MITSUBISHI EVO 4G63 - Performance Parts
Results 1 to 10 of 22
  • Short URL:  http://modifika.si/250769
    MITSUBISHI EVOLUTION 4G63 - PERFORMANCE PARTS
    Berikut ini Performance Parts untuk Mitsubishi Lancer Evolution 4G63 Engine dari EVO I-IX. Barang 100% baru semua dan jika ada yang anda mau tapi tidak ada di list ini, bisa available by order.
    Informasi harga, bisa langsung menghubungi :
    Coki Siboro
    0815.1330.1978
    021.9866.1978
    KOYORAD - ALUMINUM RACE RADIATOR Mitsubishi EVO 4-6
    Application : Mitsubishi Evolution 4-6 (4G63 Engine)
    Number of Row : 2 Row
    Radiator Cap Included : No
    Built with a robust 53mm core, the R-Core Series is engineered for the serious performance tuner. Increased capacity means better cooling reserve when you need it. Intended for both circuit and daily use, you may double your coolant capacity and see up to 35% increased performance over your stock radiator.
    All Koyorad R-Series All Aluminum Radiators are Nocolok brazed, designed as a factory fit, direct bolt in with no engine modifications necessary, and retain mounts for the stock fan shrouds and fans.
    (TAIWAN MADE) ALUMINUM RACE RADIATOR EVO 1-3
    Application : Mitsubishi Evolution 1-3 (4G63 Engine)
    (TAIWAN MADE) SILICONE RADIATOR HOSE KIT
    Hose Material : 3-Layer Silicone Hose
    Color : Blue
    MISHIMOTO LOW TEM THERMOSTAT
    Temperature Opens at 63 Celsius instead of OEM Stock at 82 Celsius
    Mishimoto Racing Thermostats will promote greater cooling efficiency throughout your engine. The Mishimoto racing thermostat will significantly lower high engine temperature produced by modified and upgraded turbo applications. Once the engine is fully warmed up the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats, also allowing the coolant to flow through the engine sooner thus reducing and maintaining cooler engine temperatures.
    HKS LOW TEMP OIL COOLER THERMOSTAT
    Application : Mitsubishi EVO 1-7
    Spec : Open at 75 degree Celcius
    SUPER90 BILLET ALUMINUM BIG BORE THROTTLE BODY 70MM
    Material : Billet Aluminum
    Bore Size : 70mm
    Bigger throttle body for your EVO Turbo Engine means bigger power output you'll get..!
    SUPERTECH PERFORMANCE VALVE SEALS
    Application : Mitsubishi EVO 1-9
    Material : Viton Exhaust Seal & Polyacrylic Intake Seal
    Supertech Valve Seals are the final piece of the puzzle for your performance valvetrain.
    COMETIC MLS ENGINE HEAD GASKET
    Stocks for :
    EVO 1-3 (Bore 85,50mm & Thickness 0.051" = 1,3mm)
    EVO 4-8 (Bore 85mm & Thickness 0.051" = 1,3mm)
    EVO 4-8 (Bore 86mm & Thickness 0.051" = 1,3mm)
    The Cometic MLS gasket is comprised of three layers of Stainless Steel. Cometic uses Stainless steel for increased strength, its ability to rebound and corrosion resistance. The outer layers of the gasket are embossed and coated on both sides with a flouroelastomer rubber based material (Viton) designed to meet the demands of a variety of harsh sealing environments, load conditions and surface finishes. The Viton coating is heat resistant to 2500C or 4820F.
    The center or shim layer of the gasket is comprised of an uncoated Stainless Steel layer, which can be varied to accommodate multiple thickness requirements.
    The composition of MLS will also withstand the shearing forces created by aluminum heads on cast iron blocks. No re-torque is necessary. By design the MLS gasket promotes an even torque load across the sealing surface allowing for measurable reduced bore distortion.
