Ultimate SUB: 23W Scanspeak
Page 1 of 16 12345 ... LastLast
Results 1 to 10 of 157
  • Short URL:  http://modifika.si/245166
    1 Wk 5 Days 11 Hrs 6 Mins
    Dear modcomers..
    Jual Ultimate Sub: 23W from scanspeak, Kondisi sangat mulus, Very clean for SQ, liter volume tidak besar, jadi kalo dipasang di mobil sangat pas tidak memakan space bagasi. dijual SOLD . Posisi barang di element audio, MGK lt 5,
    diambil dari madisound : https://www.madisound.com/store/product_info.php?products_id=1347
    ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, Silver Cone
    Madisound# 23W/4557T
    Quantity 1+ 10+
    Price for each $385.00 $346.50
    Your savings - 10%
    Reviews Quantity:
    The Scan-speak 23W/4557T is a very high end subwoofer, designed to be used with a passive radiator in a small enclosure. This sub has a very rigid aluminum cone, low loss rubber surround and cast frame. The passive radiator is similar, but with a weight attached to the bass of the cone. The 23W/4557T is using the SD-1 motor system. There are gold plated binding posts and the woofer is covered by a decorative rubber cap.
    Frequency response with the passive is down to 25Hz. One cubic foot sealed has an F3 of 33Hz.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 82 dB
    Free air resonance Fs 20.5 Hz
    DC resistance 3.45 ohm
    V.C. inductance 0.45 mH
    Power 225 W
    Effective cone area 232 cm2
    V.C. diameter 50 mm
    VC height -
    Air gap -
    Lin. & max. excursion 13 / 20 mm
    Air gap flux density -
    Force factor BL Product 9.3 Tm
    Moving mass incl. air 101 g
    Net weight 4.6 kg
    Vas 45.6 ltrs
    Qms 4.8
    Qes 0.52
    Qts 0.47
    Outside diameter: 255mm
    Cut out: 225mm
    Depth: 135mm
    25.4mm = 1" = 2.54cm
    klaten
    pertamaaaxx...up lg bwat sub mantep
    tks bro...
    up dulu............
    up dulu............
    up dulu..........
    up dulu............
    up dulu........
    up dulu...........
    up dulu............
MBtech Venom 300x250
  1. Dijual Scanspeak R7000 + Scanspeak 18W
    By asawendo in forum Speaker - SubWoofer
    Last Post: 9th November 2012, 00:44
  2. Replies: 11
    Last Post: 9th October 2012, 11:32
  3. Power 4 Chanel or 5 Chanel For Scanspeak R 7000 + Scanspeak 15 W
    By xsmxl in forum Diskusi Power Amplifier
    Last Post: 9th February 2012, 11:03
  4. [WTS] Ultimate 2way : Scanspeak R7000 + 18W
    By soluna00 in forum Speaker - SubWoofer
    Last Post: 21st February 2011, 06:02
  5. Replies: 37
    Last Post: 24th July 2009, 02:16
