Mesin Renault Clio 1.4L 126hp, ECU, transmisi 5MT + parts lainnya
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/247722
    Jakbar
    Berikut parts yang dijual:
    Engine 1.4L K4J + ECU + Wiring (Royal Purple inside)
    - Busi Iridium
    - Seal oil pan new original
    - 126hp dyno terakhir (kalau pakai unichip)
    Transmisi manual 5-speed (Royal Purple inside)
    Shockbreaker front original(1 year use)
    Shockbreaker rear rebuild Muse
    Per H&R uncut 1.5"-2" drop
    Lamp housing rear kanan
    Fuel pump original (6 months use)
    Steering wheel with airbag
    Passenger side airbag
    Radiator
    AC components (compressor, condensor etc)
    Tie Rod (left/right)
    CV Joint /boot
    Header + full exhaust
    Open air intake 3"
    Front bumper (need minor repair)
    Rear bumper (need minor repair)
    Power window system (motor + switch)
    Front & rear window (passenger + driver)
    Brake system (caliper, disc, pads, master cylender, etc)
    Other suspension parts (arm, bushing2 etc)
    All other interior stuff (kalau masih ada)
    All electrical system (excluding ECU)
    New addition: 2pcs Volk Racing CE-28 Original (15x7 et+35, white)
    New addition: 2pcs Volk Racing CE-28 Original kondisi bengkok
    New addition: 2pcs Ban GT Radial Champiro SX1, 195/50/15 tread 95%
    New addition, 2pcs Ban Toyo Proxes R888 semi slick, 195/55/15 tread 70%
    New addition: 4pcs Work CR-KAI replica (15x6.5 et+38, bronze) plus Achilles 123 195/50/15 99%) tidak dijual terpisah.
    Barang2 semua ada di daerah Pakubuwono, ***by appointment only***. Deal harga dulu lalu viewing barang. Jika barang cacat boleh batal. Barang masih attached ke mobil, kecuali velg. Harus bawa mekanik + kunci2 sendiri.
    Bisa contact by email di: arditjoa at gmail dot com atau reply ke email ini. Jika mau contact by phone bisa kasih no telp anda ke saya by email. Thank you.
    Best regards,
    Ardi
  2. Bandargua
    *JogJa*
    10 Hrs 14 Mins 44 Secs
    ada pic Work CR-Kai nya bos?
    atau kalau bisa pm harga skalian.. hehehe thanks bos..
    Jakbar
    Quote Originally Posted by ditoo View Post
    Ini foto nya bro:
    dan kembangnya masih bagus, cuma dipake dua bulan:
    Harga di PM
    Jakbar
    uppp uppp Mesin + transmisi masih ada
    2 Wks 6 Days 18 Hrs 22 Mins 31 Secs
    Ini gmn kelanjutannya niy?? Xixixixixi...
    Masi ada kah??
Venom 300x250 Vkool
  1. Pake apa naekin performa mesin Renault Clio ???
    By tikal in forum Diskusi Mesin
    Last Post: 26th November 2016, 16:04
  2. WTS Mesin dan Transmisi Matic Tiger 230 serta part lainnya...
    By enrico hotman in forum Jual Beli Mesin Lainnya
    Last Post: 25th October 2011, 14:33
  3. WTS: Renault Clio A/T 02
    By indra2226 in forum Renault
    Last Post: 24th January 2011, 12:31
  4. WTB oem renault clio
    By wongjowo in forum Bursa Kaki Lainnya
    Last Post: 24th November 2008, 22:57
  5. WTB Renault clio
    By Mesin023 in forum Renault
    Last Post: 9th October 2008, 18:54