    MANLEY H-PLUS CONNECTING RODS
    Type : H-Beam (H-Plus with ARP 625+ Bolts)
    Application : Mitsubishi Evolution 7-Bolts Crankshaft
    Spec :
    Center to Center 5.905"
    Big End Bore 1.890"
    Big End Width 1.038"
    Pin Diameter .866" (22 mm)
    Pin Bore .8671"
    Weight 554grams
    Manley "H" Beam connecting rods are manufactured from 4340 forgings to the same exacting standards developed and approved by our original equipment customers. There is a vast difference in quality between a Manley "H" Beam and the "other" inexpensive H-Beams on the market. Weight matched to +/- 1.5 grams. Perfectly round big and small ends. Bend and twist is tightly controlled. Cap fasteners are 3/8" ARP Custom Age 625+ for the H-Plus.
    ACL RACE SERIES BEARINGS
    Application : Mitsubishi EVO 3 (7-Bolts)
    Size Available : Standard Size & 0.025 Size
    High performance driving demands that you use the best parts. So rely on ACL's Race Series Products to perform to the exacting race standards you expect. They provide the dependability it takes to hold up under higher RPM conditions. The unique combination of design, metallurgy and engineering come together to deilver what drivers expect from high performance parts.
    HKS VALVE SPRINGS
    HKS valve springs are stiffer springs specifically designed for use with HKS camshafts. As valve train dynamics change with the use of high performance cam profiles and greater lift, stiffer valve springs are needed to optimize valve movement. When changing to a high lift cam, stock springs cannot match the increased valve train movement. Therefore HKS engineered valve springs that are precisely matched to the characteristics of HKS camshafts.
    NGK POWER CABLE R9 SPARK PLUG WIRE
    NGK SPARK PLUG
    Application : Mitsubishi Evolution 1-6 (4G63 Engine)
    Type : BPR8EIX & BPR9EIX
    WALBRO HI-FLOW FUEL PUMP
    Application : Mitsubishi EVO 1-9 (In-Tank)
    Flow Rate : 255 Liter/Hour
    Optional Installation Kit is Available
    SARD HI-FLOW FUEL PUMP
    Flow Rate : 280 Liter/Hour Complete with Installation Kit
    The SARD High Flow Fuel Pump - Universal 280l/h will supply the excess fuel demanded on vehicles with upgrade injectors, increased boost, upgraded turbine kits, additional injectors, etc. It comes with all connectors, harnesses, strainers and o-rings for a `drop in` application.
    size comparison between SARD 280LPH & WALBRO 255LPH
    RC ENGINEERING INJECTORS
    Stock (Flow Rate - CC's) :
    660cc
    1000cc
    RC Engineering is the world's leading supplier of made-to-order, high-performance, electronic fuel injectors. RC injectors are available for a wide range of automotive, motorcycle and marine engines used in high-performance or racing applications.
    SKUNK2 ADJUSTABLE CAM GEAR
    Color : Red
    Sold in Pair/Sepasang
    HKS ADJUSTABLE CAM GEAR
    Color : Purple
    HKS Adjustable Cam Gears allow fine tuning of the camshaft timing to maximize engine performance and tailor power characteristics for various driving conditions. Either with OEM or HKS Camshafts, adjustments can be made to tune an engine’s power band to the optimum RPM range for a particular application. HKS Cam Gears are made completely of anodized Duralumin with nickel plated gear teeth except for applications with timing chains which utilize an aluminum slide with steel teeth.
    HKS FINE TUNE TIMING BELTS
    Material : Kevlar
    HKS kevlar timing belts are incredible strong and reliable when compared to an OEM part. Ideal for big power, high reviving applications.
    GATES RACING TIMING BELTS
    Material : Kevlar
    "Incredibly strong, extremely heat resistant. Tough enough to take the worst pummeling your engine can dish out. No other belts help protect your engine and deliver high performance like Gates Racing Performance Timing Belts.
    Yes, the color gives you a hot custom look. But look deeper. Constructed of HNBR elastomeric composites, Gates Racing Performance Timing Belts are 300% stronger than stock belts and deliver up to three times the heat resistance. You can count on them to hold up to the rigors of high horsepower, even with interference engines."
    ZAKLEE CLEAR CAM GEAR COVER
    Application :
    Mitsubishi Evolution 4-8 (4G63 Engine)
    The SightGlass Clear Cam Gear Cover is almost an exact duplicate of the factory part. It is made of polycarbonate - an extremely durable thermoplastic. We guarantee it will fit every after market cam gear set.
    If you have cam gears and tune them then this is what you need to see your settings. Complete clear polycarbonate material is extremely strong, durable, and fits like stock.
