[REPOST] Zapco Competition Series - C2K-3 + Symbilink Cable
Results 1 to 10 of 78
  • Short URL:  http://modifika.si/248953
    12 Hrs 34 Mins 55 Secs
    [REPOST] Zapco Competition Series - C2K-3 + Symbilink Cable (Update Harga)
    Dijual Zapco Competition Series - C2K-3 dengan kabel Simbilink-nya. Made in USA. Secondhand berfungsi dengan normal.
    Spoiler for Specs: Show
    Spek:
    Stereo, 4 ohms: 2x75 Watts
    Stereo, 2 ohms: 2x150 Watts
    Stereo, 1 ohms: 2x300 Watts
    Bridged, 4 ohms: 1x300 Watts
    Bridged, 2 ohms: 1x665 Watts
    T.H.D. + Noise: <0.015%
    Frequency Response: 20Hz - 20kHz; +0 dB/-0.32 dB
    S/N Ratio: >100dB
    Transient Distortion: <0.008%
    Slew Rate: >28V/uS
    Damping Factor: >1000
    Input Sensitivity: 1-4 Volts or 4-16 Volts
    Dimensions: 17.5"L x 8.75"W x 2.375"H
    -Chassis design allows infinite customization options by replacing slide-in trim panels to personalize any installation
    -SymbiLink™ Balanced Technology provides up to 16 volts of balanced input for the cleanest quietest signal possible
    -Pre-clip and output clip indicators to maximize performance settings
    -Symmetrical, discrete power amplifier circuitry
    -Fuse, short circuit, high temperature, DC offset, and over voltage protection
    -Dual color LED for power and protection indications
    -25-amp High Current Bi-Polar output devices
    -50-amp MOSFET switching devices
    -Optically isolated power supply
    -Gate Drive Boost maximum power supply efficiency and improves overall performance
    -Very high damping for excellent speaker control
    -Surface Mount Technology w/1% resistors, precision capacitors and massive ground planes
    -High Current design allows 2 ohm loads for use as a bass amp with low Z woofer systems
    -Four layer PC board with heavy 2 oz copper
    -Variable electronic crossovers (Input & Aux Out)
    -Pass-through output
    -Sub-sonic filter for speaker protection
    -Switch for use as stereo, single L ch. or R ch. bridge
    -L+R sum mono for use as a bass amp
    -Dual cooling fans allow any mounting position
    Zapco C2K3.0X Zapco C2K 30X Competition 2 Ch. 665 Watt Amplifier
    Sumber: http://www.woofersetc.com/p-587-c2k-...amplifier.aspx
    Spoiler for kelengkapan: Show
    unit + simbilink
    Spoiler for penampakan: Show
    Spoiler for zapco: Show
    Spoiler for Zapco: Show
    Terms of Purchase
    Harap dibaca jangan ditanyakan lagi apa yang sudah ditulis di sini. Maaf kalau kurang berkenan, sy ketemu byk orang yang gak gentleman dalam bertransaksi.
    Spoiler for terms of purchase: Show
    - Tidak menjawab pertanyaan "nett, super nett, superduper nett" , "harga pembukaan sudah diposting, kalau mau menawar saya persilahkan, kalau mau lihat kondisi barang terlebih dahulu juga silakan.
    - No Price Police.
    - Tidak menerima booking-bookingan. Siapa bayar duluan unit dijual ke ybs.
    - Tidak menerima pengiriman baik dalam maupun keluar Jakarta. Barang bisa diambil di tempat saya (Rasuna Said/Salemba) atau kalau mau dites janjian dulu di installer saya di Kali Malang, Jakarta Timur.
    - No garansi. Barang dijual dalam kondisi fully functional dan tidak rusak pada saat jual beli. Pembeli diberi kesempatan untuk melakukan pengetesan dan pengecekan sebelum membeli. No refunds karena alasan apapun.
    - Tidak menjawab pertanyaan "kalo buat monoblok bisa nggak", "kalo buat ngangkat speaker xxxx kuat nggak?" atau pertanyaan bersifat teknis lainnya. Saya juga user,jadi pertanyaan2 teknis bisa ditanyakan langsung ke installer langsung.
    Spoiler for Harga: Show
    Rp2.750.000,00
    Spoiler for Kontak: Show
    Minat hub. 081286268627 (kalau tidak diangkat berarti sedang ada keperluan, silakan sms)
    Selamat sore Modcom
    Bexazi ..
    Selamat malam Modcom
    Quote Originally Posted by fully.lebay View Post
    Thank you om Lebay
    1 Wk 2 Days 3 Hrs 17 Mins 28 Secs
    Selamat siang Ry, apa kabar...
    Malem Pak El, kabar baik :-)
    *masukin smiley sekarang gimana yah?
    Kebetulan aja saya pake titik dua + kurung tutup.
    Mudah2an cepet laku ya...
    Thank u Pak El.
    Up dulu Selamat Pagi Modcom!
    Sundul dulu dini hari
    Up up selamat sore
  1. (WTS) Zapco Competition Series - C2K-3.0x @ Surabaya
    By davetrends in forum Power Amplifier
    Last Post: 28th February 2012, 10:02
  2. Replies: 6
    Last Post: 3rd June 2011, 01:29
  3. wts: Genesis DA100, Zapco 350 + Symbilink Cable
    By sinar_jaya in forum Power Amplifier
    Last Post: 27th February 2011, 07:24
  4. Replies: 6
    Last Post: 11th April 2010, 01:51
