkable for their intrinsic features. Fitted with lowimpedance and low-distortion foil capacitors, they provide high saturation, excellent fidelity, and faithful phase linearity throughout the treble range. The low-impedance, low-stray coils ensure minimum power loss at the crossovers. Palladium-plating ensures the best possible connections, and the variable tweeter level attenuation in combination with the HALO-system prevents excessive treble output.
    The Woofer & Midrange:
    Special plastic compound basket with extreme stiffness for resonance-free operation
    Palladium-plated screw terminals for high quality, large diameter cables
    Extremely flexible surface refined lead wires fixed via glue-points to guarantee rattle- and break-free operation
    Butyl rubber surround for controlled cone motion and low distortion
    Natural fiber cone for authentic and brilliant sound reproduction
    Innovative dust cap formed of reinforced natural fiber for optimal frequency response
    Machined aluminum phase plug for phase correction around the crossover frequencies and additional cooling for magnet motor
    High temperature 37 mm voice coil former of black kapton for minimal current loss and maximum excursion
    Duroplastic backed and vented voice coil with temperature-resistant glue
    Vented spider to avoid compression
    Vented magnet system for better magnet motor cooling and vented dust cap to prevent thermal on
    Optimized ferror-ceramics magnet for high sensitivity with additional cooling via aluminum backplate
    http://www.rainbowcaraudio.com/cs365profi-kick.html
    Harganya barunya masi $914.95
    http://www.speedsound.com/component-...em-p-4702.html
    Tq bos bos modcom,
    contact basthian : 20e20213
    infoh ya. itu middbassnya bukan yang itu. yang aselinya spt di web koq.tq
    &*(&#$()%&_@alpineEEQ*(&*($&%*(#$&)
    1 Wk 2 Days 2 Hrs 12 Mins 30 Secs
    Pertamax...!!
    Dilepas berapa bro?
    1 Wk 2 Days 23 Hrs 5 Mins 26 Secs
    Bos pm harga powernya, tq
    6 Hrs 8 Mins 57 Secs
    Bos bisikin masing2 harga bos tq ..
    1 Mth 1 Wk 2 Days 9 Hrs 54 Mins 26 Secs
    Quote Originally Posted by nubietol View Post
    wahhh....keduluan neh.hahahahahaha
    Haahhahahahha ane ngalah aja dah ma juragan malang :p
    Sikat mas bro
    @yode pm sent. tq
    @sablengz 2,75jt speaker 3way + passive + pilarnya bro.
    @nubitol pm sent. tq
    @nubitol pm sent
    @yoodee pm sent.
    @sablengz pm sent.
    tq
    ayo ayo bisa negoo ini. tqtq.
    2 Wks 6 Days 22 Hrs 55 Mins 37 Secs
    pm harga power mcintosh nya oom, tq
MBtech Venom 300x250
  1. Replies: 2
    Last Post: 25th April 2012, 13:05
  2. <WTB>control panel ac Honda stream
    By benkz_89 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 12th October 2011, 21:48
  3. Replies: 14
    Last Post: 17th July 2011, 00:54
  4. WTS: Brax X2000 & Mcintosh MC440
    By rr14 in forum Power Amplifier
    Last Post: 20th March 2011, 20:59
  5. [ASK] Wood Panel Untuk Stream
    By whipstock44 in forum Diskusi Interior
    Last Post: 11th June 2008, 18:31