    KSPORT COILOVER KIT
    Application of Stock : Mitsubishi EVO 3
    Suspension Type : Kontrol Pro Damper (Street)
    Pillowball Uppermount : Front
    Short Brief : Adjustable High-Low & 36 Level Soft-Hard
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed.
    Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
    The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride.
    The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
    ULTRA RACING CHASSIS BAR
    Application :
    Mitsubishi Lancer EVO 1-3
    - Front Strutbar 2 Points
    - Rear Strutbar 2 Points
    - Fender Bar 3 Points
    - Front Lower Bar 4 Points
    - Rear Sway/Anti-Roll Bar 23mm
    Mitsubishi Lancer EVO 4-6
    - Front Strutbar 3 Points
    DEI TITANIUM EXHAUST WRAP
    Size & Length Available :
    1" x 50feet
    2" x 25feet
    2" x 50feet
    Titanium exhaust wrap
    with LR Technology, is made from pulverized lava rock and stranded into a fiber material and is engineered to be stronger than typical wraps on the market today. It has the ability to handle higher heat for improved performance and durability and with a cool carbon fiber look!
    Features:
    * Withstands 1800 F direct/2500 F radiant heat
    * Promotes increased flow for improved performance
    * High resistance to chemical & oil spills and abrasions
    * Reduces temperature & vibration breakdown
    * Extremely pliable for easy install will not shrink
    * No need to "wet" wrap to install
    EXEDY RACING CLUTCH - SINGLE PLATE
    Application :
    Mitsubishi Evolution 1-3 (4G63T Engine) 3-Puck & 4-Puck
    Mitsubishi Evolution 4-6 (4G63T Engine) 3-Puck
    EXEDY cerametallic clutches are designed to handle the abuse of high powered modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading. All cerametallic discs feature spring center dampers to reduce impact and shock loads.
    ... more parts available soon :
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    busi NGK
    Bos klo busi Type : BPR8EIX & BPR9EIX, hrgnya brp?
    klo radiator hose kitnya??ane pake lancer CB5 bos..
    trus klo injector cleaner ma carbon spirit brp??
    thnx's b4..
    Quote Originally Posted by lep's View Post
    thnx's b4..
    spirit carbon clean dan ultrasonic injector cleaning nya 550rb bos.
    busi bpr8eix nya gak bisa buat cb5 loh bos.. kalo radiator hose kit nya ada.
    CP : Coki Siboro
    Quote Originally Posted by coki.de auto View Post
    btw yang paket hematnya dah gak bisa lagi ya bos? klo tgl. merah buka pa gak?
    trus spek busi NGKnya yg bisa brp??
    radiator hose kitnya brp?
    paket hemat nya udah lewat bos.. nanti deket lebaran baru ada lagi.
    kalo busi setau saya pake kepala kecil, yg heat range nya 8 pake nya bkr8eix.
    silicone radiator hose kit nya 650rb set selang atas dan bawah. tq
    CP : Coki Siboro
    klo ane ambil paket hrg normal 640rb klo oli shell ya gan..??
    rencana siy maw ambil paket itu dulu...
    paket yg mana ya bos? saya lagi gak ada penawaran paket perawatan apa2.. tq
    CP : Coki Siboro
    paket yg periode akhirnya mpe 31 Maret 2011, kan disitu tertulis klo normal 640 rb..
    mangnya klo spirit carbon+injector cleaner+oli shell 4 liter normalnya gak sgtu ya??
    keliatan nya udah gak 640rb kalo dengan oli shell, tp kalo yg depan oli fk rs, mobil super 2000 dan total 7000 masih sama harga nya.
    oli shell mulai awal bulan april ini udah naik banyak loh bos.. coba cek2 deh biar yakin.
    CP : Coki Siboro
    ok d gan, nti ane cek...tks ya.
Venom 300x250 MBtech
  1. WTB :Performance part 4G63 (N/A) butuh cepat!!
    By moyung in forum Diskusi Mesin
    Last Post: 10th February 2009, 18:16
  2. MITSUBISHI RVR 4G63
    By MYJDMWORLD in forum Jual Beli Mesin Lainnya
    Last Post: 27th August 2008, 11:23
