.:de Auto Motorsport:. HONDA K-SERIES PERFROMANCE & SWAP PARTS
Page 1 of 27 12345 ... LastLast
Results 1 to 10 of 264
  • Short URL:  http://modifika.si/248629
    1 Wk 3 Days 2 Hrs 57 Mins 2 Secs
    .:de Auto Motorsport:. HONDA K-SERIES PERFORMANCE & SWAP PARTS
    HONDA K-SERIES PERFORMANCE PARTS
    PERFORMANCE PARTS HONDA K20 & K24 DOHC i-VTEC
    dengan kondisi barang semua nya 100% baru
    Yang berminat bisa kontak langsung:
    Coki Siboro - de Auto Motorsport
    0815.1330.1978
    021.9866.1978
    SWAP PARTS
    HASPORT MOTOR MOUNTS
    Hasport Engine Mounting Swap Kit for Honda Civic EG 92-95 with K-Series Engine Swap.
    Durometer : 62A Urethane (Street)
    Performance mount kit for K-series engine swaps into the 92-95 Civic and all years of the Civic Del Sol. After making some modifications to the engine bay, this mount kit makes swapping the K-series engine into the EG Civic and Civic Del Sol a bolt in procedure.
    Like All Hasport Mount Kits, it's designed using sophisticated CAD/CAM software. This kit optimized engine placement for best axle alignment, ground and hood clearance and designed blending strength and style with a lifetime warranty for worry free use.
    P2R K24 MOTOR MOUNT BRACKET
    Doing a K24 swap? No need to go to Honda to get this bracket anymore. P2R now offers you a better solution. This bracket weights in at only 310 grams, while the Honda bracket weights in at 805 grams. P2R bracket is made from 6061 aluminum and then anodized clear for added strength.
    HASPORT AXLES
    Hasport Axles Swap Kit for Honda Civic EG 92-95 with K-Series Transmission Swap.
    Spec : Level 1 (Street)
    Hasport Axles are made from completely brand new parts and do not require a core like many other competitors do.
    K-TUNED SHIFTER MOUNTING KIT
    Application :
    Honda Civic EK 96-00
    The mounting plate is constructed using 3/16 thick billet aluminum and is anodized black for a great looking and durable finish. Customer reviews of this mounting kit have continually stated that it is much easier to install.
    Key features:
    * Unique steel template is included which greatly improves cut out accuracy
    * Custom made grommet seals cables perfectly
    * The factory shifter is held firmly to the plate with studs and custom fit billet aluminum bushings
    * Very easy to install with complete instructions and template provided
    * Silver zinc plated hardware to resist rust
    * Lightweight aluminum design
    K-SERIES ECU REMAPPED
    PND ECU Modified to 6 Speed Manual Transmission PRB. Just Start & Drive with SwapECU-K..!
    Features:
    - Immobilizer Disabled
    - Multiplexer Enabled
    - Reverse Lockup Added
    - Secondary O2 Sensor Disabled
    - ELD Disabled
    K-TUNED WIRING CONVERSION HARNESS
    Application :
    A K-swap conversion harness is a must-have part for any K-series engine swap. The harness is required to join up the factory K-series engine harness to the factory dash harness of the swapped car. It is designed integrate the K-series ecu and all of the related electrical functions get them operating properly. Functions like the fuel pump, tachometer, speedometer, starter signal, O2 sensors, etc.
    The harness is 99% plug and play and takes very little time to install. The harness is constructed with quality mil-spec spec, OEM colored wire and finished with a nice clean looking mil-spec nylon sleeving for protection. The harnesses come complete with installation instructions and a very cool wire cutter / stripper tool. The end result is a very high quality conversion harness at the best possible price. Several applications are available so get yours to make sure your K-swap is wired up right!
    K-TUNED STAINLESS CLUTCH LINE KIT
    Application :
    This fully stainless steel clutch line with SS fittings comes complete with all the adapters needed for both outlet sizes found on oem Honda clutch master cylinders. This way, no matter what master cylinder you have, the clutch line will fit. It also has properly angled fittings on both ends of the hose for a very clean looking install. There is a 180 degree fitting on the master cylinder end and a 90 degree fitting on the slave cylinder end. There will be absolutely no corrosion on this line setup because the hose, adapter fittings, and hose ends are all 100% stainless steel.
    K-TUNED THROTTLE CABLE & BRACKET
    Application :
    NOTE: Does NOT work with JDM K20A throttle or BDL Performance throttle bodies. This will ONLY work with North American K20A2 and K20Z1 throttle bodies.
