SQL Jazz RS budget 7jtan
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/250466
    haduuh saya bingung nih masang buat jazz rs
    berhubung masih SMA, bokap saya ganti ganti mulu nih
    disuruh cari barang sendiri, baru bawa kebengkel pasang doang
    padahal saya jg ga ngerti apa apa nih
    jadi bermodalkan ngira ngira aja, saya pilihlah susunan seperti ini
    Spoiler for setting 1: Show
    Power : LM Audio - CP 5100.5
    Spoiler for LM CP 5100.5: Show
    5 Channel Class AB Power Amplifier
    4 x 60Watt + 150Watt (4 Ohms)
    20Hz - 20KHz Frequency Response
    452 x 55 235mm
    Power Output in 4 Ohm : 4 x 60W
    Power Output in 2 Ohm : 4 x 90W
    Mono Bridge mode 4 ohm : 2 x 180W
    Low Pass Filter : 40 - 400Hz
    Hi Pass Filter : 40 - 400Hz
    Remote Sub Control : YES
    S/N ratio : >90dB
    THD : <0.05%
    Frequency Response : 20 - 20KHz
    http://audiojakarta.com/power-multi-channels/420-lm-audio-cp-51005.html
    Front speaker : DLS R6A
    Spoiler for DLS R6A: Show
    (2 - Way System)
    Bass : 6.5" (16.5cm)
    Tweeter : T25 (25 mm / 1")
    Power : 80W RMS / 120 W Max.
    Sensitivity : 94dB
    Magnet : 100 mm / 3.94"
    http://audiomobilshop.com/detail/dls-r-6a
    Sub : ane bingung mau pake yang mana, tolong kasih saran bagusan mana
    Spoiler for Rockford P212S4: Show
    Impedance : 4, 8, D2, D4
    Power Range : SVC 200rms/400peak - DVC 250rms/500peak
    Motor Size : 60oz double stacked
    Coil Diameter : 2" alumunium
    Speaker Connector : 8 AWG compression
    Outer Diameter : 12.6875"
    Cutout Diameter : 11.125"
    Depth : 6.125"
    Rec. Sealed Enclosure : .85 ft3
    Rec. Vented Enclosure : 1.75 ft3
    Tuning Frequency : 37 Hz
    http://audiomobilshop.com/detail/rockford-p212s4
    http://www.kaskus.us/showpost.php?p=388565227&postcount=5757
    tapi pas tadi saya bilang ke bokap katanya kalo kaya gitu powernya takut ga ngangkat jadi akhirnya bokap ikut milihin, dapetlah
    Spoiler for setting ke-2: Show
    452 x 55 235mm
    S/N ratio : >90dB
    THD : <0.05%
    Spoiler for Rockford Fosgate - P1S410: Show
    10 Inch 4-Ohm Subwoofer
    Molded polyproplene woofer cone with poly-foam surround
    Power range : 50-150watts RMS (300 watts peak power)
    10" 4-ohm subwoofer
    Molded polypropylene woofer cone with poly-foam surround
    Power range: 50-150 watts RMS (300 watts peak power)
    Frequency response: 30-250 Hz
    Sensitivity: 85 dB
    Spoiler for ADS - 236is: Show
    Frequency Response +/- 3dB : 40Hz to 22KHz
    Sensitivity : 91dB
    Impedance Nominal : 4 Ohms
    ecomended Amplifier power watts RMS : 15 to 150
    Dimensions, wwofer / midrange transducer : 2 7/16" /63mm
    Free Air Resonance : 57.1Hz
    Voice Coil Diameter : 1 / 25.4mm
    Voice Coil Lenght (Winding Lenght) : 12.5mm
    tapi setelah dipilih seperti itu, saya makin ragu
    karna dipilihin yang kecil kecil sama bokap..
    sebenernya kalo kaya gitu saya dengerin RnB bisa 'jedang jedung' ga sih???
    atau kalo bisa modcomer kasih saran deh power pakenya apa apa aja dengan budget 7jt
    tp yg nyarinya ga susah
    please banget dibantu, bingung banget nih saya
    Jakarta 11520
    2 Days 42 Mins 21 Secs
    Gw jg msh sma n pake jazz RS juga.. Hehehe.. Pake full RF aje. Sub p1 10" (2pcs),mono nya r500.1, 4 ch nya r 300.4. Dah tuh tinggal cari speaker aja yg cocok.. Trus nambah duit lg dikit buat instalasi.. Beres.. Huahahaha...
    itu ganti aki ga??
    kalo ganti, ganti berapa?
    5 Days 5 Hrs 41 Mins 56 Secs
    Untuk Jazz RS, kalau boleh nimbrung saran bisa pertimbangkan:
    tweeter = Vifa xt25sc90 = 650rb
    midrange = Vifa TG9 = 1jt
    midbass = Peerless SC18 = 750rb
    passife 2way = 700
    Power Gardiner 4ch = 1jt
    Power Metallic 2ch = 800rb
    Sub ARC KS12D4 = 1,2jt
    Box full bagasi+kbl+peredam pintu depan+dll = 2,5jt
    Total = 8,6jt
    Harga khusus Modcomer = 7jt pas
    JOIN THE UnSCAC'S!!!!
    New Avexis FU6s on:
    E-MAIL: unscac@yahoo.com
    Whatsapp, Cell : 082141139097
    Line: Hwely
    Please DON'T sent via PM!!!
    Quote Originally Posted by UnSCAC View Post
    passife 2way = 700
    Total = 8,6jt
    passive 2 way itu untuk belakang?
    Enggak, passife itu singkatan dari Passife Crossover Network, fungsinya untuk memisahkan suara nada tinggi dan nada vocal untuk membagi pekerjaan Tweeter dan midrange, sekaligus memastikan mereka bekerja dengan harmony yang baik.
    Speaker belakang kita tidak sebutkan karena memang tidak kita sarankan untuk digunakan, beberapa kasus dimana penumpang belakang cukup 'penting' untuk mendengarkan musik lebih jelas, bisa dikasih sebuah coaxial yang tidak terlalu mahal, kemudian dihubungkan langsung ke HU dan cuma dinyalakan ketika memang ada kebutuhan tersebut. kebetulan fitur menyala-matikan internal power amplifier di dalam HU sudah tertanam dalam HU kenwood bawaan Jazz RS. Bagi HU yang tidak memiliki fitur tersebut, bisa menggunakan switch manual untuk menghidup-matikan speaker belakangnya.
    New Avexis FU6s on:
    Line: Hwely
    oooh xo maksudnya...
  1. exe 20an..lebar belang..7jtan
    By itoracism in forum 20 Inci
    Last Post: 26th June 2012, 09:28
  2. Replies: 13
    Last Post: 13th March 2012, 16:11
  3. Dilegooo»»Velg OEM harrier+ban 7jtan aja..(ORI)
    By carisini in forum Ragam Ukuran
    Last Post: 23rd November 2011, 12:53
  4. Jual >> Rep.Autocouture 19x8,5+9,5 + ban 90% Rp.7jtan
    By liqlique in forum Ragam Ukuran
    Last Post: 21st March 2011, 22:51
  5. 5zigen FNO1R-C+ban r18 kond 85% cuma 7jtan
    By andy_gabriel85 in forum Bursa Kaki Lainnya
    Last Post: 1st April 2008, 13:03
