FS: DLS Ultimate A5 The Big Three (3 channel: 2x85W + 1x300W)
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/250501
    2 Hrs 59 Mins 42 Secs
    Arrow FS: DLS Ultimate A5 The Big Three (3 channel: 2x85W + 1x300W)
    Sesuai judul, dijual amplifier DLS Ultimate A5. berikut spec dari salah satu topline-nya DLS ini:
    Spoiler for Spec: Show
    Number of channels 3
    Amplifier class AB
    Damping factor > 200
    S/N ratio, A-weighted >100 dB
    Output power in 4 ohm 2 x 85 W RMS
    Output power in 2 ohm 2 x 100 W RMS
    Mono sub channel 4 ohm 300 W RMS
    Mono sub channel 2 ohm 500 W RMS
    Mono sub channel output in 1 ohm 780 W RMS
    Frequency range 10 Hz - 50 kHz
    Input sensitivity 0,2 - 7 V
    Input impedance >10 kohm
    Filters channel A & B HP: 50-150 Hz
    Filter sub channel LP: 40-90 Hz, Subsonic 25 Hz / 18 dB
    Low level output No
    Remote bass level control Yes
    High level input with auto start No
    Remote phase shift control Yes
    External cooling fan terminal Yes
    Phase control for subwoofers 0-180 degrees
    Power consumption (idle) 0,5 A
    Power consumption (max) 90 A
    Rec. power cable Minimum 4AWG / 21 mm2
    Fuses 3 x 30 A
    Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
    Weight 5,9 kg ( 13 lb)
    Ini link dari pabrikannya: http://www.dls.se/en/car/prod.html?produkt=en_10
    Mint Condition (9/10). Suara bening, 100% works perfectly. Boleh test dengar sebelum beli.
    Dijual lengkap berikut remote bass, dus & buku.
    Barang dijamin asli! Jika ternyata dapat dibuktikan palsu, uang kembali alias ampli-nya gratis!
    Alasan jual: mau main bi-amp alias tweeter & midbass dipisah power-nya.
    ini pic-nya (barang masih nempel di mobil).
    Spoiler for Pic: Show
    open price: Rp. 4,950,000
    SMS only 0815-84321861
    UP..UP..UP !!
    UP..UP..UP !!
    UP..UP..UP !!
    UP..UP..UP !!
    UP..UP..UP !!
    Pending Sale!!
NGK Busi GT Radial
  1. Replies: 16
    Last Post: 28th September 2010, 17:02
  2. Replies: 43
    Last Post: 28th April 2010, 10:56
  3. Replies: 36
    Last Post: 17th September 2009, 19:27
  4. Power 3 channel, 2 channel depan, 1 channel sub
    By torpey in forum Diskusi Power Amplifier
    Last Post: 17th August 2005, 01:28