    No more long throttle cable all over the engine bay, this one is just long enough to reach the firewall with no wasted length and just enough slack. Cable is a custom sized OEM quality cable. Bracket is powder coated black.
    Key Features:
    * Powdercoated steel bracket
    * Properly sized throttle cable
    * OEM quality & appearance
    PERFORMANCE PARTS
    BRIAN CROWER PRO SERIES H-BEAM CONNECTING ROD
    Application : K24A
    # Lightweight bROD Series
    # w/ARP2000 Fasteners
    # 4340 Steel Billet
    # Supports 700 hp @Flywheel
    # Bronze Bushings
    Made from premium, 4340 steel billet material, Brian Crower connecting rods are available in two distinct styles depending on horsepower, budget and engine application, but both include the exclusive Brian Crower oiling groove in the pin bushing for added oiling.
    The bROD Series is intended for moderate boost applications and all motor race applications where peak horsepower is not going to exceed 700 at the flywheel. Utilizes venerable ARP2000 fasteners.
    EAGLE H-BEAM CONNECTING ROD
    Application : K24A
    All Eagle "ESP" Connecting Rods are manufactured from a TWO-PIECE FORGING. The forging process forces the grain into the shape of a connecting rod, resulting in a superior fatigue life. The rod cap is forged separately so that the grain runs perpendicular to the load forces, which strengthens the connecting rod. Many aftermarket connecting rods are manufactured from 4340 steel. 4340 specs allow a range of different materials to achieve the desired results. Although it is a more expensive process, all Eagle "ESP" 3-D connecting rods also include higher content of nickel & chrome, which increases the strength & fatigue life without making the connecting rod brittle.
    Extensive testing has proven Eagle's two-piece forging superior to any one-piece forging on the market! All Eagle "ESP" Rods are clearly identified. Proper rod bolt torque is vital to connecting rod life. A rod bolt fastner is without question the highest stressed fastener in the engine. The big end bore of the connecting rod is a stressed bore in much the same way as cylinders are on a block. It is equally important to torque properly to provide proper strength & to insure the big end of the rod sizing is correct. Improper torque will result in premature rod failure!
    K1 TECHNOLOGY H-BEAM CONNECTING ROD
    Application : K20A
    Forged 4340 Steel I Beam connecting rods. Shot peened for improved fatigue life. Sizes held to +/- .0001 , finish honed in the USA. Bronze wrist pin bushings. Weight matched +/- 1 gram on each end. Exclusively using ARP fasteners.
    Billet 4340 Steel H Beam connecting rods. Closely monitored material mechanical properties for optimum performance. Designed and finish honed in the USA. Sizes held to some of the tightest tolerances in the industry, +/- .0001 and +/- 1 gram per end. Shot peened for improved fatigue life. Bronze wrist pin bushings. Exclusively using ARP 2000 fasteners.
    WISECO FORGED PISTON KIT
    Application : K24A
    Bore : 87mm
    Compression Ratio : 12,5 (with K20A Head)
    ACL RACE SERIES BEARINGS
    Application : K20 & K24 (Standard Size)
    High performance driving demands that you use the best parts. So rely on ACL's Race Series Products to perform to the exacting race standards you expect. They provide the dependability it takes to hold up under higher RPM conditions. The unique combination of design, metallurgy and engineering come together to deilver what drivers expect from high performance parts.
    OEM RSX TYPE-S OIL PUMP
    Whether you are building a K24/K20 or just rebuilding your stock K motor, the Type-S oil pump is the best and most reliable oil pump for the money. This oil pump is proven to provide oil pressure to 8600rpm.
    SUPERTECH PERFORMANCE ENGINE BLOCK GUARD
    On-Stock for : K20 Block & K24 Block
    Supertech Block Guards are meticulously designed and tested in many engines. As a result Supertech offered Block Guards that will provide support to highly stressed cylinder walls with optimal engine cooling by allowing enough water in critical areas to avoid destructive cylinder hot spots.
    Supertech Block Guards are made from high strength, corrosion resistant 6061 aluminum alloy and CNC machined for precise installation.
    SUPERTECH PERFORMANCE VALVE SPRING
    Application : K20 Head & K24 Head
    Type : Dual Spring
    Recommended Lift : 14.0mm-15.5mm
    Running in High Profile and Lift? You're definitely need Supertech Dual Valve Springs!
    SUPERTECH PERFORMANCE TITANIUM RETAINER KIT
    These will work on all Supertech Valve Springs, OEM Valve Springs and possibly some other manufacturer aftermarket valve springs
    They utilize the OEM Style 7 Degree Keepers -- you can use your Stock ones or purchase the Supertech ones.
