STRI DSD SLMOil Temp Gauge 60mm.. 99%
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/247426
    2 Wks 1 Day 2 Hrs 48 Mins 14 Secs
    STRI DSD SLM II Oil Temp Gauge 60mm.. 99%
    Jual STRI (white) DSD Stepping gauge 60mm.. 99% lohh...
    (bekas 2 minggu di WRX di singapore, mobil lg standarin)
    Ini yang seri SLM II.. ada Peak warning lamp..
    lengkap Box, sensor, wirings, Peak limit button, holder stand & visor...
    Features:
    Warning - User Preset
    Peak Recall
    Automatic Self Calibration
    Short Circuit Auto Detect
    Racing Spec Sensors - Exteme Accuracy
    270 Degree Full Sweep - High Resolution
    Sequential Open / Closing Mode
    jual 1.6jt..
    mau?
    08128702666
    Photo asli... (body full titanium steel case & full socket connector)
    link:
    http://autotechinteriors.com/index.p...ii-series.html
    http://autotechinteriors.com/index.p...white-led.html
    Upppp ahhhhhh....
    up lagi ahhhh....
    anyoneee? cocok buat mesin turboooooo.....
    anyone? harga nego dekit....
    dekit info about oil temp...
    Oil Temperature Gauge is for anyone who wants to know exactly what the temperature of their engine oil is during peak performance. Too high of an oil temperature can break down even the best motor oils. Your coolant temperature and oil temperatures can be very different, modern "performance" engines running over 120 degree oil temps yet have normal coolant temps. The 320 degrees of resolution makes it easy to see when there's even a 2 degree change in temperature, giving you time to shut things down before damage occurs. The lightning fast needle movement is a result of a precision high speed electronic stepper motor making it one of the fastest and most accurate gauges available.
    Honoured Member
    MODIFIKASI.COM
    mohon dijelaskan dan ditulis dengan jelas kondisi barang disemua thread anda, baru / 2nd sesuai dengan peraturan modcom.
    kategori larangan penjualan barang baru terutama berhubungan dengan otomotif kendaraan roda 4, yaitu:
    Barang yang belum pernah terpakai atau terpasang di kendaraan, dikategorikan sebagai barang baru.
    Barang sisa stock, new old stock (nos), dan semacamnya.
    Barang cuma buka bungkus saja, untuk alsan cek kelengkapan, dan semacamnya.
    Barang tidak jadi pakai atau salah beli juga masuk dalam kategori barang baru.
    Barang gadget dan eletronik spt gps dan alat elektronik lain yang berhubungan dengan roda 4
    Barang aksesoris, variasi, parfum, emblem (tidak termasuk stiker), yang berhubungan dengan kendaraan roda 4.
    Penawaran jasa perbaikan mesin, body kendaraan, salon mobil, dan sejenisnya.
    Silahkan menuliskan dengan jelas kondisi barang dan jumlah barang pada thread jualan barang bekas anda.
    Ketidak lengkapan informasi barang bisa berakibat dianggapnya sebagai kondisi barang baru dan berakibat infraction/banned.
    Siapp bozz!.. thanks for bandwidth juga... : )
    Ayo2.. up2...
    barang msh mulus..
    uppppp ahhh......
  1. WTS 2nd Indikator Auto Gauge Water Temp, Oil Temp, dan Oil Pres.
    By yessar in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 27th October 2012, 15:04
  2. WTB: auto gauge water temp 60mm yg dusnya item..black face
    By bobby1987 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 27th January 2010, 12:43
  3. WTS: AUTO GAUGE BLACK(WATER TEMP,OIL TEMP,VACUM) Wowwww,,!
    By RLX in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 5th July 2009, 23:58