    The Retainers are manufactured with high quality military certified Titanium alloy, CNC machined for a tight fit that will ensure a long durability.
    SUPERTECH PERFORMANCE VALVE KEEPER/LOCK
    Type : 5.5mm & 10 Degree Design
    Newly redesigned and now fully CNC Machined for a higher quality and better precision finish.
    SUPERTECH PERFORMANCE VALVE SEALS
    Supertech Valve Seals are the final piece of the puzzle for your performance valvetrain.
    Material :
    Exhaust Seal > Viton
    Intake Seal > Polyacrylic
    COMETIC MLS HEAD GASKET
    Application : K24A with K20 Head
    Bore Size : 88mm & 89mm
    Thickness : 0.030" / 0,76mm
    ARP HEAD BOLTS KIT
    Quick Overview
    Premium grade 8740 alloy
    Heat-treated to 190 ksi
    Thread rolled after heat-treat
    EXEDY HYPER SINGLE SERIES CLUTCH KIT
    Application : K20 & K24 Transmission
    - Honda Civic Type-R K20A2 (Hyper Single Series Complete with Lightweight Flywheel)
    - Integra DC5 K20 (Hyper Single Series Complete with Lightweight Flywheel)
    BUDDYCLUB P1 RACING SPEC FINAL GEAR
    Application : All Honda K-Series Transmission (Both K20 & K24)
    Gear Ratio : 5,46
    Direct Replacement for your OEM final gear ratio. Honda OEM Type-R Ratio is 5.062, by replacing with this BuddyClub Racing Spec 5.46 final drive set, your vehicles acceleration will increased dramatically..!
    SKUNK2 COMPOSITE FUEL RAIL
    Application : K20 & K24 Head
    This is a Fuel Rail with bigger volume. The composite material reduce or will not absorb heat from the engine room, thus you'll get colder fuel temperature for a better performance.
    RC ENGINEERING INJECTORS 440CC
    Flow Rate - CC's:
    440 CC's / MIN @ 43.5 PSI
    Resistance:
    12.5 Ohms @ 68 F
    RC Engineering is the world's leading supplier of made-to-order, high-performance, electronic fuel injectors. RC injectors are available for a wide range of automotive, motorcycle and marine engines used in high-performance or racing applications.
    HONDA RBC INTAKE MANIFOLD
    Note : MUST BE MODIFIED to fit K20a/a2/a3 cylinder head
    This is by far the best intake manifold Honda has made as far as power is concerned. The RBC manifold out performs the PRB and PRC manifolds almost everywhere. There is a little loss in power from low to mid range rpm but from the 5500rpm point and up the RBC takes the win by a good bit.
    SUPER90 ALUMINUM THROTTLE BODY
    Bore Size : 70mm & 74mm
    This is a Big-Bore Throttle Body as an upgrade for Honda/Acura DC5-R & EP3-R. Bigger Bore size is a perfect choice if you're running K-Series Turbo or NA Engine looking for a top end power..!
    ... to be continue
    other honda k-series performance & swap parts can be available upon request.. tq
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    1 Wk 2 Days 10 Hrs 37 Mins 14 Secs
    wiih,makin sadis aja ni parts2 nya
    RACINGrepublic
    Kontak : Agus
    HP/WA : 0857 1417 7725
    BB Pin : D534E597
    1 Wk 6 Days 14 Hrs 52 Mins 39 Secs
    Wuihhhhhhh
    manteb pisan bozzzzz
    Quote Originally Posted by RacingRepublic View Post
    Quote Originally Posted by HotHatch View Post
    Wuihhhhhhh
    masih dikit nih om....
    CP : Coki Siboro
    Now it's time for K-Series...
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
Mega Glodok Kemayoran GT Radial
  1. .::de Auto Motorsport::. Second Hand Parts..!
    By coki.de auto in forum Engine & Parts
    Last Post: 16th February 2015, 18:06
  2. .:de Auto Motorsport:. HONDA D-SERIES Performance Parts
    Last Post: 16th February 2015, 18:04
  3. ::de Auto Motorsport::[ HONDA COMBO PACKAGE ] Racing Parts - Limited
    By coki.de auto in forum Jual Beli Mesin Lainnya
    Last Post: 10th April 2013, 14:12
  4. HONDA K-SERIES PERFROMANCE & SWAP PARTS
    By coki.de auto in forum de Auto Motorsport
    Last Post: 29th November 2012, 16:36
  5. B series Swap PARTS for HONDA engine
    By HotHatch in forum Jual Beli Mesin Lainnya
    Last Post: 4th June 2012, 20:07
